12-31-2016, 07:16 PM | #1 |
Rep 3,926
Flashing / Programming using ISTA (ISTAD and ISTAP) PsdZData Full
Environment/Setup
I have set up ISTAD and ISTAP within Oracle VirtualBox virtual machine. Windows 7 x64 Enterprise with SP1 ISTAD v4.3.21 ISTAP v3.60.2 PsdZData v60.1 Full BMW ICOM A2 Clone Using my girlfriend’s loaner F25 X3 28i as a power supply in order to keep voltage between 14.0 and 14.9. This seemed sufficient for maintaining voltage and a temporary alternative to purchasing a Schumacher INC-700A power supply/charger. BMW ICOM A2 clone… ISTAD v4.3.21 My understanding was that ISTAD v4.x.x was supposed to be able to do flash programming and eventually replace ISTAP. I have not been able to get this working with my setup after weeks of trying. Not sure if anyone else has gotten this functionality to work. Otherwise, ISTAD has been great in terms of serving as diagnostic software and factory service manual. VCI configs… It would seem to calculate measures fine which is another way of saying determine which modules need to be flashed. However, pressing “Execute measures plan” would result in no action. ISTAP v3.60.2 I finally decided to give ISTAP a try. I know flash programming can be done via ESYS after talking with number more experienced forum members, but I prefer a factory all-in-one solution for simpletons like myself. Fortunately, ISTAP worked when ISTAD did not. ISTAP reading vehicle data after starting New Session… ISTAP preparing vehicle for programming… ISTAP programming vehicle in progress. You can see the status bars below the module names. What the display says when in the first few minutes of programming... I did see the “Emergency call malfunction” warning after I restarted the car after completing the flash. It went away after driving for a bit. A few notes: - Total duration for everything was about 57 mins - ISTAP will flash firmware onto the modules and then code them. The coding process is automatic and it is fairly short. However, there will be a few dialog boxes that pop up to warn you or instruction you to do certain things such as calibrate the steering wheel angle, close all doors, etc. You’ll see your instrument cluster, climate system, windows/sunroof activate and deactivate. Don’t worry. Your car is not possessed, it’s just ISTAP doing everything to re-initialize your vehicle. - You will lose your previous coding. For example, I had VO coded Bluetooth Audio/Media, tire pressure and temperature displays, and 6 blinks instead of the default 3 blinks for the turn signals. You will have to re-code all of that. PsdZData Full So one major issue that I foresaw was that ISTAD, ISTAP, and ESYS all have different places they want to access PsdZData Full. You don’t want to have 3 separate places to store all this data because it would consume a ridiculous amount of space. PsdZData Full is about ~70 GB. The solution is to decide where you want to keep the real physical PsdZData Full and create symbolic links for the other two applications to utilize. Code:
mklink /J "C:\Rheingold\PSdZ\data\psdzdata" "C:\ISTA-P\BMW\Services\data\ecudata\psdzdata" Where psdzdata really is. I've also attached a "FinalReport.pdf" that basically describes which control modules have been updated. It's neat because it provides a "diff" between beginning and end. I obtained most of my factory BMW software from CarTechnology forums: http://cartechnology.co.uk/forumdisplay.php?fid=61 Last edited by Polo08816; 07-07-2017 at 07:57 PM.. |
01-01-2017, 10:59 AM | #2 |
Rep 3,926
Screen/Radio Update
Anyone know how to get my 2014 335i screen to look like my gf's 2016 X3 35i screen? shawnsheridan Almaretto
I somewhat expected this to be updated by flashing new firmware, but my screen basically remained the same. I'm basically interested in my screen being able to display Album Art and Artist/Song info without having to dig through a bunch of menu settings. Was there a control module that simply was left out in the process of flashing my 335i? Last edited by Polo08816; 01-01-2017 at 12:03 PM.. |
01-07-2017, 08:19 AM | #3 |
Rep 35
Drives: 2013 528i
Nice write-up. I got a similar setup in a MacBookPro; 150GB vmware Fusion machine running Win10x64Home.
On the radio issue, is RDS enable? In my 13'528i the radio listing shows just as in yours, the details shows when you select the station or click to the right. |
01-10-2017, 05:58 PM | #5 | |
Rep 3,926
Link to the software is at the end of the original post. You have to go through the forums and figure out what version you want to use. |
05-12-2017, 07:31 AM | #6 | |
Rep 615
08-03-2017, 04:14 AM | #8 |
BMW Enthusiast
Rep 10
Drives: 2011 BMW 320d
Where can I buy ICOM A2 Clone?
08-04-2017, 12:30 PM | #9 |
Rep 557
Polo08816 damn Polo, I didn't think you were this geeky -- but mad propz to you! My brain almost exploded reading thru. I only used eSys but will try your method. What is the usage of the ICOM interface?
08-04-2017, 03:08 PM | #10 |
Rep 3,926
http://www.obd2tool.com/goods-4507-2...ICOM+A2BC.html
Something like that... I bought mine off of Ebay. However, if I had to buy now, I'd probably opt for the Genuine BMW ICOM NEXT. It's not as expensive as the ICOM used to be. I believe the part number is 81312360883. You could get it from GetBMWParts for $675. |
david51537.50 |
12-07-2018, 01:52 PM | #11 |
Rep 10
Hi Polo08816,
I totally agree with sharing the file location as per your suggestion. How or where does the coding need to be input? sorry I'm a NooB in all this? Any guidance would greatly be appreciated. |
