03-13-2015, 03:22 AM | #2 |
Rep 5,140
F30 xDrive with M Sport has staggered wheels as factory options:
Style 400: F: 8x18" ET34, 225/45-18 R: 8.5x18" ET47, 255/40-18 or Style 403: F: 8x19" ET36, 225/40-19 R: 8.5x19" ET47, 255/35-19 |
03-29-2015, 01:46 AM | #4 |
Rep 749
Drives: 2016 528i Executive Edition
My stock rims on 335xi is:
20" x 8" fronts - tires 225/35/R20 20" x 8.5" rears - tires 255/30/R20 |
03-29-2015, 09:18 AM | #5 |
Rep 410
Drives: One car with good steering ;)
Yup, BMW claims the front and rear tire diameters should only differ by ~1% at the most to avoid damage to the xDrive system. The tires should also differ by 3% diameter compared to the original wheels at the most.
CPT Smuggs98.00 |
03-29-2015, 09:23 AM | #6 |
Rep 3,947
For an xDrive vehicle, I think you're better off going with a square setup. It's more practical and probably has more tire options (as a set).
04-30-2015, 08:56 PM | #7 |
Rep 22
F30 XDRIVE planning to run 235/35/19 front and 265/30/19 rear. Will I be okay with the rolling diameter? I'm having a hard time understand how to use the calculator. If not, what would be a good recommended tire size on a 19" rim?
04-30-2015, 09:36 PM | #8 |
Rep 1,490
I ran this for a while, car seemed okay functionality wise. But definitely a lot more understeer, the tires are a little short for the F30, no rotation, and the car follows crowns in the road much more.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
04-30-2015, 09:47 PM | #9 | |
Rep 22
What tire setup is yours now? I had these installed today and it seems a little jerky at about 15-20mph and again at about 40ish. Traction control light occasionally comes on- now I'm beginning to doubt my tire size selection. |
04-30-2015, 09:58 PM | #10 | |
Rep 1,490
I never experienced any lights out of the ordinary. My old setup was 235/35/19 F on 19x8.5 and 265/30/19 R on 19x9.5 My current setup is square tires (245/40/19) on lightweight square rims (19x8.5). Car feels very neutral, much more responsive/nimble, and doesn't follow road imperfections like it used to.
04-30-2015, 10:48 PM | #11 | |
Rep 22
Yeah that's good to know. Shouldn't be the transfer case, I didn't have any issues in the past. Like you said, I get slight jerkiness, but I haven't really driven it enough to really get a good feeling for it. (Maybe about 15 miles so far) Like I mentioned that rolling distance calculator I'm having trouble with understand (does offset really matter?) and what not. Really trying to see if my rolling distance it correct within 1% as I'm Not trying to damage the xDrive system of I'm out of the parameters. I'd rather cough up the extra few bills for new tires rather than a few grand down the road for major repairs. |
05-01-2015, 08:01 AM | #12 | |
Rep 1,490
BMW sells 225/40 and 255/35 on certain tire/rim packages even on the xdrives. That may be another option if you want to stick with staggered. I think that may be like a 0.25 or 0.5% difference. Alternatively, depending on your wheel widths, might be able to get square tires on all 4 of them, even though you wouldn't be able to rotate them, you would maintain the same rolling diameter.
05-01-2015, 08:29 AM | #13 | |
Rep 1,900
Past: 1999 M3 2003 M5 2006 330i 2007 335i 2009 M3 2013 M3 2018 M3
05-01-2015, 08:48 AM | #14 | |
Rep 1,490
I would get the 8.5s, add spacers as you see fit. My fronts are pretty flush, I am trying to add spacers to the rear to get a little flush/poke. Or maybe 19x9".
05-01-2015, 09:02 AM | #15 | |
Rep 1,900
I meant 19x8.5 ET 35 w/ 235/35 and 19x9.5 ET 43 w/ 265/30.
05-01-2015, 09:10 AM | #16 | |
Rep 1,490
If not, than those tires are quite short for the F3x chassis. I'd go for 225/40 and 255/35 which is an oem fit that BMW specs out I believe.
05-01-2015, 09:26 AM | #17 |
Rep 1,900
Planning on doing Dinan Springs. And those are the OEM tire sizes. Maybe I should go with those. I was worried the 255 on the 9.5 would be stretched?
05-01-2015, 06:57 PM | #18 | |
Rep 22
My two cents. |
05-01-2015, 07:08 PM | #19 | |
Rep 22
Say 235/35/19 front and 265/35/19 rear? How does a wider rim affect the xDrive system? |
05-02-2015, 07:19 AM | #20 |
Rep 132
Always been debating this topic myself when I brought wheels for my x-drive car. Ended up going with a square set up 20x9 all around 245/35/20 I believe
Someone told me that the difference between rim needs to be .5 or less and heard a few bad stories about straggered on x-drive so made the decision to play it safe. |
05-02-2015, 07:59 AM | #21 | ||
Rep 1,900
However, maybe 245/40/19 or 245/35/19 square might be more practical and neutral.
05-02-2015, 01:33 PM | #22 | |
Rep 335
You can see how this works with any tire calculator: http://www.e90post.com/forums/forumdisplay.php?f=12 |
