02-23-2016, 02:58 PM | #67 | |
Rep 3,946
And what were the dimensions + offset of your wheels? Last edited by Polo08816; 02-23-2016 at 03:04 PM.. |
02-24-2016, 03:05 PM | #68 | |
Rep 766
doesnt surprise me at all. The stock wheel diameters hover around 26". 225/45/18 = 25.97" 255/40/18 = 26.03" 225/40/19 = 26.09" 255/35/19 = 26.03" these all fit with no issues on the front. Earlier in the thread somone posted they fit a 255/30/20 = 26.02" with no issues. your fitment: 245/35/20 = 26.75" Its not just widths and offsets but also aspect ratio and overall wheel diameter. If the wheel is tall the likelihood of rubbing is obviously there.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
02-24-2016, 03:18 PM | #69 | |
Rep 3,946
MickAv8r is your front suspension stock? (xDrive or RWD)? |
03-01-2016, 08:06 AM | #70 |
Rep 3,946
It seems like 255/40/18 with 18x8.5 ET35 will clear. What about the same setup with the exception of the offset:
255/40/18 with 18x8.5 ET38 Basically, instead of Apex EC-7 in favor of Apex ARC-8? I'm hoping the margin of error on the setups tested above isn't just 3mm. |
03-01-2016, 08:16 AM | #71 | |
Rep 338
03-01-2016, 08:26 AM | #72 | ||
Rep 3,946
Let me shoot APEX an email to verify. Quote:
03-01-2016, 08:37 AM | #73 |
Rep 338
03-01-2016, 08:44 AM | #74 | |
Rep 3,946
In 2012, the M Sport Brake option was basically a blue-painted caliper. I know for a fact that in 2014, it's different. It uses a larger rotor 370x30mm instead of 340x30mm and both front and rear calipers were upgraded. The only difference between the M Sport Brake Option and the M Performance Brake kit is the rotors: blanks vs. slotted. Also, there are 3 variations of the Michelin Pilot Super Sport 255/40/18 tires. They all have the same sectional width of 10.2" but they have different tread widths: 8.5" 9.2" 9.5" I'll probably end up going with the 9.2" just for a measure of safety. The 8.5" is really narrow at the tread for a 255 tire. It's just as narrow as my 235/45/18 Michelin X-Ice Xi3 that I have on the front. |
03-01-2016, 08:46 AM | #75 | |
Rep 338
03-01-2016, 08:56 AM | #77 | ||
Rep 3,946
Someone is running an 18x9 ET42 with a 5mm spacer and 265/35/18 tires. That setup is approximately 5mm closer to the inner strut than my hypothetical setup. Short story: it's a tight fit (for the brakes). Last edited by Polo08816; 03-01-2016 at 09:04 AM.. |
03-02-2016, 08:32 PM | #78 |
Rep 3,946
I ordered my APEX ARC-8 18x8.5" ET38 and Michelin 255/40/18 with the 9.2" tread width - square setup.
It'll probably take about 2 weeks before I receive it and get it mounted. I'll post some pics when it's done. |
03-05-2016, 02:03 AM | #80 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
It all depends on your offset and wheel width. I ran 245's on my 20x9.5 +35, im lowered so much that it rubs when i hit a bump but its nothing terrible. A 255 wouldnt fit though because it hits the strut.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
03-07-2016, 08:42 AM | #81 |
Rep 3,946
I'm thinking the wheel width and offset is the issue and not the tire width (245 vs. 255)...
03-09-2016, 03:32 AM | #82 | |
Infidel
122
Rep 1,102
edit: I´m on stock height with the M Adaptive. Tires are MPSS
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
03-09-2016, 04:20 AM | #83 | |
Rep 3,946
MPSS in 245/35/18 are 26.8" tall. The height is probably what is causing the rub. Stock height is 26.0". |
03-09-2016, 04:22 AM | #84 |
Infidel
122
Rep 1,102
ET35. Yes, the correct profile should be 245/30 for the 20". But I wanted some cushion for the tush
03-10-2016, 11:50 AM | #85 |
Rep 3,946
Mounted and balanced by BMW of Annapolis...(Square setup)
APEX ARC-8 18x8.5 ET38 (Finish: Anthracite) Michelin Pilot Super Sport 255/40/18 It fits. No rubbing. Last edited by Polo08816; 03-10-2016 at 12:34 PM.. |
03-11-2016, 08:41 AM | #87 | |
Rep 3,946
My guess is that a 255/40/19 would be way too tall. The total diameter is 27.1". OE diameter is 26.0". The limit that comes up is about a 26.6" (245/45/18) and no further. 255/40/19 is both wider AND taller. |
03-11-2016, 08:46 AM | #88 | |
Rep 184
