BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Juice box on AH3?
      05-14-2016, 11:32 PM   #45
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Originally Posted by RLSinCO View Post
I've added the JB4Stage 2 tune to my AH3.
It works flawlessly, I'm using Map1 as I have no other modifications.
Originally Posted by Boosted John View Post
I have a JB4 sitting in my office. I am just afraid to install it. I'm hoping someone does it first..lol...
Originally Posted by franzzz View Post
Ordered JB stage 1 for my AH3
Stay tuned for review, pics and performance analysis
What model JB4?
Also, franzzz did you ever post pics, review and performance analysis?
      05-16-2016, 05:16 AM   #46
franzzz
franzzz's Avatar
Italy
53
Drives: 335i ActiveHybrid
You find video on this thread.
In the same road :
0-60mph stock : 5.3 secs via mlaptimer
0-60mph tuned : 5.0 secs via mlaptimer
BMW F30 Hybrid 370cv TMC - B40 - step8M S - Navi -Performance Brake - USB-DivX-DVD-TV - Btooth - VoiceControl - Connect - App - Online - TrafficInfo - SpLimInfo - VenetoBeige - PDC - Cam - LedFog - Roof - Antitheft - Servotronic - AdaptiveM - GarageDoorOpen - K&N - Ragazzon Exhaust
      05-17-2016, 07:10 PM   #47
afranke
Drives: 2013 ActiveHybrid 3
I put the Stage 2 on my AH3 after installing the Dinan CF intake, ran Map 2 after getting comfortable on Map 1, and blew my charge pipe. Luckily, I was close to home and drove home under electric power (whoo!) with no problem. I got an ER charge pipe, which is sweet, put it back on Map 2 for a bit and no problem. I added the Meisterschaft mid-pipe back and changed to Map 5 and have had 0 issues (aside from traction) since.
      05-19-2016, 09:51 AM   #48
franzzz
franzzz's Avatar
Italy
53
oh my god
      05-19-2016, 12:33 PM   #49
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Charge pipe is a must with map 2 or higher power
      07-09-2016, 12:51 PM   #50
frackje
frackje's Avatar
Belgium
30
Drives: AH3
This is my AH3 With Burgertuning JB
0-180km/h 12sec
Hmmmmm on my acceleration video I timed 11s from 0-170 (stock). So I'm not sure if the BMS Stage 1 is worth it for the AH3.
Have you made a new video with the new mods?
      07-11-2016, 03:25 AM   #51
franzzz
franzzz's Avatar
Italy
53
This is stock AH3
0-180 14 sec
In your test the road is not FLAT.......
      07-11-2016, 04:43 AM   #52
franzzz
franzzz's Avatar
Italy
53
1700Kg weight
19" Wheels
Stage 1 with around 380Cv
      07-11-2016, 04:44 AM   #53
franzzz
franzzz's Avatar
Italy
53
Without Stage1 0-100Km/h max 5.2 sec
      07-11-2016, 07:52 AM   #54
frackje
frackje's Avatar
Belgium
30
Drives: AH3
This is stock AH3
0-180 14 sec
This one is doing 12 from 0-160.
Mine is doing 11. Road was flat for sure. Will make a new one in daylight soon
Wish there was M Laptimer for Android :/
      07-11-2016, 09:34 AM   #55
franzzz
franzzz's Avatar
Italy
53
Without laptimer is not possible to see real performance of your car
Ah just for info :
http://www.br-performance.be/en-be/c...active-hybrid/
http://www.talus.at/tuning_bmw_3er_f30_31.html
https://www.facebook.com/Autowerksba...36421869848369
      10-22-2016, 09:31 PM   #56
Kabrich
Originally Posted by stonefocus View Post
Everytime I install JB4 on my AH3, check engine light come up. And it goes away in 3 days. When I uninstall it, same.
+ One day, drive malfunction happened. Car just lost all the power, and it does not want to go over 30 mph. I parked my car, called BMW road assistant for towing and planned to directly go ahead to dealership for service. While I am waiting, I uninstalled JB4, restarted and car works fine.
It just scared me. Probably I will sell JB4 for now.
After 3 days, my car was serviced by BMW. They said they had to replace fuel pump. Covered by warranty fortunately.
A number of AH3 owners have had fuel pump failures, so not the JB4.
      10-24-2016, 05:04 AM   #57
franzzz
franzzz's Avatar
Italy
53
Low pressure pump or high pressure pump ?
      10-24-2016, 09:53 PM   #58
Kabrich
Technically it a sensor on the low pressure fuel pump that fails, throwing an error code that throws the car into limp mode.
BMW does not have a sensor replacement so one has to swap out the entire fuel pump due to he sensor failure.
      10-26-2016, 01:11 AM   #59
plzy86
Drives: 13 AH3 Sport
hey guys i am planing on buying JB4 ...are u guys just running jb4? or other mods too? any issues ???
thanks
      10-26-2016, 02:54 AM   #60
franzzz
franzzz's Avatar
Italy
53
A new entry :
http://f30.bimmerpost.com/forums/sho....php?t=1282052
It's good in order to switch off
      10-29-2016, 02:26 AM   #61
Lancelot
France
127
Drives: 2014 M Sport ActiveHybrid3
thanks
Hi, JB4 map 5 here with Akrapovic exhaust and BMC air filter on the intake side, no issues to report, no codes anything. I have the bluetooth extension on JB4 to monitor everything and switch maps easily ln the iphone.
      10-29-2016, 03:20 AM   #62
Kabrich
So you didn't need a new chargepipe or downpipe etc? I thought those were required with JB4 if you didn't want to blow the OEM parts and bit throw error codes?
Also, seeing yours is a 2014, do you have an EWG?
Finally, off topic, do you have the automatic Anti-Dazzle Halogen Headlights?
      10-29-2016, 03:29 AM   #63
Lancelot
France
127
JB4 allows for progressive mods, map 1 is designed for added performances on a fully stock car for instance, map 5 is auto learning and will adjust to engine parameters, probably benefitting of the exhaust/intake mods i put on. I don't plan on other engine mods for now, i've got the power I need.
Things I like about JB4 is:
- it uses all engine parameters to determine appropriate boost - gear, rpm, oil temp and more than that, protecting the engine in lower gears, or when it's cold.
- it can evolve with my future mods if any
- it's got bluetooth extension
- and a wide community of users for support
Indeed i have EWG, it's a 12/2013 production / 2014 Model Year car.
And yes I do have anti dazzle too.
      11-08-2016, 12:01 AM   #64
plzy86
how do u like the Akrapovič exhaust ? not many dealers out there ...i think there is only one in CA
      06-05-2017, 11:37 AM   #65
oRetro
Drives: '13 AH3 - fully stock
Replying to a pretty late thread here, but I can't tell if I need PWG or EWG JB4 for my '13 AH3, how do I tell(I'm pretty sure it's PWG b/c of its model year but I want to be sure before I buy)?
      06-05-2017, 12:01 PM   #66
afranke
Originally Posted by oRetro View Post
Replying to a pretty late thread here, but I can't tell if I need PWG or EWG JB4 for my 'AH3, how do I tell(I'm pretty sure it's PWG b/c of its model year but I want to be sure before I buy)?
http://files.dinancars.com/webresour...582dca6718.pdf
2013 ActiveHybrid 3 (335ih) N55 PWG Meisterschaft GT catback Wagner tuning catless DP and Stage 2 Evo Comp Intercooler ER chargepipes BMS intake io2V3 O2 simulator Pure Stage 2 turbo with high-flow inlet and DV upgrade Fuel-It Stage 2 LPFP JB4 ISO firmware Fuel-It DIY PI Kit bootmod3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
