BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Wind-Noise Issues
proTUNING Freaks
      12-15-2019, 01:51 PM   #969
tardboi
Drives: 335i xDrive MSport
Has anyone run into an issue where only one side of the car has howling from the mirror?
My driver side is awful. Passenger side is silent. Same road, same day, same speed - just I swapped seats.
I tried taping over the front windshield to get that out of the way - no improvement. I taped over the left mirror assembly - minor improvement. No obvious seal issues on the door.
However, the weirdest thing - if I put my hand outside the car, between the mirror assembly and the A pillar... silence! No whistling! What the hell is this?? I could not determine any seams that are being covered when I do this; nothing to tape.
      02-12-2020, 02:12 PM   #970
Joe 47
Drives: Bmw 3 series touring
Wind noise in cab 320 bmw
Hi there.
I’ve just solved the problem with wind noise on my 320d touring
After check all door seals window seals on passenger front door
It turns out it was the windshield plastic trim on the out side of
The window had a slight gap, which was making a whistling sound
As if the door or window wasn’t closed. Resealed trim problem solved.
      06-06-2020, 04:43 AM   #971
ndshgyta
Drives: f30
This theme is not for whistling sound!
We are talking about wind noise!
Is there any working solution?
Somebody tried to replace the front door seals with the new part number:
51337414531
      06-06-2020, 09:12 AM   #972
tardboi
51337414531
Maybe you should go back to the first few pages.
Whistling is wind noise.
      06-07-2020, 09:43 PM   #973
Pauloxxi
Pauloxxi's Avatar
Drives: 2014-320Xi / 2017-330Xi
Originally Posted by Joe 47 View Post
Hi there.
Could you please add pictures of this plastic trim and the gap you referred?
How did you resealed this trim?
My wife has a 2014 F30 that don't make wind noise, and I bought a 2017 F30 CPO, couple months ago which makes this noise. I'm trying to get to the source of problem without success so far.
Thanks.
      06-11-2020, 07:24 PM   #974
murdered320
Drives: 2015 BMW F30 320 xdrive
I notice the wind noise in my 2015 320i f30 when I hit 50 mph and then on. Its not that bad with the radio on but when I'm on the freeway its a little annoying. I on occasion drive my families lexus SUV and theres no wind noise at all. It's not worth the money to take it to bmw because if theres no obvious problem the are not going to replace or do anything.
Glad im not the only one thought that experiences the wind noise in the car. overall thought not a huge deal to me.
      09-22-2021, 12:10 PM   #975
gameson
Drives: 2015 BMW 320i N20
I have the same issue as well
      09-24-2021, 06:58 PM   #976
omarsaudi
Drives: BMW F30
I have the same issue, it is really annoying
      10-07-2021, 09:58 AM   #977
GOLDENDUSt86
Egypt
23
Drives: f30 320i 2016
Nothing new to say, but since it’s been debated for so long, here are pics showing where wind noise originates , I believe you cannot do anything about it
Even wind dampening materials cannot be applied onto those areas
Last edited by GOLDENDUSt86; 10-07-2021 at 10:05 AM.. Reason: Typo and image editing
fe7565552.50
      12-05-2023, 03:51 PM   #978
Alpinadrachten
Drives: E91 320d
My car 2016 lci.
Has no wind noise but the tires are making a lot of noise
Much more then my e91.
The sound is coming from the back wheels as far as I can find.
Did someone insulated the rear wheel arches? And how did you do it?
      12-05-2023, 05:38 PM   #979
fs34
Drives: E46 M3
Originally Posted by Alpinadrachten View Post
My car 2016 lci.
Could be wheel bearings. I’m about to embark on that repair soon. Sounds like worn tires moaning, you can isolate by turning at speed. If it gets better/less noisy when turning right, it is the left bearing..turn left and it gets better its the right side bearing.
      12-05-2023, 05:39 PM   #980
Tommy D
Drives: '17 BMW 440i GC, 2005 BMW 330i
My car 2016 lci.
How old are the tires and do they look worn?
How many Km?
      12-12-2023, 12:23 AM   #981
Alpinadrachten
Drives: E91 320d
I already tested with my e91 wheel set from my old car.
No difference in sound
noise, wind noise, wind-noise, windnoise
