07-01-2015, 10:57 PM | #244 |
Rep 614
Drives: 2016 F36 M Sport
Just received my 50W amber cree LED's from Horizon (UK vendor) today. Took a little bit for them to arrive and a bit more expensive than some of the other options I'm seeing on the threads, but definitely worth the wait and money. They're much brighter than the incandescent bulbs, and the instant ON/OFF function of the bulbs is a huge improvement. They look great! I'll definitely be ordering some red ones for the rear turn signals, and then maybe for the brake lights and reverse lights later on.
Install was actually easier than I had expected, just popped off the little cut-out in front of the wheels and had direct access to the indicator bulbs. Unfortunately, I didn't realize this until I had already removed some screws on the driver side and tried to peel back the fender lining to get to the indicators. After knowing that, the passenger side literally took like 30 seconds to switch out!
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
07-15-2015, 07:44 PM | #245 |
Rep 57
Here are my led turn signals. Search out motoring max on eBay. $50-60 a pair. I went with amber front and rear. No problems at all.
2014 328i M-Sport (black grills,CF spoiler) SOLD
2004 325ic (stock) 2010 128i M-Sport (VMR wheels |
07-15-2015, 08:16 PM | #246 |
Rep 246
07-16-2015, 08:47 AM | #247 | |
Rep 173
Drives: 2021 M340i
Using E-Sys, the codes that need to be changed for the front two turn signals in are: (For left bulb) FEM_BODY 3061 FRA_V_L_KALTUEBERWACHUNG aktiv --> nicht_aktiv FEM_BODY 3061 FRA_V_L_WARMUEBERWACHUNG aktiv --> nicht_aktiv FEM_BODY 3061 FRA_V_L_IS_LED nicht_aktiv --> aktiv (For right bulb) FEM_BODY 3061 FRA_V_R_KALTUEBERWACHUNG aktiv --> nicht_aktiv FEM_BODY 3061 FRA_V_R_WARMUEBERWACHUNG aktiv --> nicht_aktiv FEM_BODY 3061 FRA_V_R_IS_LED nicht_aktiv --> aktiv |
07-16-2015, 10:15 AM | #248 |
Rep 57
Just installed em. That's it. Nothing seems to be going wrong.
07-16-2015, 11:01 AM | #249 | |
Rep 614
Perfect write-up!
07-16-2015, 11:06 AM | #250 | |
Rep 173
Drives: 2021 M340i
Also, I forgot to add the coding for the rear bulbs which are almost identical to the fronts; only difference is that the ECU is REM instead of FEM. Everything is the same except the beginning phrase which is FRA_H_L instead of FRA_V_L |
07-16-2015, 03:29 PM | #251 | ||
Rep 57
07-16-2015, 03:59 PM | #252 |
Rep 312
There most likely is flickering and you're just not noticing it yet. The easiest solution would be to find a local member in your area and to pay them to do it. I don't have a laptop, but the cost of that, plus an enet cable, sourcing a token for esys, etc is just too much for me. I'd rather pay someone with experience to do it for me.
07-16-2015, 06:17 PM | #254 |
Rep 173
Drives: 2021 M340i
You can PM shawnsheridan, he's the one who hooked me up with the coding software. Or you can just browse around on the Coding and DIY section of the forum for other sources. As for the ENET cable, you can either make one or buy one off Amazon for around $40. All of the installation instructions and steps for activating E-Sys as well as connecting to your car are well explained in the included documentation. After that, all you need to do is apply the changes I mentioned above and you should be good to go
02-29-2016, 03:08 AM | #256 |
Rep 72
how about these:
http://www.aliexpress.com/item/1set-...502098323.html do they work instead of coding? |
03-07-2016, 10:47 AM | #257 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
If you're looking for a pair of LED bulbs for the front turn signals I highly suggest going with the plasma LEDs you get that from underground euros. There's a picture of them on my car on that website because we were testing them out when my car first came out and there are no error codes or anything in there an exact match to the halos but my halos were coded to 100% instead of the original I think 50% but when they're on there is an exact match and they are perfect I've had them in my car since the day I got my car or the week I got my car December of 2013 and to this day they are perfect and I wouldn't change them for anything else they are white plasma LED from his website underground euros or if you just do a search for underground euros or something
07-05-2016, 03:20 PM | #258 |
Enthuisiast
93
Rep 423
Bringing the thread back from the dead...
I recently installed these in my car and have had zero issues. No coding, no fast blinking or anything. They are crazy bright at night and comparable during the day. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david |
07-06-2016, 08:04 AM | #259 | |
Rep 33
07-06-2016, 09:00 AM | #260 | |
A family of bimmers
2748
Rep 7,742
I got these: http://www.ebay.com/itm/Error-Free-A...-/131243398136 They are 50w equivalent and cree leds. I did code them as well so i disabled the bulb checks and enabled is_led.
07-06-2016, 10:06 AM | #261 | |
Rep 33
07-06-2016, 10:48 AM | #262 | |
Enthuisiast
93
Rep 423
Leave the car idling outside and sit and watch? Does it only do it while the bulbs are on? I literally haven't noticed them blink, give errors or do anything weird. They work just like the halogens...? I also had the car out in the daylight with the hazards on an watched the LEDs vs the OE bulb... the difference was almost not noticeable. What am I missing?
IG: @hybrid_david |
07-07-2016, 12:28 PM | #263 |
Rep 273
Hey guys, I just want the Halogen bulbs in clear color that turn amber when signaling. I dont want to do any LED coding or anything...does anybody know which halogen amber bulb to buy for turn signals?
(I ordered USR Depo headlights and plan to put the turn signal in those) |
07-07-2016, 01:43 PM | #264 | |
Enthuisiast
93
Rep 423
IG: @hybrid_david |
