BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 328i JB4 **STAGE2** Dyno Testing -- New World Record. :)
      05-27-2013, 04:23 PM   #155
BRM6
BRM6's Avatar
Brazil
Drives: 328/335/M235i/M4 - Current M6
Originally Posted by swe328i View Post
What do you guys think of boosting 6psi and using 102 octane fuel
in a everyday use ? can the fuel injectors handle it ?
Your best bet would be to ask BMS directly. If it's doable and safe, logs will show.
      05-27-2013, 07:14 PM   #156
boogysbmw
Noice
boogysbmw's Avatar
125
Drives: 2023 BMW iX 50drive
Originally Posted by Eddian!
Nice. Does anyone know when this will be available? I want to get both stage 1 and 2 at the same time.
You wouldn't need stage 1 if you ordered stage 2.
2023 BMW iX xDrive50 - Blue Ridge Mountain Metallic / Oyster Perforated / Ultimate PKG 2 / Sport PKG
2023 BMW X1 xDrive28i - Portimao Blue Metallic / Black perforated /Shadowline/ M sport / premium package
      05-28-2013, 12:12 AM   #157
Zluk
Drives: BMW F80 M3 Orange Sahir
All were good. Buy usb cable ans see logs.
      05-28-2013, 04:22 PM   #158
Eddian!
Drives: 2012 328i Black Saphire
I thought I read somewhere stage 2 is an add-on to stage 1...
      05-28-2013, 04:36 PM   #159
momo3605
Drives: M340i LCI, 718 GTS 4.0
There is an upgrade price if you already have stage 1, but you can buy stage 2 outright...you don't need stage 1 to get stage 2, it's a replacement
      06-07-2013, 05:08 PM   #160
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Just bought my stage 2, I also opted for the laptop USB cable and the flex fuel E85 wires so I can run a 50/50 mix of E85/91oct.
Can't wait to get it!!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      06-08-2013, 07:57 AM   #161
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Originally Posted by Zluk View Post
0 map 98 ron fbo
1 map 98 ron fbo
7 map 99 ron fbo
plz tell me what exactly mods did you have and how much boost over stock did you reach to get that 330 whp ?!!!!
      06-08-2013, 02:44 PM   #162
slmdgee
Usofstance
Drives: 328I 6SPD
What size is the stock injectors and the fuel pump? I dont think it can handle e85 for long
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      06-08-2013, 03:00 PM   #163
Zluk
      06-08-2013, 06:20 PM   #164
rustyminded
248
Drives: BMW 328i
I already got hesitation problem during acceleration on half pedal my mods are stg 1, afe filter and scoop I use ron92 I don't know if it's the tune or what. I did some clean but the problem seems to exist, I contacted bms and he said to remove the blue wire for solenoid and it did make a difference for few hrs then prob. back again maybe a vacuum leak.
      06-08-2013, 09:43 PM   #165
slmdgee
Usofstance
Drives: 328I 6SPD
Can you post video of this?
      06-09-2013, 07:50 AM   #166
rustyminded
248
Drives: BMW 328i
I doubted it's the MAF, I took MAF from f10 28i same engine of course and bam no hesitation but the car doesn't feel it's tuned sorry I couldn't take any video before. so that means my MAF sensor is bad ? or it just needs to be cleaned
      06-09-2013, 10:33 AM   #167
rustyminded
248
Drives: BMW 328i
I was testing the car it was good so far until a check engine light came out and back to hesitation again I will post a video when I can
      06-10-2013, 07:00 AM   #168
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
No one on the forums is going to be able to help you. If you have a check engine light then step 1 is to read that code using a BT scanner or JB4 (stage2). That should put you on the right path to finding the issue. A common problem is oil from those AFE filters is too much filter oil coating the MAF so I would not be surprised if its related.
Mike
      06-10-2013, 07:13 AM   #169
rustyminded
248
Drives: BMW 328i
Mike
It's dry filter not oiled, for the check engine light it disappears right after I shut the engine and if stage 2 should help then I will try it but it will take some time because I have to send it here.. I did some injection clean and it helped but someone told me the tank is filled with residues because fuel here is very bad and there is no ron95 except in some far places, so I will try to clean the tank and the whole fuel system and will tell you the results. thanks again
      06-10-2013, 11:03 PM   #170
nenenenene
Drives: 328i
Here is 328I with BMS STAGE2+DP.
0-100km/h PBOX 4.8S.
      06-11-2013, 06:21 AM   #171
rustyminded
248
Drives: BMW 328i
cool but I can't see the pic
      06-11-2013, 04:47 PM   #172
swe328i
Drives: BMW 328i f30
Which Map and fuel are you using ?
      06-12-2013, 12:34 PM   #173
rustyminded
248
Drives: BMW 328i
can you do 0-200 ?
      06-12-2013, 12:34 PM   #174
rustyminded
248
Drives: BMW 328i
anyone here tried the throttle body spacer ?
      06-12-2013, 12:43 PM   #175
rustyminded
248
Drives: BMW 328i
Mike
I did the system clean but I'm going easy on the car and still there is no hesitation so far I hope it's fixed or I will sell the car lol
      06-12-2013, 07:36 PM   #176
nenenenene
Drives: 328i
can you do 0-200 ?
It's really hard to do that in Shanghai.But I will try it some days later.
