12-10-2017, 10:14 PM | #1 |
BMW forever!
1387
Rep 2,418
Best F30 suspension upgrade options
Hi All,
My car has ~38K miles and it is so wobbly and bouncy on the freeway. I got my suspension and alignment checked and all are within spec. I'm running the right pressure as well. I am thinking that its just the F30 suspension that is terrible on the freeway and as the tires wear out the ride gets worse and worse. What type options do I have? I was looking at the M Performance Suspension and Ohlins R&T. Can anyone recommend a solid setup for the F30? I like the price point of the M Performance Suspension but I'm not sure if it is too stiff. I also carry my family in the same car. I enjoy a stiff ride which is in control. I really like the M2/M3 ride. Is there a setup that resembles the M2/M3 stiffness? Maybe not as stiff but still close. The problem with the current suspension is that the car bounces up/down and side to side when it hits imperfections on the road. Thank you!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
12-11-2017, 12:21 AM | #2 |
1-800-STOCKAF
157
Rep 376
Coilovers:
Ohlins KW Street Comfort , v2 , v3 ST Coilovers (Manufactured by KW) From what I remember these are zinc coated, while the KW is stainless steel. Same thing as KW Street Comfort, built with different material. Bilstein B14, B16 Fortune Auto 500 fortune-auto.com BC Racing Br Lowering Springs: Purpose is to pretty much lower. Downside is that they damage your oem shocks and struts over time. MachtSchnell Mperformance H&R Sport & Super Sport Useful links Bilstein B14 vs BC BR series coilovers vs.... something else? http://f30.bimmerpost.com/forums/sho....php?t=1331123 Need Help: KW Street Comfort vs. KW V2 http://www.1addicts.com/forums/showthread.php?t=874491 Who is Fortune Auto?
F30 320i Stock
12-11-2017, 03:53 AM | #3 |
Rep 1,291
IIRC the M performance suspension is a Bilstein made suspension, and generally gets very good reviews.
KW - I often hear they're sitting quite low, as mine are, not incredibly low but I think 20mm lower than stock M adaptive suspension. Bilsteins seems to be the preferred choice on road cars. Ohlins get excellent reviews too, although I remember reading they're quite stiff, stiffer than KW or Bilstein from what i read
2017 M550i | Sophistograu
12-11-2017, 07:14 AM | #4 |
Rep 10,256
Very little to add to a very detailed response from @Stlthnmrdrd, other than KW Street Comfort coilovers are a very good option to explore if a reasonable budget is one of the goals. Bilstein B16 PSS10 are a great choice as well.
Stlthnmrdrd156.50 |
12-11-2017, 08:20 AM | #5 |
Rep 136
i'll just parrot what has been stated many times here...
first thing...always, always swap out the run-craps.... almost makes the car livable...i installed the b14 setup ~3wks ago... fantastic...transforms it... /story |
Stlthnmrdrd156.50 MacklinUSOB518.00 |
12-12-2017, 06:30 AM | #7 |
Rep 10,256
12-12-2017, 11:53 PM | #8 |
Rep 32
I have the 2-way adjustable KW Club Sport coilovers with built-in camber plates and really love them. I'm planning to post them for sale soon since I'm planning to sell my car.
Would you be interested in them? |
12-13-2017, 10:47 AM | #9 | |
Rep 3,622
I wish they had the MPS configured for edc too
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
12-22-2017, 08:52 AM | #10 |
Rep 162
I just installed the Bilstein B16 PSS10 Coilovers on a Sport line 340i. It's like its not the same car. I hated the orig suspension but now the car is like its on a wire going around turns and on straight aways. I did the suspension along with a M Performance LSD so that helped a lot also. To me the suspension would be first up on the list of mods.
12-23-2017, 03:39 AM | #11 | |
Rep 10,256
12-23-2017, 08:16 AM | #12 |
Rep 162
I wanted to lower the car to take out the fender gap but not to lower to the point where the wheel looked under the fender in any way. I was thinking I would have to go the min lower range spec'd on the B16's eg around 1.25" to achieve this but oddly, the installer had to go almost the full range down on the B16 adjustable range to get to the desired point. If you go by the spec sheet of the B16 then this would mean it was lowered over 2 inches. I know a bit confusing but my car was a sport line version so maybe it sat higher as a starting point then an Msport version. It sits over the tires awesome now with very little gap.
12-23-2017, 08:34 AM | #13 |
Rep 162
Here is a pic...
01-17-2018, 09:21 AM | #16 | |
Rep 8,163
01-17-2018, 03:33 PM | #18 |
Rep 8,163
Thanks. Interesting that the coilovers are at their lowest on your car, it is not even slammed at all.
Still satisfied with them?
01-17-2018, 08:09 PM | #19 |
Rep 162
Yeah that was surprising for me also thats why i posted the pic. The rears are basically at lowest settinf but front not fully yet. The bilsteins are my favorite mod. Would do again. Ps there's a reason they have been on backorder and hard to get ahold of.
MacklinUSOB518.00 |
01-17-2018, 11:28 PM | #20 |
Rep 891
Initially I was going to splurge on a set of B16's, but I saw the B14s at ECS on sale for $897.xx shipped and pulled the trigger this evening. Couldn't pass it up at that price. I'm sure the damping adjustment is satisfying and effective, but from what I hear, I should be with the 14s and a lot more dough in my pocket too.
01-18-2018, 07:26 AM | #21 |
Rep 5,457
Question: when upgrading shocks and springs... are there other items that we should be looking at swapping/upgrading "while we are in there."
The one item that comes to mind are mounts. Are most people using stock mounts with aftermarket shocks/springs? Just wondering peoples opinions on whether the stock mounts are a weak point and if they will last the life of the new suspension components. |
01-18-2018, 10:26 PM | #22 | |
Rep 162
