BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F32 LED fog lights
proTUNING Freaks
      04-06-2014, 02:48 PM   #23
Fazerfahrer
Fazerfahrer's Avatar
Drives: 330d touring F31, Z4 35is E89
Originally Posted by rustyminded View Post
Does it only need the LED core or just the lamp itself ?
...I'm not sure if my english is good enough to understand your wording exactly. The complete fog light need to be replaced, so I think it is what you discribed as LED core.
Regards Thorsten
Our rides: Skoda Octavia Combi RS TDI DSG / company car // E89 Z4 sDrive 35is / my summer fun toy // F31 330d touring / daily driver of my wife
      04-06-2014, 04:21 PM   #24
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
yes, your english is very good, great ! thanks
      04-07-2014, 04:44 PM   #25
sahajesh
sahajesh's Avatar
Drives: 2021 G05 X5 40i Tanzanite Blue
Got a price for the LED fogs from bmminiparts - £97 ex VAT each - guess I won't bother then!
Perhaps they are too new and not likely to have failed hence so expensive?
      04-07-2014, 04:45 PM   #26
sahajesh
sahajesh's Avatar
...yes, we did.
It is plug and play but need some coding
Where did you get them from and how much? I'm prepared to buy from a German or Dutch dealer if reasonably priced and they can perhaps order in advance?
I'd collect as over there late April.
      04-07-2014, 05:00 PM   #27
Fazerfahrer
...I ordered them at a german f30 forum dealer BMW Matthes in DE-Meiningen. We got a special offer of € 104,- each as we ordered nearly 20 sets. But normaly he also makes best quotes even if you ask for single offers.
I bought all modification there like Performance Interieur and Exterieur, PPK, Schnitzer springs, stand heating,...He also installs all these parts.
If you want to make more modifications please let me know, perhaps I can let you now know the prices for the standard parts and can arange a date to install.
Regards Thorsten
      04-08-2014, 12:55 AM   #28
sahajesh
sahajesh's Avatar
What's 'stand heating'?
I'll see what I'd like to do and perhaps have done when in Germany - thanks!
      04-08-2014, 01:48 AM   #29
Fazerfahrer
...sorry, just wrong translation with google. Looked on the Webasto page, right name should be Webasto parking heater.
Regards Thorsten
      04-08-2014, 10:31 AM   #30
simonchs
simonchs's Avatar
Hong Kong
Drives: BMW F20 LCI2 120i
I've done this retrofit and coded the following:
NSW_L_KALTUEBERWACHUNG = nicht_aktiv
NSW_L_WARMUEBERWACHUNG = nicht_aktiv
NSW_L_KURZSCHLUSS = nicht_aktiv
NSW_L_IS_LED = aktiv
NSW_R_KALTUEBERWACHUNG = nicht_aktiv
NSW_R_WARMUEBERWACHUNG = nicht_aktiv
NSW_R_KURZSCHLUSS = nicht_aktiv
NSW_R_IS_LED = aktiv
Now it won't prompt Front fog light fault, and the fog lights won't flickering during ignition on.
But when the fog light switch on for certain time, it will flickering non-stop until I turned the fog light off and on again.
Any idea?
      04-21-2014, 09:52 AM   #31
Basya
Russian Federation
Drives: F31 Touring 320d
Any idea?
I faced the same problem
      04-22-2014, 01:45 PM   #32
Basya
Russian Federation
Try this
MAPPING_NEBELSCHW_L_PWM_LEVEL_1 100%
MAPPING_NEBELSCHW_R_PWM_LEVEL_1 100%
NSW_L_DUALSP_aktiv
NSW_L_KALTUEBERWACHUNG » nicht_aktiv
NSW_L_WARMUEBERWACHUNG » nicht_aktiv
NSW_L_KURZSCHLUSS » nicht_aktiv
NSW_L_IS_LED » aktiv
NSW_R_DUALSP_aktiv
NSW_R_KALTUEBERWACHUNG » nicht_aktiv
NSW_R_WARMUEBERWACHUNG » nicht_aktiv
NSW_R_KURZSCHLUSS » nicht_aktiv
NSW_R_IS_LED » aktiv
      04-29-2014, 04:47 AM   #33
340driver
Singapore
Drives: F15 Xdrive35i Pure Experience
Originally Posted by Basya
Try this
NSW_L_DUALSP_aktiv
NSW_L_KALTUEBERWACHUNG nicht_aktiv
NSW_L_WARMUEBERWACHUNG nicht_aktiv
NSW_L_KURZSCHLUSS nicht_aktiv
NSW_L_IS_LED aktiv
NSW_R_DUALSP_aktiv
NSW_R_KALTUEBERWACHUNG nicht_aktiv
NSW_R_WARMUEBERWACHUNG nicht_aktiv
NSW_R_KURZSCHLUSS nicht_aktiv
NSW_R_IS_LED aktiv
Hi Basya,
I've just received my f32 led fogs. Am wondering if you've managed to solve the issue of flickering with the fog lamps on.
Thanks and regards
      04-30-2014, 07:01 PM   #34
hsk1610
Drives: 2013 328i xDrive
Originally Posted by Basya View Post
Try this
NSW_L_DUALSP_aktiv
NSW_R_DUALSP_aktiv
I purchased the Weisslicht fog lights and installed and coded the above, yet still get the fog light malfunction on the dash. Is this only applicable to OEM BWM LED fogs?
Nevermind, the error went away after I actually started the engine.
      05-01-2014, 12:57 AM   #35
Fazerfahrer
As far as I know you have to do following against the flickering.
FEM_BODY MAPPING_NEBELSCHW_L_PWM_LEVEL_1 13,4V 100%
FEM_BODY MAPPING_NEBELSCHW_R_PWM_LEVEL_1 13,4V 100%
Regards Thorsten
      05-19-2014, 01:38 AM   #36
340driver
Singapore
To set the power level to 100% do you edit the WERTE value directly? The only voltage options available on my car are 13.0 13.2 and 13.4. It's currently at 13.4 but only 86%
Also I noticed that after changing to LEDs and performing the coding (except for the PWM_LEVEL1) that I've lost the cornering function of the fog lights. The appropriate fogs don't come on with the indicator or when turning and also both fogs don't come on when reverse is selected. Is this expected behaviour?
Thanks for any assistance
      05-28-2014, 01:14 PM   #37
MulattoMajor
Drives: MG F30
Did you purchase the WeissLicht with the error canceler or just the bulb?
      05-28-2014, 04:29 PM   #38
hsk1610
I got the error canceler but decided not to use it because it gets so hot. I did program to turn off error checking and haven't had issues with flickering or error messages.
      05-28-2014, 04:40 PM   #39
aacabriolet
aacabriolet's Avatar
Drives: '14 435i Coupe
So has anyone sorted ALL of the possible flickering with coding?
And what did you code exactly?
Thanks
      05-28-2014, 09:51 PM   #40
hsk1610
Thanks
Please refer to post #32.
      06-03-2014, 06:52 PM   #41
MulattoMajor
Drives: MG F30
Thanks for the info.
      07-13-2014, 12:56 AM   #42
MoneyFor
MoneyFor's Avatar
Belgium
25
Have done the retrofit on my F31 a few weeks ago.
I bought them by the same dealer as Fazerfahrer, great service there and best prices ever I guess.
Did the coding myself and no flikkering at all.
      07-13-2014, 01:32 AM   #43
rustyminded
248
Drives: BMW 328i
cornering function ??! mine doesn't even work after coding it, what did you use ?!!
      07-13-2014, 01:54 AM   #44
MoneyFor
MoneyFor's Avatar
Belgium
25
I still have the cornering funktion on the leds.
