02-12-2013, 05:28 PM | #2641 | |
Rep 742
Tip: disable 3D acceleration in VMware as E-Sys seems to use a lot of Java and is not compatible with the acceleration.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
02-12-2013, 05:51 PM | #2642 | |
Rep 18
02-12-2013, 06:22 PM | #2643 |
Rep 490
Here's a torrent link for all the software you'll need, but if you miss this post means you haven't read enough
http://www.f30post.com/forums/showpo...postcount=2356 |
02-12-2013, 11:38 PM | #2644 |
Rep 1,397
if i dont have combox or navi am i still able to use the white iphone cable instead of the ycable?
Im guessing without combox i cant stream bt correct? |
02-13-2013, 01:14 AM | #2645 |
Rep 490
02-13-2013, 03:51 AM | #2646 | |
Rep 89
Hoping that it washes itself out in the next few days. |
02-13-2013, 03:59 AM | #2647 |
Rep 51
Did it work previously in your car? Or did you start coding it as well?
02-13-2013, 06:00 AM | #2648 | |
Rep 89
Today the browser was working, but BMW Live let me go through the setup - even register my email - but then gave me the error. |
02-13-2013, 06:26 AM | #2649 | |
Rep 67
I am a new member and a new car owner :-) - my email id is rajesh10800@yahoo.com. It will be great if you could send me instructions on how to cose 6NH to 6NK. My car has 6NH with Professional Navigation. If you want I can share the VIN code too. Actually I want to activate many things which the local BMW delaership says is not possible. For eg, DVD Video in Motion, Seta Belt sound off, Album Art, 6NK, BMW apps (without video), Internet. Also which software version should I download, 3.18.4 with PSDZ 48.1 or 3.22.5 with 48.3. I have orderred the Enet Cable from Ebay too. Your guidance will be greatly appreciated. Regards, Rajesh |
02-13-2013, 07:38 AM | #2650 |
Rep 84
hi raj10800, this topic can be back trace from the front... For not troubling our seniors, i will answer for them that you need 3.18 and 48.1 will do.
For the connection wise, please refer to front thread. hope my explanation helps. P.S. Think twice before you convert 6NH to 6NK, may risk failure cic update from dealer. |
02-13-2013, 08:30 AM | #2651 | |
Rep 490
02-13-2013, 10:23 AM | #2652 |
2012 335i sportline every available option
Rep 15
Need help!!! Please
some help on this would be much appreciated.
I have spent about 3 hours searching this forum and reading posts and can't resolve this issue. I currently work with E-Sys v3.18.4 in combination with the v46.3 datafiles. I do a ZGW search and it finds my Vin number. when I click on connect in E-Sys there is nothing listed under target.....Therefore when i click on connection via VIN, the connect is grayed out and can't be pressed. under connection via VIN my Vin does show up. i'm guessing that I have some files in the wrong place but not sure. any help on this would be appreciated.. |
02-13-2013, 11:14 AM | #2653 | |
Rep 18
But I'm not sure if it works even on an F20/F21. Does it? Can I activate internet connection trough my phone's bluetooth tethering? |
02-13-2013, 11:54 AM | #2654 | |
Rep 1,397
02-13-2013, 12:14 PM | #2655 | |
Rep 1,105
02-13-2013, 05:22 PM | #2656 | |
Rep 39
02-13-2013, 05:41 PM | #2657 | |
Rep 40,310
02-13-2013, 05:50 PM | #2658 |
Rep 10
Thnx
I know it is required to bridge and use this setup. Virtual or not but I do not receive an ip address. My MacBook detects the cable but I don't get an IP address assigned. So this could mean dhcp is broken somehow. So I am wondering to configure this static. I think the ip setup will be the same for each car just as brand new router has a default ip configuration. Grtz, Ray |
02-13-2013, 05:51 PM | #2659 | |
Rep 40,310
I also already explained exactly what you need to do to change from 6NH to 6NK here: http://www.f30post.com/forums/showpo...postcount=2627 Go to Post 1 here, and read the 3 Getting Started Guides, and FDL Coding and VO Modification will make more sense to you: http://www.f30post.com/forums/showpo...71&postcount=1 After your VO is modified and activated, to VO code your Head Unit and Combox if you have one, simply highlight the ECU in your SVT, right click on it, and select CODE. Fair warning. Whatever you do, don't ever mistakenly click on the Code Defaults button, or you will regret it.
02-13-2013, 05:54 PM | #2660 | |
Rep 40,310
Regardless, the car does not have a DHCP server; so it does not assign an IP Address to the computer. Both the computer and the car will go into DHCP fallback mode, each assigning themselves a random Class-B IP Address so that they can talk to each other. This can take up to 60 seconds, so you have to wait until the PC has an IP address before you try to connect.
02-13-2013, 06:13 PM | #2661 | ||
Rep 10
Going to set it up once more from scratch. Back to square one ! Grtz, Ray |
