02-11-2016, 12:56 AM | #45 |
Rep 18
Hi Cryptocar,
so this software does not have an option to open and save modified dumps? That sucks... Are you completely sure about it? If you were that kind and tried it, I would really appreciate it. I have the files on hand and can send them to you for your test... Martin |
02-11-2016, 03:49 AM | #46 |
Rep 18
Mods: I am sorry for double-posting, but I am not sure if Cryptocar would get an announcement if I only edited my last post.
I tried to open the ECU Explorer with my BMW Explorer dongle, so I went through the menu (I do not have the license, so I can not do it myself) and found out, it should be possible by this: Device -> Tricore - SAK-TC1797 - open EEPROM, which is stored at your computer and edit it. It should be possible this way in my opinion. Please let me know, we are a bit desperate I need to say. EDIT6: I did a bit of research myself and tried to give you some more accurate information, but at the end I found out that the diagram you posted is correct. The only thing comes up in my mind is the way you work with the boot mode pin. Do you keep it grounded all the time when attempting to read? Is it connected to the ground before powering up? Maybe the update will solve your problem because there is a higher protection on ECUs from 2011 on, it has something to do with PWD read command. EDIT: I have attached the EEPROM memory from that unit in the ZIP file for your testing. Last edited by Fx323i; 02-11-2016 at 07:33 AM.. |
02-11-2016, 01:16 PM | #47 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
I will take a look at this again today when I'm back in front of my computer.
If I don't post back by tonight just PM me I've been swamped with stuff recently and keep forgetting about certain things, sorry I'm more than willing to help just busy right now.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
02-11-2016, 01:40 PM | #48 |
Rep 497
Crytocar if your not sure about the pinout, pm your last 7 of your vin and pull the wiring diagram for your DME.
I also a natively speaking Russian friend, whose down to help me. So if we need to email the guys back in Russia were covered. Let's make this happen boys!!!! |
02-11-2016, 02:19 PM | #49 |
Rep 18
cryptocar: Thank you very much. I know the situation, I am kind of busy in the same way. Will try to PM you, just please let me know how much time from now should I send it. Here it is 9 PM and I do not know what is the exact time difference :-)
tifosielia: The pinout seems to be OK since it is the same at different information sources, but we could give it a try. I also have an access to ISTA, WDS etc., so this could be a way to go (at least to check if the pins on the ECU are what they should be). The same pinout is on various websited even for VVDI and other interfaces, so I expect it to be OK. Unless - since the interface is a prewired connector, there might be some different pinout used. So far I can see: ECU - OBD 42, 46 (+12V) <-> 1 (+12V from power source as mentioned in Avtotools website) 1 (GND) <-> 4 (chassis ground), 5 (signal ground) + GND outside 44 (CAN H) <-> 6 (CAN H) 45 (CAN L) <-> 14 (CAN L) __________ +12V outside <-> 16 |
02-11-2016, 02:30 PM | #50 | |
Rep 902
I also picked up some other equipment Kess+KTAG which should allow me to access the DME in the same way (enter bootmode to dump/write the rom, but no built in calculators for the hour counter, VIN, and ISN) but I've decided to probably Just hold off my own attempts on my DME now because I'm having mine flash tuned by ACF at the end of the month. I may give it one more shot next week but I think my experiment is coming to an end since I don't have access to a DME I can test with anymore.
02-11-2016, 03:00 PM | #51 | |
Rep 902
Decoded to ASCII at first glance looks like pretty useless cryptic data, was going to post a picture but now i just realized i can see all the info laid out in an odd format, Your full VIN was the dead giveaway, its not easy to read as is, but I'm going to keep going though and trying to extract what I can and try some other features of the software as well. What specific DME variant do you have? i opened this in the tricore mode which encompasses lots of different variants. To properly edit the hex files with the VIN, ISN, Hour counter, etc calculators I think we need to open in the specific tab for that DME variant I'm gonna be taking another break now got to head out with the wife for a while, but i think I may be able to help you, I'll check later tonight or tomorrow at the latest. For times I'm UTC -6 (right now at least) hopefully that will ease communication.
02-11-2016, 04:05 PM | #52 |
Rep 18
Car: 640i F13 Engine: N55 ECU:Bosch MEVD172Y Controller: Infineon Tricore TC1797 If you would like me to check for the pinout of your DME, please PM me with the last 7 digits of your VIN number, I'll try to do my best. |
02-11-2016, 10:11 PM | #53 | |
Rep 902
We've got the same DME variant and the 640 N55 is identical to mine. I don't really know how to proceed from here since we can't select MEVD1972Y from the drop-down like a couple other MEVD1792 variants, PM me and we can chat via email or skype, since I'm not gonna go posting your ISN on the forum lol.
02-18-2016, 10:53 PM | #55 |
Rep 902
Ok so this is basically my last time to try this, I pulled my manifold and DME today and the DME is sitting on my bench.
I will probably not be doing anything today (18th) but will try tomorrow (19th). If anyone has any last suggestions please post them and I'll give them a try.
02-18-2016, 11:02 PM | #56 | |
Gettin It Figured Out
1820
Rep 2,669
You see ACF's latest record? F-N NUTS!!!! I'm excited for you!! .. .. .
02-19-2016, 02:36 AM | #57 | ||
Rep 902
07-08-2016, 09:50 AM | #58 |
Rep 931
Any news ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
07-08-2016, 10:08 AM | #59 |
Rep 4,323
that's kind of nuts. I'll be happy to hit 400/400 at the Enzo dyno.
07-08-2016, 11:52 AM | #60 |
IG @bmwF9xG80
3812
Rep 7,593
You prob are, free up your schedule and we go to Dynojet with the group of guys. We trying to go soon.
60-130mph 6.5s X4M #HCP
07-08-2016, 01:07 PM | #61 |
Rep 4,323
I need to get tuned first! What weekend were you guys planning? I couldn't keep track in thread :-)
07-08-2016, 06:37 PM | #62 | |
Rep 902
07-09-2016, 10:38 PM | #63 | |
Rep 902
Also basically everything ECU explorer does is possible and much more because I have professional tuner tools now.
07-17-2016, 02:16 AM | #64 | |
Rep 931
07-17-2016, 05:37 AM | #65 |
Rep 2,406
Drives: E30 M3 Cecotto, F85, G05, G07,
What a the time lock?
07-18-2016, 04:21 PM | #66 |
Rep 902
The time lock I was referring to earlier in this post was the DME hour counter that starts when the car is first powered on, usually in Germany.
For the first 10 hours of the DME being powered on there are several functions in the DME ECU that can be altered via ESys, this includes, the VIN, the ISN(password for creating keys), the mileage, the engine variant (change 335i output to a 640i output same engine different maps), catalytic converter monitoring, and finally VMax (max speed). The timer begins as soon as the car is turned on and once it elapses 10 hours, usually long before an end user takes control of their car (Euro Delivery excluded), none of these values can be easily changed in ESys by just changing the FDL coding for the functions. The timer can only be reset using specialized tools, ECU Explorer is one example of one of these tools.
