12-13-2017, 02:37 AM | #1 |
Rep 922
Time limit on tyres?
Especially with the xdrive models, a lot of people are getting an easy 15-20k miles out of their tyres.
If someone does 20k miles a year, that's only taken one year. If someone does only 5k a year that's going to take 4 years. Is there a limit to the effectiveness of the rubber compounds in the tyres as far as time goes? Will the rubber be less effective after a given time?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
12-13-2017, 02:41 AM | #2 |
Rep 594
There is a date stamp on the sidewall that shows the week and year it was manufactured. I believe the recommendation is to replace these every 5-7 years, although I never have in the past and I doubt many do.
12-13-2017, 03:04 AM | #3 |
Rep 709
Old tyres become less supple and you will start to see cracks appearing between the treads especially at the edges, which obviously reduces their strength.
12-13-2017, 03:08 AM | #4 | |
Rep 15,858
Rubber compounds can work harden through heat cycles, one reason why grip becomes less as tyres wear down. I suppose the driver who has tyres on for years may suffer that more, than the user who drives decent mileage each day. |
12-13-2017, 03:25 AM | #5 |
Rep 922
Is that time then widely recognised as being around 5-7 years?
12-13-2017, 03:28 AM | #6 |
Rep 3,066
6 years is the recommendation I believe.
They do degrade quiet significantly over that period. Example is in laws front wheel drive KA - rear tyres have about 6mm tread but they've been on the car that long the walls are perished & the rubber is rock hard, no real grip. Also as it sits around for quite a long while between drives, they have flat spots which you can feel on a smooth road. Tried telling them to change the tyres, but the answer is 'well there's lots of tread so they are fine' !! |
12-13-2017, 03:57 AM | #8 |
Rep 922
I wasn't necessarily looking at it from the legal aspect of it all. More from the "how well is this tyre working to the design that it was built for" angle.
12-13-2017, 04:01 AM | #9 | |
Rep 32,881
12-13-2017, 04:16 AM | #10 | |
Rep 6,944
As stated, how they have been stored and used will make a large difference. I assume that a tyre stored properly in a warehouse and not exposed to UV will still have a lot of life in it even if first fitted at 5 years old. |
12-13-2017, 05:01 AM | #11 |
Rep 1,705
It all depends on how they are treated, tyre pressures, weather etc.
I have never had tyres that have deteriorated before the tread has worn out but my wife's Hankook tyres started cracking after 3 years and 15000 miles which is poor. For storage of tyres they recommend bagging them to stop the oils in the tyre drying out. So some last a very long time and others not very long....but I would expect them to last more than 3 years. |
12-13-2017, 05:06 AM | #12 |
Rep 922
Thanks for the info guys.
12-13-2017, 11:31 AM | #13 |
Rep 142
What about Winter Tyres ?
I've long been asking the same question about winter tyres. A friend of mine who lives in Northern Italy says that winter tyres are fantastic in the first year, OK in year 2, and useless in year 3 (due to deterioration of the compounds, I guess). I have failed to find any other source to confirm this view. Mine are now starting their fourth winter and they seem fine (they've probably only done about 7,000 miles, and they've been stored indoors at 20psi during the summer). Perhaps he is referring to worn tyres, not just old ones.
Anyone heard of this issue with winters ? |
12-13-2017, 01:25 PM | #14 |
Rep 3,432
There is a recommendation about age of tyres in the manual for the car, together with advice on how to read the date stamp on the side of the tyre...
Mine (from the Driver's Guide app) says "Irrespective of wear, change tyres after 6 years at the latest."
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
12-13-2017, 07:14 PM | #16 |
Rep 725
This thread reminded me of this. Only 5k on the tyres but the age had a big part to play.
I could never understand the guy had enough money for a Carrera GT but left old and perished tyres on it. Sad story. https://www.carthrottle.com/post/pau...en-it-crashed/ |
12-14-2017, 07:17 AM | #18 | |
Rep 15,858
It is one reason when users swap to a different brand and say "the new ones are softer riding". Some of the difference is in the hardening over time/mileage. |
