01-28-2017, 04:32 PM | #112 | |
Rep 2,475
Were they the original runflats from the 403s? What brand were they? Any close ups of the 225 on the 9J rim to see the stretch?
340i F31
01-28-2017, 05:01 PM | #113 | |
Rep 196
ie: 1% / 1.5% means the front wheel is 1% larger than stock and the rear wheels is 1.5% larger than stock. Ideally, both of these percentages would be the same 1% / 1% or 1.5% / 1.5% to guarantee the front and back are rotating at the same speed, but in reality, the CPU has to compensate for this as the front and rear tires wear differently over time. As for 275/35R19, you are correct. Some members use this setup just fine with no rubbing, while others either find slight rubbing or don't like the ride and have been forced down to 265/35R19.
2019 F87 M2C - DCT / 10mm spacers w 246/265 / RW lip / Suvneer skirts / PSM spoiler / BMW diffuser / 3M gloss black
01-28-2017, 05:12 PM | #114 |
Rep 196
More poke?
More width? More sidewall height? More overall height?
01-28-2017, 11:33 PM | #115 | |
Rep 1,986
01-29-2017, 02:39 PM | #116 |
Rep 1,733
Drives: 2003 M3
01-30-2017, 08:14 PM | #118 |
Rep 196
I have seen others run that same setup, so yes it will work, depends on the offset. Maybe ET35 all around?
01-30-2017, 11:22 PM | #119 |
Rep 340
01-31-2017, 03:28 AM | #120 |
Rep 157
Thank you!
I really love my original 437M wheels (looks,stance,performance). So,some better pics with my DSLR.
01-31-2017, 04:10 AM | #121 |
Rep 24
Probably the best looking F3X in Greece!
Congrats Bill for your wonderful OEM set up of these pretty nice looking original 437 Undoubtful the first non M (but OEM M sport)car in our country!! |
01-31-2017, 05:42 PM | #122 | |
Rep 196
See diagram You will not want to use any spacers with a 437m wheel on a 440 as the wheel already extends past the fender both front and back. You may want to use a 5mm spacer on the front if you choose a replica wheel.
mdai245104.00 |
04-15-2017, 11:13 AM | #123 |
Rep 260
UPDATE 4-15-17:
One of my front tire is still leaking air. Shops cannot find what it is, they have tested everything, even the tpms sensor. They cannot figure it out. I think it's leaking because it is (stretched). BUT other one holds just fine, it's only one that is giving me issues. I want to purchase two new front tires. So, my question is can I run 235/35/19 with rears being 255/35/19? My car is an XI will there be an issue? I know with XIs its trickier. Question is Can I run 235/35/19 fronts with 255/35/19 rears? My current setup is 225/40/19 and 255/35/19 I want 235/35/19 and 255/35/19 if it's okay |
05-17-2017, 10:22 AM | #124 |
Rep 177
Oguz - I'm doing a tremendous amount of research before purchasing wheels and this has been one of the best forum posts for it.
One of my OCD over-analysis traits catches the difference between the 437m OEM vs Replica look. The OEM is darker on the outside spokes and edges, while the replicas are lighter. I like the OEM darker look, but that cost difference is maybe a couple $$$thousand$$. To answer your question as far as setup, I would try to go what BMW recommends for your car. But if you want to change it up, You should also consider the size of the wheel width and offset to determine your tire setup. |
05-24-2017, 08:42 PM | #126 | |
Rep 284
Drives: 2017 340i MPPSK
Just beautiful
2017 340i LCI //Glacier Silver Metallic //xDrive//MPPSK//Premium Package//M sport brakes //Vossen 20" CV7//6 MT//Performance front spoiler//Performance side blades//Performance diffuser//Performance trunk spoiler//Tinted//Coded//Painted reflectors//Matte black 340i badge//Powder coated MPPSK tips
06-04-2017, 05:23 PM | #127 |
OOOO another former Audi B5 S4 owner OOOO
196
Rep 625
for all you running these tires on your 437m wheels:
(front) 225/40R19; (rear) 255/35R19 HOW HAVE THEY DONE OVER AN EXTENDED TIME? (I still have my 403M tires that are new and I want to keep them for my 437M wheels when those wider tires need replacing on my M2) thanks! |
06-06-2017, 04:02 PM | #128 | |
Rep 525
06-06-2017, 07:59 PM | #129 | |
Rep 578
Is anyone actually running those specs other than oguz? |
06-10-2017, 10:38 PM | #130 |
Rep 1,011
finally got my pair of OEM 437M on with continental ECS tires on the 340xi. looks and feels great!
maybe a drop in the future but enjoying the travel and compliance and nibble handling for now. stockers were: 225/40 255/35 with the 437Ms swapped tires to: 235/40 265/35 Last edited by monkiboy; 06-13-2017 at 11:08 PM.. |
06-11-2017, 11:45 AM | #131 |
Rep 418
I've a strong feeling that you'll be dropping this bad boy very soon
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
monkiboy534.50 |
06-11-2017, 03:58 PM | #132 |
Rep 1,011
437m, f30, rims, wheels |
