06-30-2013, 09:25 PM | #3939 | |
Rep 139
I did the 6NK, right click ECU, code and it coded the entire car but still nothing...maybe something to do with my token. |
06-30-2013, 11:36 PM | #3940 |
Rep 1,892
Did you also properly install the 2 patched jar files?
07-01-2013, 01:18 AM | #3941 | ||
Rep 40,650
07-01-2013, 01:20 AM | #3942 | |
Rep 40,650
07-01-2013, 05:10 AM | #3943 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Hey all!
Does anybody know will the ISTA-D (2.35) run under VMWARE connect to the F30 via ENET cable I made for E-SYS? If yes how a have to configure VM network connection? Last edited by avgor123; 07-01-2013 at 05:37 AM.. |
07-01-2013, 06:24 AM | #3944 |
Rep 40,650
No. You need an ICOM Interface or ICOM Emulator VM.
07-01-2013, 11:06 AM | #3946 |
Rep 40,650
And so can S90MJG. I think it is a 24 hour wait.
PM's sent.
07-01-2013, 04:01 PM | #3947 | |
Rep 139
coding successful! only turned on bt audio stream, changed the startup display and digital speedo. couldn't figure out how to do office since the names have changed. |
07-02-2013, 04:02 PM | #3949 | |
Rep 1,892
For example, for people with a combox, but no enhanced BT, you can change the VO 6NH code to 6NK and VO code the HU_CIC and CMB_MEDIA ECUs to enable it. That will also enable the use of the white iPhone cable instead of requiring the Y-cable. You can't just add any old code though as the ECU software still requires the car to have the hardware it is enabling. Some codes (like 6NR - BMW Apps) also require an FSC (security) code before the function will become available and the FSC codes can be expensive. |
07-03-2013, 10:51 PM | #3951 |
Rep 91
Hey all I am looking for a code to keep the fog lights on even when high beams are on, also a code for the fog lights to automatically come on with the switch in the auto position.
I understand it is illegal for high beams and fog lights to be on at the same time. Would appreciate it thanks. |
07-04-2013, 01:21 AM | #3952 |
Rep 1
Hello @ all,
I'm new here. Could anywone also send me the links to the latest version psdzdata? I Have E-Sys 3_23_4! E-Mail: Damir1984@arcor.de Thanks! |
07-04-2013, 02:06 AM | #3953 | |
Rep 40,650
07-04-2013, 11:26 AM | #3954 | |
Rep 29
Drives: 2012 BMW 328i Sportline
But I hate the ASS feature and would like to tweak a few things, like get rid of the nag screens... When I asked the dealership how long it would take to change the ASS to last state they stated it would be from 2.5 to 4 hours...why did they state it would be this long ???? Also can you send me the link(s) to get started..thanks in advance
2012 Black Sapphire Metallic 328i Sportline | Technology | Premium | Heated Seats
07-04-2013, 11:32 AM | #3955 | |
Rep 40,650
PM sent.
07-04-2013, 01:39 PM | #3956 |
Rep 122
Shawn, do you have a manual to configure the ICOM emulator VM whith ENET?
I can't connect the VM with ICOM emulator to ZGW. That VM has two network adapters. One is connected to VMnet2 with IP 169.254.247.242. Second has IP 192.168.68.128 and is connected to bridge. ZGWsearch doesn't see the ZGW. Ping to ZGW address 169.254.42.77 doesn/t work. How I have to configure the second network adapter to connect VM and ICOM emulator to the ZGW? |
07-04-2013, 01:58 PM | #3957 | |
Rep 40,650
Which version are you running? After launch, are you reverting to the Snapshot to bypass the Dongle check?
07-04-2013, 02:13 PM | #3958 | |
Rep 122
I have ICOM connector v.1.2. UPD. I tryed to set other IP addresses to second netwirk adapter but trere is no connect to ZGW. - obtained from network - equal IP of real network apapter - IP from the same net as real network adapter ( in that case ping to ZGW works) Last edited by avgor123; 07-04-2013 at 02:18 PM.. |
07-04-2013, 03:13 PM | #3959 | |
Rep 40,650
Look at this Guide here: http://www.2shared.com/complete/dG2T..._ICOM_Emu.html It is for Ops Head, but it should be the same for ENET except pick ENET.
07-04-2013, 03:54 PM | #3960 |
Rep 10
Hi Shawn,
Hate to be another one of the "please help me out" people, but if you could send me the email you've been sending everyone with the links and whatnot, I'd really appreciate it. I plan on seeing how far I can code this baby (brand new 320i EfficientDynamics) and plan on sharing all I find out (helps that my wife is German, I can ask her to translate ) Email is f30felicia@gmail.com Cheers and thanks. Last edited by spekesel; 07-04-2013 at 04:01 PM.. |
