05-23-2014, 08:09 AM | #1 |
Rep 46
Drives: BMW 3 Gran Turismo
Proactive Steptronic?
Hi, I read this article and they said that Proactive Steptronic will be in cars from this summer, is possible that older cars can be updated with this "software only" change I think? https://www.press.bmwgroup.com/globa...tem=node__4100
05-23-2014, 08:25 AM | #2 |
Rep 876
Sounds interesting. I think Fifth Gear did a review of a new Rolls Royce (or maybe it was Bentley) recently. Anyway, it was well received by them. It anticipated grades and curves and downshifted accordingly. If it was a seamless integration I wouldn't mind having this feature. I'd be surprised if this was a software only upgrade. Might be some additional add ons to support this. Maybe they will bundle it like the MPPK and sell as an upgrade to those with compatible cars.
Here's some verbiage from the site: "On vehicles equipped with a navigation system, the proactive drive system ensures that the moment to shift gears is precisely adapted to the prevailing driving situation even if the navigation system is not active. The Proactive Driving Assistant works in tandem with the navigation system and “sees” a bend or a roundabout ahead and takes into account turn-offs and motorway exits. If the vehicle is approaching a roundabout or a bend, the transmission automatically changes down to the most appropriate gear, making optimum use of the engine braking effect. Subsequently, the system again shifts to the optimal gear for accelerating out of the bend. Furthermore, unnecessary gearshifts and hunting between bends are avoided through intelligent interaction with the navigation system." |
05-23-2014, 08:28 AM | #3 |
Rep 3,619
Interesting but as we know as tires wear off the accuracy of the navigation is reduced not by much though. With these inherent inaccuracies this new system is likely to have its flaws
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
05-23-2014, 09:04 AM | #4 |
Rep 876
05-23-2014, 09:08 AM | #5 |
Rep 2,757
Drives: 2020 M4 ZCP / 2023 X3 M40i
I hope there's a way to disable. If new roads are built/modified and the map doesn't get updated, is it going to think you're driving on a road that's completely different?
05-23-2014, 09:10 AM | #6 | |
Human
932
Rep 1,200
In areas where there's no GPS reception (like tunnels or underground parking garages), I'd understand why since there it relies on internal sensors to approximate from last known GPS position...but otherwise?
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
05-23-2014, 09:18 AM | #7 |
Rep 3,619
Good points but I have just observed that my navigation is always a couple of feet off as tires wear. This is something you can always check when you set your destination to "home". With time you will observe the navigation will not get you exactly to your home address but will be a few feet off. I have observed this since my first car that had navigation which I bought in 2006.
05-23-2014, 09:22 AM | #8 | |
Rep 54
05-23-2014, 09:27 AM | #9 | ||
Rep 3,619
05-23-2014, 09:29 AM | #10 | |
Rep 876
Now maybe in the past he experienced a tire upgrade that had a direct impact on MPH and odometer readings which can certainly be impacted by going to a larger or smaller diameter tire. |
05-23-2014, 09:41 AM | #11 |
Rep 3,619
Before we go nuts over this here is some interesting reading. As long as the car is in a place where the GPS signal is clear then there are no issues with locating the car. However this is not always the case. I believe this is where tire wear among other things will impact your positioning by the navigation. As I said I have had the same home and eight cars with navigation and I have observed this on all of them. I am actually the boring type that does not swap out the OEM wheels that come with the car and I always buy OEM tires to replace the worn out ones.
http://books.google.com/books?id=U2J...%20gps&f=false
05-23-2014, 10:07 AM | #12 |
Rep 1,369
An interesting observation. Time to have that sent off to the Mythbusters to see if it might be true. I have a feeling most GPS systems, when they can't get a good signal, 'estimate' their position based on speed along with internal map data and hence the error is introduced.
As for GPS, there are two types of signals. The one used in cars, GPS units, phones, etc is the Course Acquisition Code. A somewhat 'dumb downed' version of the other code, called the Precision Code. For example, mounting the GPS unit out of a smart bomb in your car, you'd likely be able to navigate to the middle of your living room. Not convinced? If he was still around you could ask Sadam Hussein. Lots of items were guided to many of Sadam's living rooms using the P code. P codes are somewhat more complex than C/A codes. A C/A code is 128 bytes (not kilo or mega, just plain old bytes). A P code is 728 gigabytes. Actually, the 728 GB code is a small segment of the master P code, a 26 TB monster. A C/A code is great for finding Disneyland. A P code is great for finding the ventilation shaft of an underground bunker. As for BMW's idea, I think it's great. What could possibly go wrong with yet another flawless auto technology that probably won't kill more than a dozen people? |
05-23-2014, 10:24 AM | #13 |
Human
932
Rep 1,200
A bit over dramatic maybe?
05-23-2014, 10:29 AM | #14 |
Human
932
Rep 1,200
Right, as I thought...
My problem was that, I was trying to picture places where GPS would be unavailable and all that came to mind (living in Geneva) were parkings and tunnels... There's however cities with skyscrapers that I didn't take into account (we don't get that many here)
05-23-2014, 10:35 AM | #15 | |
Rep 3,619
All that matters is we are on the same page, that's the problem with written intercontinental communication at times
05-23-2014, 11:59 AM | #16 |
Rep 6,990
So if "tire wear" were to have an effect on a GPS unit's accuracy, how does one account for using a portable GPS in "walking mode"? Will it's accuracy depend on shoe size, sole thickness, stride differences, etc.? Since my Garmin units aren't connected to any of my car's instrumentation, there's no way that miniscule differences in tire size will affect its accuracy.
That said, why would the Ultimate Driving Machine need this GPS-adaptive technology? Isn't that what us drivers are for? Maybe it'd be good for those who view automobiles as "transportation appliances" and would rather let the car drive itself, but not for me.
05-25-2014, 04:06 PM | #17 |
Rep 1,369
Believe me when I say I think it ridiculous that car maker after car maker is dragged into court when the annual crop of new idiots pops up and dreams up ways to crash their vehicles in fantastic and innovative ways then looks to blame anyone but themselves. It really does drive up car prices. That being said, there is a pattern of all, and I mean all automakers doing some really reckless stuff they knew better not to do.
American car companies get the most press about fatal defects but that's only because Americans like to show off European and Asian makers are just as bad. |
