11-07-2014, 08:02 AM | #45 |
PLEB R8
62
Rep 288
The BMW manual gearbox isn't that great in general, you know it's true when I opted for the sub par SMG in my E46 over the 6MT. I have a buddy that works for BMW, these aren't the only failures friend
Current: R8 V8 6MT | B9 SQ5
11-07-2014, 10:09 AM | #46 |
Rep 69
I'd honestly trust a remanufacturerd tranny over a OEM brand new one with potentially more future issues.. The remanufacturered one has been fully inspected/tested most likely and carries the same warranties as new.
That being said, what the heck happened to your 6MT? Mines silky smooth for the most part and I can't imagine how it could fail unless it had a major fluid leak causing it to over heat.
2013 F30 335i 6MT M Sport Melbourne Red
2007 Honda Fit Sport 5MT Daily 2013 Honda CBR600RR Repsol #84 |
11-07-2014, 06:05 PM | #47 |
Rep 37
11-07-2014, 06:08 PM | #48 | |
Rep 37
I have no idea what happened. I don't drive it hard, and I've driven a manual transmission my whole adult life. Hopefully it was a one off, but time will tell.
11-12-2014, 06:53 PM | #49 |
Rep 91
I have a 2013 335xdrive which was one of the first off the assembly line. I am getting the same crunch in between gears. It used to be rare but now at 35,000 miles any shift over 5,000 from 1st to second definitely crunches. Somebody mentioned if they replace the transmission they don't cover the clutch. Wtf!!!
11-13-2014, 05:22 AM | #50 | ||
Pace Car Driver
1547
Rep 3,162
The clutch isn't the problem, sychros are. If you pay for the clutch they may throw in the labor free. They'll be in that deep anyway. But that clutch wear at 35K miles is probably greater than 70% life left. |
11-17-2014, 02:55 PM | #51 |
Rep 159
Installed a new transmission! Deleted bms clutch-stop, changed oem oil to motul gear300. Now I'm shifting first to second gear carefully
01-28-2015, 11:04 PM | #52 |
Rep 140
Drives: F80, G01
13' 335i here with 28k. Just started having the same problem. Brought it into the dealer and they are replacing the whole transmission.
01-30-2015, 10:28 AM | #53 |
Rep 23
I had my 6mt replaced at 15k miles same issue. Now at 22k miles I have the same grinding issues. .... dealership has had my car for 4 weeks and I am now waiting for a clutch and fly wheel. They said they think that is why the transmission keeps going out. Soon I will be on my third transmission! Not sure if the second transmission was new or re manufactured. Every one talking about this transmission being silky smooth, just blows my mind.....
07-26-2015, 09:45 AM | #54 |
Rep 108
I am experiencing 1-2 grind over 3k rpm. 2013 335i 10k miles. Made an appointment to take it in, hopefully they don't bust my chops because I have a upgraded clutch in there. Clutch has nothing to do with faulty syncho but let's hope for the best!!
07-30-2015, 08:40 PM | #57 |
Rep 141
A remanufactured tranny may have gone through more stringent inspection before it was released back to BMW due to the known fact that it has failed before. At the time of receiving it at the repair facility, they would have gone through each component as inspected it's condition. The transmission would be then re-assembled, and reinspected, as tested.
2014 BMW 435i xDrive M-Sport "Elphie" | Mineral Grey Metallic | Coral Red Interior | M Performance Package I | Premium Package | ConnectedDrive | bootmod3 OTS Stage 1 93 Octane Tune | M Performance Exhaust | M Performance Stainless Steel Pedal Covers | Dinan Performance Spring Set | Dinan Supplemental Ride Quality | Precision Raceworks N55 Ignition Kit
08-24-2015, 08:38 AM | #58 |
Rep 159
Hey guys did you know that f36 435i and f33 435i cabrio have another manual gearbox? bmw decided to put old transmission from e92n 335i in f33 and f36! Who know why? Because f30 and f32 owners have lots of problems!
Mine is good after change (bmw warranty)! Ordered uuc ssk! |
08-24-2015, 10:57 PM | #59 | |
Rep 1,627
M4 in MG | 6 MT
08-25-2015, 08:22 AM | #60 | |
Rep 159
You didn't like e92 gearbox? You had e92 n54 or e92n n55? That cars have different gearboxes too |
08-25-2015, 12:40 PM | #61 |
Rep 36
i have an early 2013 335i xdrive with about 30k miles on it, and i have always felt that shifting from 1st to 2nd was a little grindy, i have tried shifting at diff rpms, but only like 1 out of 10 shifts is smooth.
i wonder if i have the defect or i am just shift challenged... |
08-25-2015, 01:07 PM | #62 |
Rep 1,627
e92 N52 and N54... Shifting from 1st to 2nd was always a PIA. Not the case with my F32, very impressed with this one.
M4 in MG | 6 MT
08-30-2015, 08:44 PM | #63 |
Rep 36
for any of the guys that have experienced f30 1->2 shift issues,
can you describe the conditions under which it would be most likely to occur? like what RPM, and are you trying to shift as fast as possible, is the clutch fully depressed, etc... i'm trying to determine if i have a faulty transmission (before i go out of warranty)... appreciate any 411! |
09-22-2015, 10:47 PM | #65 |
member
Rep 5
SAME ISSUE here on 2013 335i 6MT with 27k miles. Syncros messed up and grinding when shifting from 1st to 2nd at higher rpm's. Dealer is replacing manual transmission.
08-18-2016, 08:25 PM | #66 |
Rep 5
Exact issue on a 2014 335i 6MT
27000 miles. Got the car as CPO, with 16000.
Noticed some grinding when up-shifting OR down-shifting into 2nd gear, almost from the day I got the car, but associated it to me "getting familiar" with the car/gears/clutch. Despite having 20+ years of MT experience. Over the course of several months, I felt it was getting worse and realized I'm getting more and more hesitant and careful when 2nd gear shifting. And, my belief is that the 2nd gear in MT cars should be one of the more enjoyable ones...:-) This grinding made all the "2nd gear fun" go away...:-( Read this forum, took my (under-warranty) car in, and sure enough, the transmission is being replaced with a rebuilt one. Interesting bit about the process: my local BMW service shop needed authorization from BMWNA before proceeding with this replacement. They had to take a transmission fluid sample and my SA commented the color was BLACK. Not sure what caused what: bad synchro discolored the fluid, or "something else" ruined the fluid, causing the synchro to fail later... |
