06-01-2017, 10:50 AM | #12102 |
Rep 40,959
PM sent.
06-02-2017, 02:28 AM | #12103 |
Rep 42
Unable to code different indicator flashes - F30
Hi all,
We have a 2015 (Pre-LCI) 320d which I have used PSdZData v61.2 for coding and a 2016 (LCI) 330e which I have just coded using PSdZData v61.4. I've noticed that on both vehicles I am unable to change the number of indicator flashes. I tried changing the value of BLINKZYKLEN_ANZAHL_TIPP to 03 and also 05 and the indicators still blinked 3 times. I noticed prior to changing the value that it had a default value set to 0. I also checked Pia_Default_Tippblinken and made sure that it was set to Mehrfachblinken. The last PSdZData version that I used where I did not have this problem was v60.4. Does anyone else have this problem and, even better, a fix for this please? Thanks very much in advance for your help. Cheers, Colin. |
06-03-2017, 08:18 AM | #12105 |
Rep 40,959
Sorry, but I cannot help with ISTA. PM sent.
06-03-2017, 05:44 PM | #12106 |
Rep 910
Drives: 2022 G80 Comp x-drive
Shawn,
Can you send the software needed to code a 2017 340i? Thanks.
2022 G80 comp X-drive:San Marino Blue/ Silverstone, 826 bicolor, cf roof; exec pkg; shadow lasers; carbon pack; MSS HAS; spacers (15/12); Burger intakes; Unit17 front lip/CS Style spoiler; TLG flappies; full xpel ppf + 15% tint; AWE switchpath exhaust w/mid-pipes; csl strut brace; Eventuri cf engine cover
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335 |
06-03-2017, 06:05 PM | #12107 |
Rep 40,959
PM sent.
06-04-2017, 11:48 AM | #12109 |
Rep 40,959
06-04-2017, 06:08 PM | #12111 | |
Rep 40,959
http://f30.bimmerpost.com/forums/sho...&postcount=408
06-05-2017, 11:38 AM | #12112 |
Rep 92
Does someone know, if it is possible to code the fog lights to be automatically on with the headlights (low beam)?
For the E92 I found the following line, but is this still working with F30 F22 models? SL_FKT_MIT_NSW aktiv |
06-05-2017, 03:04 PM | #12114 |
Rep 40,959
PM sent.
06-05-2017, 05:41 PM | #12116 |
Rep 40,959
PM sent.
06-07-2017, 05:13 PM | #12117 |
Rep 2
I used FEM_BODY-->3063-->MAPPING_NEBELSCHW_L_FUNCTION & MAPPING_NEBELSCHW_R_FUNCTION for left and right fog lights and set the value to 03 instead of the default value 08. Fog lights will turn on with low beams but the fog lights button will not work anymore, it will be disabled.
06-08-2017, 11:23 AM | #12118 |
Rep 10
shawnsheridan
Can you please send me links for the software? My account was just activated so I may not be able to get a PM for an hour, I lurked here for too long. |
06-08-2017, 11:55 AM | #12119 |
Rep 40,959
PM sent.
06-08-2017, 02:27 PM | #12121 |
Rep 45
Hey shawnsheridan!
Could you PM me the latest E-Sys, Launcher and PSdZdata? Mine is "out-dated" (March '17) and I want to code ID6_Light and test some VIM-Workarounds with my NBT2 - I might have found a possible solution |
06-08-2017, 02:48 PM | #12122 | |
Rep 40,959
