BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > NEW RELEASE: DINANTRONICS Sport (N20/N26)
proTUNING Freaks
      12-02-2016, 08:42 AM   #221
Phil2thejay
EBII F30 N26 M-Sport
Phil2thejay's Avatar
Drives: F30 N26 M-Sport
Originally Posted by Phil2thejay View Post
Car went limp mode mid drive through back roads running sport setting (in comfort mode, casual driving). Loss of traction and power to the pedal/throttle response. Almost wanted to get towed but I took a guess at it being a tune issue. Unplugged the module and car runs normal. Gonna wait till the weekend to plug it back in and hope its not a reoccuring issue or at least figure out what caused it. I will also check what code it threw when I get home.
Keep yall posted.
It has been about a little over 2 weeks since my issue occurred. I plugged it back in. I have this theory that it might have been a auto start stop issue. I forgot to mention it happened after leaving from a stop light with the auto stop mechanism on. Since, then I have had that setting turned off. Runs fine through all boost settings.
Injen | H&R | VR Speed Factory| FTP Motorsports | RW Carbon | Custom Exhaust | Custom Splitter |
Custom Tune: 264WHP and 319WTQ at 20PSI | Instagram @myboiblu328
      12-02-2016, 10:39 AM   #222
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Just ordered tuner, looking forward to checking it out.
:wave:
      12-02-2016, 10:31 PM   #223
ThexGovenor
Drives: 2015 328i xDrive, 2006 E60 M5
Mine arrives tomorrow!
      12-03-2016, 09:09 AM   #224
Fergie308
Drives: F30 328i
I put mine on a month ago with a new afe intake and h&r lowering springs at the same time and I honestly am fine/done modifying the car after all that. I didn't want to go with any other tuners because I didn't want to mess with any maps or put a downpipe on. It sounds like some people's car just turn into a hunk of shit after doing all that stuff to it. I'd suggest this to anyone that wants a little bump in power, it made my afe intake sound louder and my dv sounds different. Instead of pssshhhh it sounds like pewwww. 😂😂😂
      12-04-2016, 07:03 AM   #225
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
Originally Posted by Dinan_Engineering View Post
See website / sponsors section.
I missed it. Damn the bad luck.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      12-05-2016, 09:17 AM   #226
Dary
Dary's Avatar
Drives: F30 Imperial Blue 320i Xdrive
Theoretically there should be no performance difference between this and the BMS Stage 1?? Assuming both are running at +3PSI and same gas.
Trying to decide on which one to go with, it seems like installation and UI are the only major differences.
      12-08-2016, 08:38 AM   #227
chums
Drives: 328
So if limp mode happens you just unplug the device and the car is fine?
      12-08-2016, 12:27 PM   #228
bateau
Drives: 2013 328i Sedan
Here are dyno graphs of BMS Stage 1 vs Dinantronics Sport
CIWS654.00
      12-08-2016, 01:08 PM   #229
Dary
Dary's Avatar
Thank you!! Decisions decisions
      12-08-2016, 03:10 PM   #230
CIWS
Moon Parasite
CIWS's Avatar
Note that in the runs bateau completed he was running 92 oct gas, so wisely he ran the car with the Sport+ setting on the Dinan module. If you have access to 93 oct gas and or a good octane booster you could run it in Race mode and get even better performance.
      12-09-2016, 09:28 PM   #231
etinifni
etinifni's Avatar
Well my plans for installing tune this weekend are on hold. I have a miss and dealer tech couldn't isolate it. I don't want to throw a tune into the mix before that's figured out.
:wave:
      12-10-2016, 01:06 PM   #232
etinifni
etinifni's Avatar
Where are you guys mounting the unit after it's connected?
:wave:
      12-10-2016, 03:22 PM   #233
Fergie308
Drives: F30 328i
I zip tied mine on the charge pipe
      12-11-2016, 01:25 AM   #234
etinifni
etinifni's Avatar
From my googling it appears most people are installing this horizontally which is the exact opposite of what the instructions say:
"It is best to orient the module vertically, with the wiring pointing downward."
But the image Dinan is using kind of makes you think it is supposed to be mounted horizontally:
[IMG]http://d.pr/i/LWJJ+[/IMG]
:wave:
      12-14-2016, 04:17 PM   #235
etinifni
etinifni's Avatar
Can someone explain how this app works? Since there is no documentation I'd kind of like to know if I'm doing things correctly!
:wave:
      12-15-2016, 06:07 PM   #236
Fergie308
Drives: F30 328i
Turn the bottom button on to adjust your psi. Turn the top button on for boost gauge that doesn't work very well.
etinifni203.00
      12-15-2016, 06:24 PM   #237
etinifni
etinifni's Avatar
Yeah I figured that way how it should work but the boost gauge doesn't seem to work well like you said. Hopefully Dinan can address a couple issues with the app:
1 - How about highlighting the box around which mode you are in. (I know you can refresh to see boost level but this is kind of bush league way to check IMO.)
2 - Fix the boost gauge!
3 - Would it kill the developer to include some basic app instructions?
:wave:
      12-16-2016, 07:10 AM   #238
Fergie308
Drives: F30 328i
I always leave mine in sport+ just so the car is use to it.
      12-16-2016, 11:54 AM   #239
etinifni
etinifni's Avatar
Maybe I missed it, but if you do this will the car get the extra boost even if you're in Eco mode?
:wave:
      12-18-2016, 12:10 AM   #240
K320
Puerto Rico
131
Drives: G01-X3 30i MSport
I want to test the Dinan.
I was running RaceChip ultimate, now stock.
Readings on my toque pro app are 238hp and 248TQ.
Normal readings are 220hp and 230TQ.
Lets see if Dinan makes some changes.
      12-19-2016, 01:53 AM   #241
MidLifeX
Drives: 2016 M Sport 428i
Zip tied it under plastic cover....see pic below Made for easy removal and reinstall for service
etinifni203.00
      12-29-2016, 10:28 AM   #242
flipnkraut
flipnkraut's Avatar
Drives: 2016 BSM M3
Anyone else have issues with a dead unit? Had to ship mine back for RMA and currently waiting for a replacement.
