02-08-2014, 02:26 PM | #5721 |
Rep 26
Patched vs unPatched Token
I feel like a zombie having read so many pages of posts. I'm still cloudy about the difference between patched and unpatched Tokens. Can someone post a brief Pros and Cons of each?
02-08-2014, 03:37 PM | #5722 |
Rep 383
I think I may have missed something from the cheat sheet. Can someone post how to have the mirrors auto-fold when locking the car using the door handle? Thanks.
02-09-2014, 01:36 AM | #5723 | |
Rep 490
The only part I'm still confused/not sure is when I tried to VO code 3 ECUs, nothing happen... I tried to activate OMSA, 6AL & 6UH... (works well on all my previous attempts on F30s)... I "code" CAS, CMB_MEDIA & HU_CIC, but none of the FDL line get updated, FDL coding them manually works... what could be wrong? I checked that FA was written to car succesfully & manage to redownload it and see the option there, just nothing happen to the ECU |
02-09-2014, 01:37 AM | #5724 | |
Rep 490
Werte=00 (0.0 sec) Werte=05 (0.5 sec) Werte=0A (1.0 sec) |
02-09-2014, 01:49 AM | #5725 | |
Rep 490
While the patched tokens will require new patch file for subsequent version of eSys Of course qns remains whether or not the unpatched token really could work with future release, but same can be said about patched since it is dependant on the keygenerator to provide new patched files. I'm personally using patched token (since last year) |
02-09-2014, 03:43 AM | #5726 |
Rep 40,791
I don't think patched token solution has any advantages. Unpatched though modifies no native E-Sys java libraries and is generally not E-Sys version specific so you can update E-Sys in most cases without needing a new token solution.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 02-09-2014 at 03:49 AM.. |
02-09-2014, 03:47 AM | #5727 | ||
Rep 40,791
02-09-2014, 03:51 AM | #5728 | |
Rep 40,791
02-09-2014, 03:56 AM | #5729 | |
Rep 40,791
02-09-2014, 06:56 AM | #5730 |
Rep 490
02-09-2014, 07:41 AM | #5731 |
Rep 18
Hi, i installed everything and it work fine, reading oke, saving SVT works oke.
The failure becomes when i'm going coding. When i change something and i want to save it i will get the error C158 Failed to sign FDL ?! I work with e-sys 3.24.3. Can someone help me? :-) Last edited by andre42k; 02-09-2014 at 08:26 AM.. |
02-09-2014, 09:12 AM | #5732 | |
Rep 41
which PSdZdata versions are you using and have you checked this with your i-step version? |
02-09-2014, 09:26 AM | #5733 | |
Rep 18
Hi Lucardos, i use v.51.3_PSdZData_Lite, what do you mean with i-step version? version F020_13_11_504 did you mean this? Last edited by andre42k; 02-09-2014 at 09:36 AM.. |
02-09-2014, 09:40 AM | #5734 | |
Rep 41
http://www.f30post.com/forums/showpo...postcount=1403 could it be that your I-step is from March-2014 (F020-14-03-50x) ? |
02-09-2014, 10:37 AM | #5735 | |
Rep 18
this it what there stands: F020-13-03-503 ( current, last and shipment) |
02-09-2014, 11:04 AM | #5736 |
Rep 41
02-09-2014, 12:06 PM | #5737 |
Rep 40,791
I am not sure on that one. I think the est-cm-01.04.00.jar file is identical in both 3.24.2 and 3.24.3, but I am not sure about psdz-core.jar. It is never wise to apply patch for one version that was built for another version. Try installing 3.24.2 and patching it, and see if it works.
02-09-2014, 12:09 PM | #5738 | |
Rep 40,791
02-09-2014, 12:11 PM | #5739 | |
Rep 18
thanks i am working on that, tomorrow i will try again. Thanks for you're advice |
02-09-2014, 12:57 PM | #5740 |
bimmer noob
Rep 23
Hi, so I coded the key fob mirrors/windows. And while I can get them to go down, they won't go back up. Anyone know what I did wrong?
EDIT: NM, got it.
02-09-2014, 08:29 PM | #5741 | |
Rep 490
another reason that I could think of that could screw up the VO coding was maybe the fact that I have done "READ CODING DATA" at the beginning - I was paranoid in case I don't have all the files, so I did a full read at start just to be safe |
02-09-2014, 08:38 PM | #5742 | |
Rep 40,791
