11-18-2013, 06:29 AM | #23 |
Rep 47
Who dyno there car from.second gear? I mean seriously. I simply said when he was in fourth gear for the first couple of runs it wasn't opening the throttle. So since your so smart why wasn't I making more power in fourth then when we did the pulls in fifth gear?
11-18-2013, 09:17 AM | #24 |
Rep 1,997
With E85 in Map 7, Terry's tuner car was doing right at 370whp. Without, about 355whp in Map 2.
11-19-2013, 09:35 PM | #26 | ||
Rep 1,044
Most dynos worth their salt (dynojet included ) will detect the gear ratio and will compensate for that fact proportionally. The lead that you plug into the engine wiring allows the engine to detect this ratio. In fact assuming transmission losses are minimal at a ratio closest to 1:1, running the dyno in a gear other than at 1:1 will only slightly reduce your "dyno computed" numbers at the wheel. |
11-20-2013, 03:39 AM | #28 | |
Rep 808
11-20-2013, 09:33 AM | #30 |
Rep 1,044
When I did my dynos in 4th, 5th and 6th gears, there were no differences. I had created a thread posting the various dynos.
Btw, if you are doing dyno at 6th gear, make sure you have performance tires. My V-speed A/S tires smoked badly at 145mph |
11-20-2013, 10:32 AM | #31 | |
Rep 688
I've never heard of a "lead that you plug into the engine" that detects what gear the car is in and compensates, but I only have about 80-90 dyno pulls of experience in various cars over the last 10 years. The only information the dyno will pick up from the engine is RPM. I've also never cared to have my tuner plug in any sort of correction factors to the results, as correcting anything is inherently useless. Perhaps the variance you experienced in different gears wasn't great due to how tight the gears are spaced in the 8-speed, but there will be a difference to the upside in a lower gear. On top of torque being multiplied at a higher rate, a shorter gear doesn't allow for as much load and therefor heat. |
11-20-2013, 01:45 PM | #32 | |
Rep 1,575
Without illustrated evidence one way or another the only way we will get this settled is if NickF30 goes back to the same dyno under similar conditions and dynos in 6th gear (8AT 1:1) to compare the results....NickF30 is this possible for you? Or.... If someone else can post two dynos of their car in 5th and 6th gear (8AT 1:1) |
11-20-2013, 02:22 PM | #33 |
Rep 688
11-20-2013, 03:26 PM | #34 |
Rep 1,575
11-21-2013, 06:46 AM | #35 |
Rep 71
I'll be putting my F30 on the dyno tomorrow. Hopefully my tuner knows which gear to put the car in. I'll also ask him about the gear factor; if anyone cares..
11-21-2013, 12:37 PM | #36 |
Rep 1,575
11-21-2013, 12:41 PM | #37 |
Rep 71
11-21-2013, 12:45 PM | #38 |
Rep 1,575
11-21-2013, 02:54 PM | #40 |
Rep 71
11-21-2013, 03:20 PM | #41 | |
Rep 1,997
Edit: Time for some Mich PSS or Conti DW! (PSS suck when it's cold though, like hockey pucks, but I don't think the run flats were any better) |
11-21-2013, 08:04 PM | #43 |
Rep 688
11-21-2013, 08:05 PM | #44 |
Law Enforcer
24972
Rep 22,264
Drives: '22 Chalk Gray Porsche C2S
