02-10-2015, 10:56 AM | #67 |
Rep 162
Vithy
My car has already Xenon light. But maybe I am thinking of retrofit the 6WA cluster, if I get a cheap one. But I am not sure if my car has already the right FEM Module for this. |
02-10-2015, 07:48 PM | #68 |
Rep 286
I think you will be fine. FEM Mid should accommodate 6WA. A friend of mine and a forum member is going to be installing one and I will be flashing it today or tomorrow. He's got FEM MID.
He got a used 6WA, so it's showing VIN mismatch warning. But when we installed it in his car with the MOST cable to NBT, it worked fine. Showed all the info and functioned correctly. Short answer, you will be fine if you want to retrofit. |
02-11-2015, 01:30 AM | #70 |
Rep 931
Sorry but is not necessary to allign the VIN of car ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
02-11-2015, 10:26 AM | #72 |
Rep 286
Yes it is necessary. Which is why he got an Eeprom programmer to flash it with virgin file and then we have to flash with his VIN.
But it will still work with the Red tamper dot on the cluster and as long as the millage is lower than the car's. If not FEM will inherit the millage from cluster, which might not be good. |
02-11-2015, 10:39 AM | #73 |
Rep 162
02-11-2015, 11:22 AM | #74 | |
Rep 286
I think it looks right. Apparently the connector is a little different/smaller on the BMW one. My friend who got it here in Toronto had to order it directly from the dealer and it wasn't expensive. They come in a pack of 10 for under $20. I will let you know the part number. The optical cable should be good.
I would get this from this seller. My guess is it looks right and should work. Quote:
02-11-2015, 11:40 AM | #76 |
Rep 286
Not for the whole cable. I don't think they sell the whole cable, not sure about it, Cable and Connectors come separately.
Cable goes for $50 and connectors come in bulk. But I will find out from him as he knows a dealer. |
02-11-2015, 12:45 PM | #78 |
Rep 286
He just got back to me.
$40 per most cable. You need two and the ends are $5 each. And $20 each for Cable head (Copper head) for optical cable. Total price around $100 here. But in Canada everything is expensive for BMW parts. You might want to check with the dealer. He doesn't have the part numbers with him, but will get back to me. |
04-20-2015, 04:15 PM | #80 | |
Rep 1,397
if you have the MOST cable connected you will see 6WA Kombi |
05-08-2015, 10:53 PM | #81 |
Rep 130
12-14-2015, 06:17 AM | #82 | |
Rep 13
Have you addressed the red dot problem? If so, how did get this done? By flash the KOMBI with your VIN? I'm still quite confused. If, as you've mentioned, one long VIN & 3 short VINs in EEPROM have been blanked, and mileage been cleared. It should no different from new cluster. However, other members did say that you should only need to change SVT and write it back then inject CAFD, coding.... So why flash is necessary? |
01-18-2016, 08:57 AM | #83 |
Rep 938
I'm half considering this. I've got a dealer quote for 550eur (+ VAT), for the cluster.
(I'm having a bit of a spend-a-thon at the moment so considering all my options). Is there a straight-forward way of retrofitting a S6WAA cluster? Short of the long, I have a Business Navigation with no extended bluetooth (no combox), but it would be rather nice to upgrade my cluster to an extended version. Primarily for navigation as I like the idea of having that there, but it also looks a lot nicer. Question is...if I buy a brand new, unused unit, how simple is it to install? I've read through this forum and it's another language!
Thanks all! |
04-06-2016, 03:56 AM | #84 |
Rep 325
Success
Yessss, last night I retrofitted my 6WA instrument cluster on my F30 04.2012.
After most connection, I had to code them, there was a little bit problem, when E-Sys doesn't saw Kombi, after adding 6WA to FA, but after saved SVT, deleted BKombi, write STV to car, and read SVT from car again, E-Sys saw Kombi module. Then injected CAFD and VO code it. All is OK, no red DOT, correct KM, service etc. After done with Kombi, I had to code with 6WA in FA, HU-NBT module, and all OK. Now I have navigation instructions on instrument cluster, ED stats in HU-NBT, everything is working OK. It is a nice retrofit. Thank you all , for your help. I can help others, if they need. |
05-17-2016, 10:32 AM | #85 | |
Rep 11
I have the same problem. How do i delete bkombi? |
05-17-2016, 11:23 AM | #86 |
Rep 40,745
Do you Read ECU rather than Read SVT?
05-17-2016, 11:53 AM | #87 |
Rep 325
05-17-2016, 11:58 AM | #88 |
Rep 40,745
You do not need to delete existing ECU from SVT to see new ECU. Using Read ECU ignores SVT stored in VCM and actually queries all system buses, and populates SVT based on actual ECU's connected to bus.
