03-08-2024, 01:23 PM | #1 |
Rep 274
Drives: 2018 440i xDrive Gran Coupe
Grounding wire for dashcam...can I use this?
Hi all, hardwiring my dash cam to rear fuse box. Unfortunately the wire is too short to reach the bolt on the left side of the fuse box, but saw these two on the passenger sidd of the car. Can either of these be used?
03-08-2024, 01:57 PM | #2 |
Rep 770
I added an aux cooling fan to my EKP. I used the ground for the EKP hold down. This broke my comfort access in the same way aftermarket door projectors break comfort access. Remove the ground wire, and comfort access came back
03-08-2024, 02:15 PM | #3 |
///M
168
Rep 639
Drives: '18 F80 M3 ZCP, '14 F30 328i
Could you possibly cut, solder, and use shrink wrap to make your wire longer?
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI |
03-08-2024, 04:04 PM | #5 |
Rep 1,510
This. No need to run a ground wire all the way back there. Some would even argue that the ground wire should be as short as possible. Mine gets power from the fuse box in the trunk and grounded somewhere under the glove box. Been that way for years now.
Arthurrs92.00 Jhicks69674.50 |
03-08-2024, 04:28 PM | #6 |
Rep 267
I usually run my dashcam wiring down the A pillar (carefully securing it behind the airbag), and connect the ground to a convenient screw or nut on the side of the dashboard by the door. There's usually a panel that you can pop open. Then run the positive wire and the rear cam cable under the floor trim panels under the doors to the rear of the car.
2017 430ix Gran Coupe
03-08-2024, 10:32 PM | #7 |
Rep 16,086
