08-25-2014, 06:06 PM | #1 |
Rep 219
Drives: 14 BMW 335xi M-Sport EBII
Downpipes available for 2014 4" Outlets
Does anyone know what downpipes are available for the larger 4" outlets found on the newer 2014 electronicly wastegated turbos?
It seems that most manufactures list on a single downpipe for 2012+. It's been a year it would be awesome to see some options for us with slightly newer cars. |
08-25-2014, 07:49 PM | #3 |
Rep 219
I forgot about that announcement. I would prefer a HiFlo catted DP, but maybe I'll look into this option.
I have 3 year until I need to do emissions and replacing the downpipe is way easier than the N54. |
08-25-2014, 09:38 PM | #4 | |
Rep 383
http://www.wagner-tuning.com/BMW_c_8.html |
08-25-2014, 11:12 PM | #5 | |
Rep 18,707
You just need to wait for it as they don't stock the catted version. PM me if you are interested.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
08-26-2014, 07:01 PM | #7 |
Rep 190,721
Evolution Racewerke DP is the best one available at the moment.
08-27-2014, 08:58 AM | #8 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Nice to have some good options out there... I am eagerly anticipating the CG Precision offering - especially with the CEL defeater module that they're working on to go with it!
08-27-2014, 01:09 PM | #9 |
Rep 824
If your going to get a dp even high flow cats cause check engine lights and won't allow u to pass emissions. Keep that it mind u might just wanna go catless and should be cheaper
08-27-2014, 04:14 PM | #10 |
Rep 4,515
I have BCS automotive hi flo cat DP on my EWG car here in the UK and no CEL.
Also, Wagner website says their hi flo cat DP doesn't cause CEL. Have heard catless DP and it sounds too raspy. Hi flo cat is the fit and forget solution which gives up a slight power/torque to decat but IMHO sounds much better. |
08-27-2014, 05:38 PM | #11 |
Rep 116
Just keep in mind that, especially in states where emissions are tough, aftermarket hiflow cats have a very short lifespan before they don't do enough to let you pass sniffer test, even if you pass visual.
08-27-2014, 06:48 PM | #12 | |
Rep 824
09-01-2014, 05:11 PM | #13 |
Rep 969
09-01-2014, 05:45 PM | #14 |
Rep 221
Im considering a hi flow catted DP as well that does not set off a CEL.
Which ones the best? I.e. offers the best hp, best sound and no CEL for sure. TIA |
09-03-2014, 01:20 AM | #17 | |
Rep 648
What exhaust is on after the cat? /Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
09-03-2014, 02:10 AM | #18 |
Rep 4,515
Krelle,
Car is not old enough yet to be tested so cannot answer your 1st question. OEM mid pipe is still in place connected to the hi flow DP and I have axle back MPE muffler. Combination makes the engine more responsive and gives the sound more volume and character. PD
Current '22 X3M LCI.. |
09-03-2014, 03:02 AM | #19 | |
Rep 648
Thanks. My concern is the drone.. I had a little on the stock system when I forced both end pipes open. With the Akrapovic there is no drone at all. Ref. what "Shiftec" write. I wonder what the lifespan of the catted is, and whether this can be taken out and cleaned, thus "resetting it"? If it can't one migth just try non cat as the change of dp cannot be avoided. Have you heard the M135 with catless? How much louder is it? And is the drone worse than yours? Cheers Krelle
09-03-2014, 04:49 AM | #20 |
Rep 4,515
Krelle,
Never heard of cats being reset. If they get clogged, they fail and need replacing unlike say DPF's on diesel cars that need regeneration/cleaning. Having ran an N54 335i for 5years + ~ 70k miles with assorted mods, including sports cat DP's, the cars emissions were never a problem. In UK, once a car is 3 years old it gets inspected. Emissions are measured and were constant in years 3, 4 & 5. I have heard decatted M135i in the flesh and it sound similar to an E46 M3 in terms of rasp and being slightly "tinny". Not for me hence why I went with sports cat DP. Drone that occurs at 2k RPM with stock system is still there, no better no worse. No drone anywhere elsewhere in the rev range. Hope this helps, PD
09-03-2014, 05:47 AM | #21 | |
Rep 648
Thank you. Guess we're of the same opinion regarding noise. Yes, the stock system did have a little drone at 2000. The Akra doesn't. Now I can go shop for a catted dp. N54 335.... /Krelle
09-04-2014, 08:10 AM | #22 |
Rep 18,707
@Krelle,
I went to visit Evolution Racewerks yesterday afternoon and got a chance to asked them regarding carted downpipe. Their answer was, hi flow cat still may throw a CEL and may not pass emission control. They never went through with one, since most customer wanted the catless since it is better for the performance. Let me know if you need to get one.
