11-19-2014, 08:59 AM | #1 |
Rep 10
tire size with 20x10 et35 and H&R SuperSports
Curious what size tires you guys with H&R Super Sport springs are running that are also running a 20x10 in rear with ET-35 offset. I know that a 255/30 will fit, however i'd like to go wider if possible, without rubbing. Is the 275/30 going to be too wide for my setup? Any help is appreciated. Thanks!
EUROPROJEKTZ Northwest Chapter
1997 Audi A4-Showcar/Racecar 2014 BMW 335i M Sport-Daily Driver |
12-10-2014, 03:17 PM | #3 |
Rep 10
would a 275/30 clear? or is this not a common size to run on an et35 20x10?
Reason I ask is because I currently have 255/30 in the rear and with the minor stretch I am having issues with leaks at the bead of the wheel on one of the wheels. I bought the wheels used, and have yet to determine if its a wheel issue or a tire issue. I sent the wheels off to a wheel repair place and they said they are not bent, so i'm unsure as to the issue now. I may try swapping tires from wheel to wheel to see if the leak follows the wheel or the tire. I just wanted to be prepared to potentially step up in size if i need to and if it will even work.
12-10-2014, 05:24 PM | #4 | |
Rep 34,176
As mentioned above, 265/30 is the size you would ideally want to run. You would most likely have to roll your fenders a tad bit in order to run 275's with that offset.
Have questions? Contact us below bmw@vibemotorsports.com. 800-814-8423 Ext 107 Ask for Tom https://www.vibemotorsports.com/wheels |
12-11-2014, 11:54 AM | #5 | |
Now in the dark side !
65
Rep 1,136
Not sure. As for tires, since your offset is very aggressive, you won't be able to run 275 in the back, and maybe not even 265 (depending on the tire manufacturer).
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
12-11-2014, 12:13 PM | #6 | |
Rep 34,176
You're also right about 265's as it does depend on the manufacturer. Something like Pilot Super Sports you might have a difficult time fitting, although with some negative camber I think you should be able to pull it off as I've seen very similar setups on members' cars. It will be close though. A picture with your current clearance would definitely help assess the situation.
