12-28-2017, 06:35 AM | #45 | ||
320i F30 Sportline
41
Rep 62
12-30-2017, 10:48 AM | #46 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Friend of mine did the retrofit, he also bought the ATM emulator.
After installing the ATM emulator the Navigation still did not light op, after a few tries the screen is now black, it has backlight and sound but no screen. Any help? PS. We have NOT coded the car yet. |
12-31-2017, 07:04 AM | #47 | |
320i F30 Sportline
41
Rep 62
Complete the VO coding part (Add 609 (Nav), 6NS EBT (replacing 6NH), 6NR (apps) ) - the screen should come back on... if you don't know coding, you can find someone on forums who do remote coding for a small fee.... although a black screen is unusual as without these codes, it just shows a standard 6.6" display with old CIC style options ... |
03-03-2018, 05:39 AM | #48 | |
Rep 3
Drives: BMW 320d Efficient Dynamics
Installation; running cables/wires and coding of NBT EVO High 2 (4GB)
I am new to the forum, very recently I bought an NBT EVO high 2 (4gb) version and will need your help as you did your NBT very recently. So I believe that you are one of the people who has got all the necessary experience and knowledge to help me in completing this fitting? The extra hassle that I need to face is to bring (re-run) the combox cables from boot to the back of the EVO Sat Head unit as the components present in the Combox are located in the NBT EVO Sat Nav unit itself? I believe? I have seen your message that you are willing to help with the FSC code to my chassis number? My BMW's chassis number is WBA3E12040F162290. The donor vehicle's Chassis number is WBAKS820200W24507 (this is the car who's NBT EVO will be used on my BMW? So your help on this matter is very much appreciated? I would like to thank you in advance for all the help you provide? Regards Maz |
04-21-2018, 08:00 PM | #49 |
Rep 808
I'm getting ready to do this retrofit - from reading numerous threads it's my understanding that you can either code the car OR get an emulator... So if I'm confident I can code the various parameters I do not need to buy an emulator, correct?
So basically just the HU, screen, idrive controller and video cable? I've found a listing on eBay for $600 shipped USD for everything, thinking I might bite the bullet as it seems like a good deal. |
05-14-2018, 03:40 AM | #50 | |
320i F30 Sportline
41
Rep 62
I've found a listing on eBay for $600 shipped USD for everything, thinking I might bite the bullet as it seems like a good deal.[/QUOTE]
Emulators work is not to code but to trick your car's system into believing that the NBT that you install is the stock unit. I would reach out to Shawn Sheridan who's the coding guru - if he says you can, means you really can! Good luck with the retrofit. PS: You will need a Kcan2 (think that's what it's called) control unit aka ECU for your idrive touch controller to work as the existing cable from HU to idrive won't support the touch module (which again, has to be coded to work post installation!) Cheers, AJ |
05-20-2018, 02:18 AM | #51 |
Rep 1
Which system do I have?
Hi Guys,
First post here from South Africa . I am trying to identify which unit I have in my F30. Please could you check attachments and advise? No NAV, only USB/AUX in armrest and BT phone. No BT streaming and no combox. I want to know can I upgrade to NBT or can I get the CIC navigation unit? Am I forced to change the display if I upgrade the in dash unit? Tx in advance. Last edited by andrewlaing; 05-20-2018 at 02:23 AM.. Reason: added attachments |
06-10-2018, 02:03 PM | #53 | |
Rep 24
06-17-2019, 01:45 PM | #54 |
Rep 1
Help
i have a 2013 328i f30 with NBT bus nav 6.5 inch screen. i want to upgrade to the 8.8 screen but am wondering what all i will need. if i purchase a kit off ebay with the screen, controller, and computer will that be all i need to get the nav and such? additionally, how much programming will i need to do?
09-19-2019, 12:57 AM | #55 | |
Rep 11
Car intel :- man’fact June 2013; CHAMP 2 head unit: S606A Navigation System business. I am engineer so need a little guidance and will have this resolved for myself and other legacy iDrive F30s, br/ |
09-19-2019, 06:37 AM | #56 | |
Rep 74
Your options are changing the navi including the head unit or getting an android screen. Last edited by Tavicu; 09-19-2019 at 06:42 AM.. |
09-19-2019, 02:40 PM | #57 |
Rep 1
NBT
Hi guys
I just got my F30 few weeks ago, I'm unsure if I have NBT or CIC, but I would like to get the NBT EVO, but as you got it on eBay where would I get it coded? I'm in the uk and and on eBay they are going for £600 a lot of money to be wasted |
11-08-2023, 10:59 AM | #58 |
Rep 2
2013 BMW 320i 6" to 8" screen
Hi,
I have a 2013 BMW 320i with 6"inch screen and the CIC radio. I need to convert to 8" screen is it possible?? And i have also installed MMI prime so carplay works fine. guide me in retrofitting a 8" screen. |
