10-19-2017, 12:57 PM | #25 | |
Rep 7,000
No idea how to do it but someone in the US forum must surely know |
10-20-2017, 09:46 AM | #26 | ||
Rep 710
10-20-2017, 02:31 PM | #28 |
Rep 7,032
Drives: 335xd Msport +
Easily do able via Bimmercode. Easy way to find out/ discover more is to download the app for free and have a play in demo mode. It works in a theoretical car and gives an idea of what’s where and what is possible.
Don’t need an OBD reader Fem unit Lighting Angel eye brightness Ps Looks like it is 12% as standard.
Soul_Glo13347.00 |
10-20-2017, 02:32 PM | #29 |
Rep 7,000
10-20-2017, 02:34 PM | #30 | |
Rep 7,000
In the UK they are full brightness as standard You should be able to code from US to Euro standard |
10-20-2017, 02:37 PM | #31 | |
Rep 710
10-21-2017, 11:18 AM | #32 |
Rep 710
So iv just coded the car to my needs and I must say what an easy process it is. I know people will say you can do it for free if you've got the right software etc but I looked at one of the how to guides and it scared me to death thinking I would brick my car. I used the bimmercode app and the vgate 2 obd reader which was £17 from amazon and £25 for the app. Many thanks to JLR1969 for bringing it to our attention and his recommendation too. Just a side note if you have car play, you need to turn it off on the idrive otherwise it will not connect at all. Also I was searching in Bluetooth but it turns out it's connected via wifi and so does CarPlay interestingly, that's why you need to turn it off as it's the dominant signal.
JLR19691882.00 |
10-21-2017, 11:19 AM | #33 | |
Rep 710
JLR19691882.00 SportySpice204.00 |
10-21-2017, 12:22 PM | #35 | |
Rep 7,000
It works with iOS |
10-23-2017, 12:59 PM | #37 |
Rep 7,000
10-30-2017, 06:20 AM | #38 |
Rep 100
Back to the ops observations I also coded using bimmercode. If you adjust the drl brightness when lights are on it does max up the brightness of the DRLs also when in drl mode. I changed setting to 70% with lights on and when lights were off they were very bright. Restored details and drl lights were dimmer. So now set drl to 80% and lights to 70% when on. It's still brighter than default. Maybe default drl are 70% rather than the 100% stated?
10-30-2017, 06:35 AM | #39 | |
Rep 7,000
I have it all on 100% |
10-30-2017, 06:45 AM | #41 |
Rep 7,000
10-30-2017, 06:47 AM | #42 |
Rep 1,858
I can't understand why one would want to code the halo angel eye DRL to be brighter when the headlights are on.
The LED angel eye DRL are bright, but unfocused and cast a light visible free a wide angle, which is fine in daylight, but the purpose of dimming the DRL when the headlights are on is to reduce the glare given off by the very bright, unfocused DRL. The headlights are much brighter and shielded to mini the glare issue to oncoming cars and bye increasing the DRL brightness when headlights are on for vanity reasons, first of all doesn't increase your headlight throw (as the DRL light is diffuse and not focused) and significantly adds to glare to oncoming cars. I'd refer to the https://www.gov.uk/government/public...running-lights which says "DRL are necessarily bright to ensure they are visible in the daytime but not so bright that they will dazzle others. However they are too bright for night time use and are not intended to illuminate the road in the dark. If used at night they will cause dazzle and discomfort to others and so drivers should always switch to their position lamps or headlamps at night." And "DRL may be combined with other lamps. For example some manufacturers use the same lamp for both the DRL and position lamp. In these cases the DRL automatically dims to function as a lower intensity position lamp when the headlamps are turned on. DRL placed close to direction indicators may also automatically dim when the direction indicator is active. This is to ensure that the direction indicator is not masked by the light from the DRL." So there are clearly legal ramifications if you alter the brightness characteristics of your DRL and are involved in an accident |
10-30-2017, 07:17 AM | #43 | |
Rep 5,776
10-30-2017, 07:18 AM | #44 | |
Rep 7,000
