View Poll Results: Does your b58 consume coolant? | |||
Yes | 140 | 62.50% | |
No | 84 | 37.50% | |
Voters: 224. You may not vote on this poll |
11-21-2016, 02:00 PM | #23 |
Member
457
Rep 1,517
Just checked today, 4000 miles and the main tank is at the minnmium mark. Inter cooler tank is full.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
03-06-2017, 07:57 PM | #24 |
Rep 231
I had a low coolant light around 3000 miles, with some evidence of coolant leaking around the cap. May have been high pressure due to low coolant? The dealer topped it off and gave me some extra coolant to take home and top it off after the engine cooled down...yes it's lower when cooler. I do have to top it off every 1000 miles or so, but check it regularly now before the light come on.
03-29-2017, 08:41 AM | #25 |
Member
457
Rep 1,517
Seems like in 3 months I've dropped significantly below the minimum line. 9 Months ago it was at max. Is the normal rate or should I get this checked out?
Also, is filling with distilled water recommend?
03-29-2017, 09:49 AM | #28 |
Rep 703
I would get it checked
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
03-29-2017, 02:51 PM | #29 |
Captain Crunch
168
Rep 548
Had low coolant warning in October 2016 ~4k miles, the secondary tank was dry. Dealership filled it up with no questions and I went on my way. No problems since.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
03-30-2017, 11:49 AM | #30 |
Rep 2,825
people, dont forget to check your coolant levels when the car is cold so you get an accurate reading.
everyone keeps saying that the coolant system is a closed loop and that coolant consumption is not normal, but it is so common with BMW's especially if driven aggressively to the point where i see topping up my coolant and checking it occasionally as normal. what gives? |
03-30-2017, 11:51 AM | #31 | |
Rep 5,983
03-30-2017, 11:54 AM | #32 | |
Rep 2,825
I'm almost certain its just being burned through the engine because it happens faster when you drive aggressively, but many people keep telling me this is not possible. I know for certain there are no leaks though and this is also happening with other cars owned by friends/family like an Acura and Mazda. they are new cars, no chance of those leaking either and we checked. |
03-30-2017, 12:25 PM | #33 |
Rep 5,983
I'm not sure how it would be burned through the engine as it doesn't go into the combustion chamber unless it's leaking into the oil or the engine itself. That would not be normal and would be a serious problem. Much of the coolant is water and it would have to be going somewhere, it can't technically be burned I would think. It remains a mystery as there aren't any leaks.
03-30-2017, 12:42 PM | #35 |
Cheapskate
4442
Rep 4,992
there are a few threads on this already.
http://f30.bimmerpost.com/forums/sho....php?t=1343545 http://f30.bimmerpost.com/forums/sho....php?t=1349796 http://www.2addicts.com/forums/showthread.php?t=1331686 seems like some people are replacing the cap to fix it. |
insanecoder1410.00 |
03-30-2017, 01:38 PM | #37 |
Rep 775
Grab an oil sample and send it to the lab. That's the best way to know if collant is making it into the engine. I'd do it sooner rather than later. Sure maybe they need to 'burp' the system, yet for ~$30 you can get an analysis to be sure.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
03-30-2017, 01:39 PM | #38 | |
Rep 5,983
kern4174442.00 |
03-30-2017, 02:57 PM | #39 | ||
Cheapskate
4442
Rep 4,992
03-30-2017, 03:00 PM | #40 |
Cheapskate
4442
Rep 4,992
correct. personally i wouldn't play with the percentage. most coolant concentrate bottles will tell you the max and min ratios as well as the boiling/freezing points for each combination. usually it's between 40%-60% mix, otherwise you risk freezing the system in the winter or boiling it in the summer.
03-30-2017, 03:06 PM | #41 | |
Rep 5,983
03-30-2017, 03:07 PM | #42 |
Rep 5,983
03-31-2017, 07:56 AM | #43 |
Rep 703
As I've said before those that had there coolant drop low once and then refilled is not an indication of a problem as the bmw dealers here in Germany are telling me that due to the design of our systems it may not get filled all the way from from the factory and may need a top off after some miles have been driven.
03-31-2017, 08:36 AM | #44 | |
Cheapskate
4442
Rep 4,992
