BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Can someone aswer if these are the changeable type drl boards
      05-02-2024, 04:17 PM   #1
rusty_sojah
Drives: 440
About to purchase these from a fellow member and just want to confirm if this is the type where the drl board is changeable or not?
I was just reading an an m4 board where a similarish aftermarket headlight was being discussed and everyone said their type aftermarket icon lci led headlights were not changeable. Thanks
      05-02-2024, 05:33 PM   #2
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
The pictures you have posted show the aftermarket headlight without removable DRL boards, I believe. Unless the seller had taken DRL modules (each consists of heat sink and attached board to it) them out before taking the pic... Also, the actual halo rings do not look authentic. You can notice the difference if comparing to pics below.
Look at this pic below. - The aluminum ribbed shroud at the top of the headlight - that the heat sink for removable DRLs from 4 Series/M4 OEM LCI Adaptive LED headlights.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      05-02-2024, 06:12 PM   #3
rusty_sojah
Drives: 440
Roger, thanks now my search has to be to only ones that have that top shark fin heat sink it seems. i never thought finding the correct headlights would be so challenging
The last ditch effort for me presently is from MLPerformance I might have to call them since they haven't replied to my last email. Their last correspondence with me, they said my vin wasn't a match from their list, but i suspect that is because theirs are not adaptive, mine are, and therefore their list says they won't work. i replied that I would be cool with coding the adaptive part out and they haven't responded.
