10-10-2018, 08:22 AM | #1 |
Rep 130
Drives: 2016 bmw 328i xdrive
F15 m sport steering wheel on f30
Quick question about m sport steering wheels
Is the f15 m sport steering wheel the same size as the F30 msport wheel? Will the controller module in the f15 steering wheel work with F30 steering column? I bought a f15 msport wheel with paddles vibro and heat. I just wanted to make sure everything will work on my car before I install it. The wheel came with the electronics module and the wiring harness as well. |
12-07-2018, 05:21 PM | #3 |
Rep 451
Drives: 2017 X5 & 2020 X5
Gents the wiring for the paddle shift are different between the F15 (X5) and the F25 (X3) as I found out the hard way. Took me a year to eventually get it resolved.
There is a good chance it will be the same for the F2x/F3x. I also think the paddle circuit boards part # may differ and in switch resistance as well. The X5 has a BDC module, the X3 a FRM module and the F3x uses the FEM/REM to communicate with the various steering wheel and body functions. They all communicate differently with other modules I recommend you source your steering wheel from the same type of car to reduce the risk of incompatibility and problems occurring.
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 12-07-2018 at 05:36 PM.. |
12-07-2018, 09:50 PM | #4 |
Rep 130
Everything seemed to have worked for me. its very hard to find a real airbag though. Almost impossible. I dont even know if the one i got is good.
12-08-2018, 02:28 AM | #5 |
Rep 451
Ok I just checked the paddle shift wiring for the F15 vs F3x steering wheel and they are the same. However as I said before the F25 wiring differs to the F15 and I had to modify mine to make it work. My point is many sellers on eBay advertise their steering wheels will work with all models which is not correct I would suggest the buyer confirms the donor vehicle type before purchase and save the pain of it not working as expected and then fixing it often as an additional cost.
MY 17 X5 2.5d sDrive |
03-28-2024, 05:00 PM | #7 | |
Rep 5
is it compatible? |
