BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > *** OFFICIAL bootmod3 de-cat with OBD readiness THREAD***
      08-07-2018, 06:52 PM   #23
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
Self serve emissions...that sounds damn convenient
      08-07-2018, 07:31 PM   #24
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
Originally Posted by TSA8151 View Post
Originally Posted by JaredG_F30 View Post
Has anyone tried to pass emissions testing with bm3 tune? I'm a bit confused from what Halim is saying on FB, but it sounds like the tweaking the de-cat tables won't affect the readiness monitors, which contradicts that other tuners have said.
Any insight on the dialog below?
Passed Maryland self serve emissions testing with bootmod3 flashed. But I put the stock cat back in.
Proud of you? You swapped back to a cat the doesn't create an issue. This thread is about cats that cause readiness check failures and cel.
Being flashed has nothing to do with passing emissions. It's the elimination of a cat that is the problem
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      08-07-2018, 08:28 PM   #25
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
Big question is do the high flow sport cats pass the sniffer test in Ca?
      08-08-2018, 10:46 AM   #26
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Yep. I'm using OBD Fusion (iPhone) and it has a monitors tab so going to see what it shows with OTS tune vs. modified stock tune.
Originally Posted by paimon.soror View Post
Can't you just make the tweaks and check an app like Torque to see if the monitors are ready or not? I get my down pipe this weekend so i can check then if no one else has.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      08-08-2018, 11:32 AM   #27
paimon.soror
awesome, ill do the same for added verificaiton
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      08-08-2018, 10:51 PM   #28
52172
52172's Avatar
Why not run a catted high flow downpipe? Small loss in power and can still have all 4 sensors ready? Plus pass the sniffer in states that put sensor up the tailpipe?
      08-09-2018, 06:31 AM   #29
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
Price difference. Not to mention all catted DPs are not created equal. I had a challenge HFC and it threw a CEL in the first week. There's only one or two companies that guarantee no CEL and the price of those DPs is why people have been trying to find a solution for catless.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5
2013 Glacier Silver F30 335i (sold)
      08-09-2018, 01:20 PM   #30
52172
52172's Avatar
Gotcha. The Wagner catted downpipe will throw the cel I take it? Thanks
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      08-09-2018, 01:32 PM   #31
maxio
maxio's Avatar
19
Drives: 2014 335i M Sport
It's not about the maker of the high-flow cats, it's about the concentration they're using.
From what I understand, OEM is 400 CEL, and if you stick with 300 CEL cats chances are you wouldn't throw a code.
Most makers use 200 CEL though, so make sure you check before you buy.
      08-09-2018, 03:53 PM   #32
Jpup
Drives: 2015 435i
I think the ideal situation would be is how do we set all readiness monitors to ready minus the cat monitor. I wonder if that is possible through a map editor in BM3 and doesn't require deeper coding.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless
2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30
      08-09-2018, 05:41 PM   #33
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
subscribed
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      08-09-2018, 05:47 PM   #34
52172
52172's Avatar
Wagner is 200 so would throw a cel I guess
      08-10-2018, 07:56 AM   #35
JaredG_F30
JaredG_F30's Avatar
1106
So this is what my monitors look like running the Stage 2 E30 map. After I run through this take of E30 I'll flash to stock and review monitors again. Next, I'll flash the modified stock map (as per post earlier in this thread) and test again.
      08-10-2018, 08:04 AM   #36
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Damn I'm getting my catless DP TODAY and my inspection expires in September. Really don't want to wait until the end of the month to swap it.
      08-10-2018, 08:20 AM   #37
JaredG_F30
JaredG_F30's Avatar
1106
Can you get your inspection early? Best bet is to swap out the DP after inspection.
      08-10-2018, 09:38 AM   #38
XxThe_RemedyXx
967
Good question... I'm in NY. I have to look into that and see if I can. If so, I'll have a year to figure out the next one
      08-10-2018, 01:43 PM   #39
phat8186
phat8186's Avatar
Drives: G20 M340i F30 EBII E92 AW
Interested info
      08-10-2018, 05:35 PM   #40
XxThe_RemedyXx
967
Just spoke to my local guy. He says as long as only one monitor is on, I'm good to go. Here we go!
      08-13-2018, 11:45 AM   #41
TerryGTX
Drives: 2014 Bmw 435xi M-sport
So excited to let you guys know that my f32 n55 EWG passed emission test today with stock tune and catless downpipe and without any other mods (simulator or spacer) today.... if you are near Boston or in Massachusetts, you know it's hard to pass without cat. But my guy at a trusted shop just had the inspection stickered !!!!
So much effort spent on reading the posts in the forum ... purchased VRSF dp fix...looked through the tutorials.... nothing worked on EWG... until my guy told me the car needs to be driven in a specific manner so the monitors come on while still before the o2 sends a CEL... I don't know how he did it but he just drove it for some miles and had it passed! .. and he has done three cars successfully...all 2014+ N 55 EWG.
      08-13-2018, 12:25 PM   #42
JaredG_F30
JaredG_F30's Avatar
1106
That's awesome news. Any way that you can source the driving procedure and post it here?
      08-13-2018, 04:25 PM   #43
maxio
maxio's Avatar
19
The above is definitely possible - I recall drive cycling around 8 times and 1 of those times all monitors turned ready, but the CEL triggered shortly (within 5 miles of additional driving).
The other 7 times the CEL came on as soon as the monitors were "Ready".
      08-13-2018, 06:39 PM   #44
Jpup
Drives: 2015 435i
As I was prepping to do the same in AZ (get all readiness monitors set but O2), I was instructed to follow the following procedure:
https://www.instructables.com/id/How...or-Smog-Check/
The guy on the N55 FB page said he has done this a couple of times now and if you follow it exactly, it will get all your readiness monitors minus O2 ready for emissions. He said the trick is to try and follow this procedure while using an OBDII reader to watch your readiness monitors in real time. As soon as you had all but one monitor ready, drive straight to the testing station and get it tested. A good tip would be to try and do the driving procedure as close to the testing facility as possible.
