BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > What is the EWG HPFP fuelling limit?
      02-21-2018, 05:24 PM   #1
bradsm87
592
Drives: F25 LCI xDrive30d
I understand the cam lobe operated single piston HPFP reaches its limit at a lower output than the early model HPFP.
Does anyone have lots of near-maxing their HPFP on an EWG N55?
Is PS2 running 18psi at redline on E25 fuel with a 12.3:1 AFR too optimistic?
      02-21-2018, 06:36 PM   #2
yoandry
yoandry's Avatar
691
Drives: G80 M3CX & X5 M50i
Dont know if hpfp are different from PWG and EWG, but my pwg with ps2 + 93 will do around 8-10 hpfp values on 17psi. Anything over will crash down to 5 which is the safe fail for jb4. My afr start at 13 in low rpms and goes to 11 at the redline but Im on MHD bef also. I thing 16psi is the sweet spot for PS2 on stock fuel
So putting e25 will be worst.
      02-21-2018, 08:22 PM   #3
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Many people think early model (PWG) has a better HPFP, think again.
I know from real world experience that late model EWG HPFP is noticeably stronger. I am not talking about isolated case.
Lemania 2320
      02-21-2018, 08:31 PM   #4
obriennathaniel
obriennathaniel's Avatar
My HPFP on my PWG allowed me to run e60, hardly any other car has been capable of that.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
FSociety3810.00
      02-21-2018, 08:40 PM   #5
yoandry
yoandry's Avatar
691
On stock turbo right? Cuz on PS2 I can only do around 16 with just 93
FSociety3810.00
      02-21-2018, 08:43 PM   #6
obriennathaniel
No that was with PS2. Didn't get PI until about 7 months later. Been running full e85 ever since I got PI
      02-21-2018, 08:45 PM   #7
FSociety
IG @bmwF9xG80
FSociety's Avatar
3810
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
yoandry you should try on stock flash with JB4 and see if it lets you run more boost or more E
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-21-2018, 09:05 PM   #8
bradsm87
592
They are
Stronger in what way? I know they're more reliable but I've always heard they have a lower flow limit.
That's completely dependent on how much boost and what turbo etc. How much ethanol is only one piece to the puzzle.
Joking surely? That's a terrible idea.
      02-21-2018, 09:23 PM   #9
yoandry
yoandry's Avatar
691
@ what psi? or maybe because your afr was way leaner.
I was on stock flash with just jb4 and yes I could hit 20psi with no crash but afr running to lean, thats why, so MHD bef put it back at 12.
      02-21-2018, 09:30 PM   #10
Stanio
Bulgaria
67
Drives: F30 335 2014 Xdrive
Mine is 2014 and my HPFP was fed up with my constant pulls ..I guess.
On the drag strip I experienced couple of dead spots both in rpm and speed which resulted in a lower trap. That was later on confirmed when the the car was logged.
Fortunately the N55 community will have something soon to address the issue.
Have no clue about PS2...still on stock turbo.
      02-21-2018, 09:52 PM   #11
harkes
harkes's Avatar
China
1075
Drives: M135i, E39 M5, NSX and AE86
Short answer... 16-17psi with ~12.5 AFR on 100% petrol. My PWG car is ok at 16 - crashes at 17. Blending in ethanol = more volume = less boost for same lambda, but the gain in timing is worth it.
(A Dane in China)
FSociety3810.00
      02-21-2018, 11:26 PM   #12
bradsm87
592
Thanks. Agreed regarding a bit less boost and lots more timing with a bit of ethanol. Yeah that's about what I expected. That's fine with me. I might stick to 15% ethanol and aim for 17psi tapering to 15 at redline.
      02-21-2018, 11:37 PM   #13
FSociety
IG @bmwF9xG80
FSociety's Avatar
3810
Ah makes sense, you mean BMS BEF via MHD
Btw, did u try Race-Gas/Torco/Boostane/NOS (Octane Boosters) instead of E ?
IG: @bmwF9XG80
yoandry691.00
      02-22-2018, 08:45 AM   #14
yoandry
yoandry's Avatar
691
After ps2 installed I haven't try anything else than 93 because on my understanding, that will stress more the hpfp and make it worst.
Now, one time I get meth then I can put some e85 or race gas as the phfp will have the support from meth.
      02-23-2018, 02:04 AM   #15
obriennathaniel
21-22 psi. I could manage 24 but it was clearly dangerous. And yea I was running lean but it never caused any issues. I actually had better results and less issues running on the leaner side than richer side. But also those AFR's might not have been accurate because this was jb4 and basic tuning so the afr scaling was off due to the e content.
I'm working with CaryTheLabelGuy now on an E85 tune that will maximize the the HPFP to the best of its abilities and supplemented with PI.
yoandry691.00
FSociety3810.00
