12-05-2013, 12:27 PM | #23 |
Rep 152
I see. It may not be necessary to replace the GWS but what's the benefit of replacing it? None?
12-05-2013, 01:07 PM | #24 |
Rep 40,763
That would depend on whether it is different or not, and as I wrote, for F30, I don't know if it is different or not.
12-10-2013, 09:02 PM | #26 | |
Rep 40,763
F3x has it's own SAT Gear Shift though, so why would you want one from an F10? .
12-11-2013, 05:29 AM | #28 |
Rep 40,763
Throw it back up on ebay, it will sell.
01-18-2014, 12:56 PM | #29 |
Rep 376
I added the SAT to my car and it is a pretty significant difference, especially in manual mode. I am still in the process of adding in Launch control. In order to get it to work, I upgrade the I-step level on the EGS ecu which was a pretty scary experience. The option is now available for FA coding, and I added it. I just drove a few miles (instructions said it had to be warm) and couldn't get it to come up. I realized I forgot to recode in the SAT when I updated the ecu so I just did that and will try it again next time I drive in the chance that SAT is required for it to work.
01-18-2014, 03:12 PM | #30 | |
Rep 1,573
i did ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv ICM/IcmKod_B_S2TBA -> verbaut and got a Chassis stabilization error, althought it went away when i restarted the car. I dont feel a difference in the shifts
2015i Cadillac Escalade ESV
01-18-2014, 05:46 PM | #32 | |
Rep 40
You did everything right . When you put your shifter to DS - do you see S1 indication on dash board ? This is how it supposed to look (flag is LC) Last edited by Timur; 01-18-2014 at 05:56 PM.. |
01-18-2014, 05:48 PM | #33 | |
Rep 40
Some people say that they were able to code launch control and sport tranny, but I have not seen it personally. Try it out. |
01-18-2014, 06:29 PM | #34 |
Rep 1,573
no i did not see any gear numbers in DS. I wonder if theres a difference between the US and Russian versions
01-18-2014, 06:31 PM | #35 |
Rep 1,892
01-18-2014, 07:27 PM | #36 |
Rep 1,573
I just double checked and it seems that i forgot to set Sportschalter to active, only Sportschalter_alt was
i just did it now, ill be going out in a little bit and ill test to see if it works
01-18-2014, 10:22 PM | #37 |
Rep 376
I just tested mine! I went from the no-line with only sport mode to now having sport+, sport automatic transmission, and now launch control !!!!
Coding is awesome!! I love launch control!! |
01-18-2014, 10:27 PM | #38 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
Just quick question.
For the people who coded SAT, did you guys also buy the SAT Gear shift or just code those values? |
01-18-2014, 10:29 PM | #39 |
Rep 376
01-18-2014, 10:35 PM | #40 | |
Rep 987
Makes me want to code in the SAT. Don't know why the 12-13 MY 328s didn't get the 2TB option but gets it in 14 for Canadian models. *Should have also asked my advisor if they could order the Sport Steering Wheel with Paddles instead of the same replacement since I'm getting the wheel replaced under warranty anyways* Does the transmission shift any better in just the normal Comfort/Sport modes? |
01-19-2014, 02:39 AM | #41 | |
Rep 40
You can also buy yourself a new steering wheel with shifters, and sell yours. If you code stated above values shifters gonna work You can also retrofit shifters to the sport steering wheel (some cuttings will be required) |
01-19-2014, 09:47 AM | #42 |
Rep 1,573
so after recoding Sportschalter to aktiv, i can confirm I have SAT and it works.
I notice it more on the 1-2-3 shifts...not so much in the higher gears. never the less its cool and I see what gears I am in in DS mode
01-19-2014, 12:10 PM | #43 |
Rep 40
01-19-2014, 12:28 PM | #44 |
Rep 152
How does launch control work?
What I usually do is turn DSC fully off, hold brake, press the throttle pedal and release brake pedal. Is it any better than "my launch control"? |
