Studio RSR
      04-16-2013, 10:27 PM   #3301
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
I don't see the corner amber marker delete option in the google spreadsheet, it was done earlier in the thread by svache it seems, but no reference to what values to change...
      04-16-2013, 10:37 PM   #3302
vkoprivica
Drives: 2018 BMW g30
Originally Posted by kon View Post
Yes - IHKA module 3000 OFF_MEMORY, set to aktiv
Originally Posted by vkoprivica
Hi, I am the owner of f30 who is interested to change default hvac behavior. Currently my car remembers last temperature setting but not the on/off state. Every time when I start the engine, hvac turns on even though I left it off last time before I turned the engine off. I was wondering if there is a way to make computer remembers a last hvac on/off setting.
Thank you.
I was at the dealer today to change the setting and was told that it is applicable only to old models. The coder was not able to figure out how to resolve my issues and find proper settings. Does anyone know what setting needs to be changed on f30 models?
      04-16-2013, 10:47 PM   #3303
kon
Singapore
Drives: F30 310i > G20 310i
Thank you.
the dealer generally couldn't change specific settings you asked for - the feature is there in your F30, you need to use esys to manually change the IHKA module.
      04-16-2013, 10:49 PM   #3304
kon
Singapore
Originally Posted by DXL XLR8 View Post
Got it! Thanks you guys! Did my first coding session today and everything went smooth. Only thing was coding the mirrors to close automatically when lock didn't work. Any ideas as to why?
which settings you change to code the mirrors to close automatically? for comfort close, mirror & sunroof will close in sequence, but you need to keep the close/lock button depress (either the keyfob or door handle for comfort access)
      04-16-2013, 10:53 PM   #3305
shawnsheridan
shawnsheridan's Avatar
FEM_BODY:
MAPPING_SIDEMARKER_L_OUTPUT = off
MAPPING_SIDEMARKER_R_OUTPUT = off
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      04-16-2013, 10:57 PM   #3306
DXL XLR8
Drives: F30
I changed "ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN" and "ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN" to "aktiv (werte = 01). I didn't know what the cheat code meant by needs _FB for keyfob or _PA for door. Also changed "KOMFORTSCHLIESSUNG_FB" to aktiv (werte =01).
      04-16-2013, 11:14 PM   #3307
shawnsheridan
Set all of these to active:
KOMFORTSCHLIESSUNG_PA
Change only the Drop-down selection to aktiv, and leave the Werte values alone.
You will need to hold the Fob Button or touch the CA Door Ridges for a couple seconds for it to work.
      04-16-2013, 11:18 PM   #3308
DXL XLR8
Drives: F30
You da man!
      04-17-2013, 12:07 AM   #3309
vkoprivica
Thank you.
Please let me know what is the version of esys I should be using?
      04-17-2013, 12:40 AM   #3310
kon
Singapore
refer to this earlier post by our resident expert
http://www.f30post.com/forums/showpo...postcount=3282
      04-17-2013, 03:18 AM   #3311
ykau
Drives: F30 320I
Hi Shawn, I think i have asked before, but would like to ask again if the odometer mileage value can be just changed via esys or fsc?
reason our country will consider warranty expired after driving for more than 100K. thanks
      04-17-2013, 03:39 AM   #3312
ykau
Drives: F30 320I
Hi Shawn, is both 6NL and 6NK the same.
You have 6NL, so you have BT Streaming without coding.
      04-17-2013, 03:40 AM   #3313
kon
Singapore
*subscribed*
      04-17-2013, 04:00 AM   #3314
clarence
Drives: F30 328i M-Sport
6NK is combox media. 6NL is combox telematics. Essentiall the same thing except for provision of BMW Assist service for the latter case.
      04-17-2013, 04:09 AM   #3315
ykau
Drives: F30 320I
*subscribed*
      04-17-2013, 04:10 AM   #3316
ykau
Drives: F30 320I
Thanks man!
      04-17-2013, 04:37 AM   #3317
kon
Singapore
Thanks man!
a good picture from another thread comparing "feature"
http://www.f30post.com/forums/attach...5&d=1350325458
      04-17-2013, 06:58 AM   #3318
vkoprivica
Thank you.
      04-17-2013, 08:31 AM   #3319
kon
Singapore
Need help
File for "cafd_000000f9-007_006_009" not found! [C012]
Car i-level was F020-13-03-503 just one level higher than my 49.1 psdzdata
All ECU ok except HU_CIC
      04-17-2013, 10:09 AM   #3320
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Need help
Looks like you need 49.2 where the only difference is that file you mentioned - cafd_000000f9.caf.007_006_009.
I think Shawn should be able to just give you that cafd file and you can just plug it into your existing cafd directory and code HU_CIC. I'm taking my car in for service soon as well so I might need it too if they update the software on my car.
      04-17-2013, 04:56 PM   #3321
f302012sold
f302012sold's Avatar
Drives: F30
hey Shawn et all,
it has been a while I have not been on this thread, apparently it has grown from 79 pages to 151 and so much has changed. I think the biggest one would be all of a sudden I would need the paid token and E-Sys 3.22.5 | 49.1 PSdZData to code.. Can I trouble you to PM me the details how to obtain one as well as the files?
sorry to be a bit of outdated .. life changes too fast //
Thanks a million
      04-17-2013, 05:51 PM   #3322
shawnsheridan
Originally Posted by also1412 View Post
hey Shawn et all,
Thanks a million
PM sent.
