01-24-2019, 09:38 PM | #1 |
Rep 8
"No Signal' Corrupt coding data
Help Needed...Head Unit crashed..Yesterday I tried coding with the Bimmer app using a cheat sheet in expert mode and received a ECU corrupt: Cannot be coded..I tried restoring from a backup but no luck...Decided to connect via Esys to see the problem was seems that i haver 2 instances running on the same ECU..How can I restore the corrupt HU_NBT ECU or repair this one...Pics below..Thank you
01-25-2019, 05:09 PM | #4 |
Rep 43
I actually had that happen to me without any doing any coding at all, NBT unit had a fault and had to be replaced, would just come up no signal
01-30-2019, 12:03 PM | #5 |
Rep 1,980
Drives: 2020 G20 320i M Sport
Check the log under C:\Data\ and see what the "More than one condition is active " part fully says. It may point to something.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
