05-14-2016, 10:32 PM | #45 | |||
Rep 1,986
Also, franzzz did you ever post pics, review and performance analysis? Last edited by Kabrich; 05-14-2016 at 10:39 PM.. |
05-16-2016, 04:16 AM | #46 |
Rep 931
You find video on this thread.
In the same road : 0-60mph stock : 5.3 secs via mlaptimer 0-60mph tuned : 5.0 secs via mlaptimer
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
05-17-2016, 06:10 PM | #47 |
Rep 488
I put the Stage 2 on my AH3 after installing the Dinan CF intake, ran Map 2 after getting comfortable on Map 1, and blew my charge pipe. Luckily, I was close to home and drove home under electric power (whoo!) with no problem. I got an ER charge pipe, which is sweet, put it back on Map 2 for a bit and no problem. I added the Meisterschaft mid-pipe back and changed to Map 5 and have had 0 issues (aside from traction) since.
krnnerdboy190.00 |
05-19-2016, 08:51 AM | #48 |
Rep 931
oh my god
05-19-2016, 11:33 AM | #49 | |
Rep 190,631
07-09-2016, 11:51 AM | #50 |
Rep 276
07-11-2016, 02:25 AM | #51 |
Rep 931
This is stock AH3
0-180 14 sec In your test the road is not FLAT.......
07-11-2016, 03:43 AM | #52 |
Rep 931
1700Kg weight
19" Wheels Stage 1 with around 380Cv
07-11-2016, 03:44 AM | #53 |
Rep 931
Without Stage1 0-100Km/h max 5.2 sec
07-11-2016, 06:52 AM | #54 |
Rep 276
07-11-2016, 08:34 AM | #55 |
Rep 931
Without laptimer is not possible to see real performance of your car
Ah just for info : http://www.br-performance.be/en-be/c...active-hybrid/ http://www.talus.at/tuning_bmw_3er_f30_31.html https://www.facebook.com/Autowerksba...36421869848369
10-22-2016, 08:31 PM | #56 | |
Rep 1,986
10-24-2016, 04:04 AM | #57 |
Rep 931
Low pressure pump or high pressure pump ?
10-24-2016, 08:53 PM | #58 |
Rep 1,986
Technically it a sensor on the low pressure fuel pump that fails, throwing an error code that throws the car into limp mode.
BMW does not have a sensor replacement so one has to swap out the entire fuel pump due to he sensor failure. |
10-26-2016, 01:54 AM | #60 |
Rep 931
A new entry :
http://f30.bimmerpost.com/forums/sho....php?t=1282052 It's good in order to switch off
10-29-2016, 01:26 AM | #61 |
Rep 1,290
Hi, JB4 map 5 here with Akrapovic exhaust and BMC air filter on the intake side, no issues to report, no codes anything. I have the bluetooth extension on JB4 to monitor everything and switch maps easily ln the iphone.
10-29-2016, 02:20 AM | #62 | |
Rep 1,986
Also, seeing yours is a 2014, do you have an EWG? Finally, off topic, do you have the automatic Anti-Dazzle Halogen Headlights? |
10-29-2016, 02:29 AM | #63 |
Rep 1,290
JB4 allows for progressive mods, map 1 is designed for added performances on a fully stock car for instance, map 5 is auto learning and will adjust to engine parameters, probably benefitting of the exhaust/intake mods i put on. I don't plan on other engine mods for now, i've got the power I need.
Things I like about JB4 is: - it uses all engine parameters to determine appropriate boost - gear, rpm, oil temp and more than that, protecting the engine in lower gears, or when it's cold. - it can evolve with my future mods if any - it's got bluetooth extension - and a wide community of users for support Indeed i have EWG, it's a 12/2013 production / 2014 Model Year car. And yes I do have anti dazzle too. |
11-07-2016, 10:01 PM | #64 |
Rep 23
how do u like the Akrapovič exhaust ? not many dealers out there ...i think there is only one in CA
06-05-2017, 10:37 AM | #65 |
Rep 9
Replying to a pretty late thread here, but I can't tell if I need PWG or EWG JB4 for my '13 AH3, how do I tell(I'm pretty sure it's PWG b/c of its model year but I want to be sure before I buy)?
06-05-2017, 11:01 AM | #66 | |
Rep 488
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
