BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 OFHG Replacment
proTUNING Freaks
      04-23-2024, 09:44 AM   #1
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
N55 OFHG Replacment
Next week my 435i goes in to have it's OFHG replaced. How much should I worry about an engine seizure afterwards? Lol.
Car has 44k miles on the clock. Thr gasket isn't leaking yet but I'm doing the mosselman T STAT so I figured I'd have it all done in one shot.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      04-23-2024, 09:57 AM   #2
NxTH
AH3 Owner
NxTH's Avatar
206
Drives: BMW 335i ActiveHybrid 3
Depends how much you trust the shop to know exactly how to do it and torque everything to spec. Mine was butchered once at first, then redone the same day because it leaked immediately. It leaked again after two months, then again after two months, and yet again after two months. I then finally took it to a specialist (should have in the first place but I had warranty on the first job) who told me the bolts weren't torqued to spec and they were coming off from vibration. Finally it looks like it's fixed and done right, but the specialist shop also noticed glitter in the oil filter and I had to redo my rod bearings. Had I driven for 500 miles, the rods would have spun. I doubt the original shop even primed anything. All this because I decided to also do the gasket before it leaked, so it was fine before all this.
Lesson learned, pay the extra in labor to someone who actually knows what they are doing.
Jvac438.00
      04-23-2024, 10:02 AM   #3
Boostedphil698
Originally Posted by NxTH View Post
Depends how much you trust the shop to know exactly how to do it and torque everything to spec. Mine was butchered once at first, then redone the same day because it leaked immediately. It leaked again after two months, then again after two months, and yet again after two months. I then finally took it to a specialist (should have in the first place) who told me the bolts weren't torqued to spec and they were coming off from vibration. Finally it looks like it's fixed and done right, but the specialist shop also noticed glitter in the oil filter and I had to redo my rod bearings. Had I driven for 500 miles, the bearings would have spun.
At the moment, the dealership will be taking care of this. They're pretty well known in my area for dropping built motors in for people. I have been there many times with my car for other things. I used to use an indy shop until they stained my new leather seat and gave me the run around, which pissed me off to no end.
NxTH205.50
      04-23-2024, 10:03 AM   #4
NxTH
AH3 Owner
NxTH's Avatar
206
I learned to avoid generic shops for things like this as well. It's fine if we're talking brakes or generic items, but anything BMW specific, always choose a specialist.
      04-23-2024, 10:06 AM   #5
Boostedphil698
Sad part was they were a BMW shop. That one instance of not owning up to a mistake just pissed me off enough to never return.
      04-23-2024, 10:50 AM   #6
visionaut
visionaut's Avatar
Drives: 2016 435iX GC & 1976 2002
Highly recommend the Viton OFHG (so you never have to change it again). DuPont Viton is superior to the OE/OE-style rubber ones.
Turner might still carry it, or look for this Premium URO part: 11427537293PRM-URP
      04-23-2024, 01:07 PM   #7
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Tape a piece of paper to the dash saying "OFHG REPLACEMENT : OIL CIRCUIT MUST BE PRIMED BEFORE RESTART".
Haha
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      04-23-2024, 01:08 PM   #8
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by visionaut View Post
Highly recommend the Viton OFHG (so you never have to change it again). DuPont Citon is superior to the OE/OE-style rubber ones.
Or ELRING (They sell both types)
      04-23-2024, 01:42 PM   #9
NxTH
AH3 Owner
NxTH's Avatar
206
Haha
The funny thing about this is that they're either go
"Why did he bring it in if he's so smart, he clearly doesn't respect us. We work on these cars for a living and know this very well."
OR
"What does that mean? Oh well." - Proceeds to not prime it or just take out a fuse and go oops.
Jvac438.00
      04-23-2024, 02:54 PM   #10
Boostedphil698
OR
They know me. I've been getting a steady 20% off from this dealer since I bought the car. I drive my car less than 3k miles a year so I don't expect to have any engine issues. This car is always up to date on its maintenance.
      04-23-2024, 09:07 PM   #11
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
I don’t trust even the dealer to do work the correctly. Had an N55 oil pan gasket changed at the dealer under warranty and got my vehicle back with oil everywhere to include a pile of oil soaked rags stuffed in the drivers side fender liner forward of the strut tower. Other issues as well. Dealers are only as good as the techs they hire and it only takes one to not prime your oil system for you to have major issues. I’ve done this job myself several times (X3 35i with N55 with 175k miles and 2014 335i with 82k). Don’t use the Elring gasket between the housing and the oil thermostat housing as I’ve had it leak when the BMW one doesn’t. Have the manifold o rings on the intake ports done at the same time you do this. I recommend you DIY so you know the priming procedure was done correctly. Get ISTA and follow along with the detailed manual.
F32Fleet3636.50
Burnout27.00
      04-24-2024, 04:56 AM   #12
Boostedphil698
Yeah unfortunately I don't have the time nor the room to DIY things. Sorry to hear your experience. I've had a few bad experiences with the one indy shop I used to go to.
      04-25-2024, 06:49 AM   #13
NxTH
AH3 Owner
NxTH's Avatar
206
LMAO. I solid jinxed myself. It literally leaked the next day AGAIN. Cue a new post..pretty sure it's the cap. I hate these cars at times so much.
      04-25-2024, 06:57 AM   #14
Boostedphil698
That definitely leaked at the cap.
      04-26-2024, 09:07 AM   #15
E36M3
I bet that isn’t the cap leaking but rather the Oil Thermostat housing to Oil Filter Housing. It’s part number 11428637820. Use the BMW one. Aftermarket gaskets have leaked both times I’ve tried them.
      04-26-2024, 09:57 AM   #16
NxTH
AH3 Owner
NxTH's Avatar
206
That has also been done in the past (like a year ago), so I'm not so sure. In the pictures, you can see drips coming straight from the cap seam. Would a leak from the thermostat housing end up only on the cap seam where it would then seap down from? I see no oil in the sandwiching area.
I made a new thread: https://f30.bimmerpost.com/forums/sh....php?t=2099930
      04-26-2024, 10:29 AM   #17
visionaut
visionaut's Avatar
Oil collecting in that little well is 100% the Oil Thermostat gasket. BTDT. If the gasket was new, I bet it wasn’t torqued proper- over tightened makes it leak.
Recommend you get a Viton gasket for that one too…
      04-26-2024, 11:10 AM   #18
NxTH
AH3 Owner
NxTH's Avatar
206
As per the thread I created (and the post above) I'm having huge doubts it's the thermostat gasket. It was first messed up by an indy, then properly done by a specialist. Granted it's the OEM gasket. In any case, when wiping the oil and going for a few drives, I saw no leaks until one random drive I saw oil visibly dripping from the cap. I'm not sure it's possible for the oil to make it's way into the cap seam from the thermo gasket and not touch anything else on the way? I'm getting multiple replies saying it's 100% the thermostat gasket and others saying it's 100% the cap. There's also no oil in the sandwiching area on the housing and no oil on the pulley below. I don't mean to hijack this thread so we should continue in my thread: https://f30.bimmerpost.com/forums/sh....php?t=2099930
