BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Undercarriage Wash Question
      03-05-2015, 04:42 PM   #1
Straight Six
Straight Six's Avatar
Drives: '15 335xi M-Sport
Due to recent road treatments I feel I need to perform an undercarriage was on my 335xi. Once I did this with my Chevy at an automatic car wash and it damaged my horn that goes off when I lock the car. I was wondering if there is anything I could damage on my 335?
Thank you!
      03-05-2015, 04:47 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
No
      03-05-2015, 04:51 PM   #3
Straight Six
Originally Posted by F32Fleet View Post
No
Thanks!
      03-05-2015, 08:03 PM   #4
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
This isn't a good idea...
SOLD: 2012 335i Mineral Gray
      03-05-2015, 09:00 PM   #5
2014_335i
Drives: 2014 335i
Thank you!
It will be fine.
      03-05-2015, 09:18 PM   #6
Vegetable
Vegetable's Avatar
Drives: 2019 M4 MT
Originally Posted by 2014_335i View Post
It will be fine.
..... (rest of sentence) without the undercarriage car wash
M4 in MG | 6 MT
      03-05-2015, 09:56 PM   #7
2014_335i
Drives: 2014 335i
It will be fine.
Thanks, I can speak for myself.. Vege-brain can enjoy his German bits as they tarnish and rot off.
I highly recommend a thorough cleaning on a regular basis of the car's undercarriage for any cars that spend time on mag chloride, salt, ice melt etc.
      03-05-2015, 10:17 PM   #8
Vegetable
Vegetable's Avatar
Drives: 2019 M4 MT
Thanks, I can speak for myself.. Vege-brain can enjoy his bits as they tarnish and rot.
Perhaps you can start speaking in complete sentences, then. If a Vegie-brain can do it, so can you.. I have faith. But I agree that nobody ever needs an undercarriage wash from a car wash.. oh wait..
M4 in MG | 6 MT
      03-05-2015, 11:19 PM   #9
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Because BMWs have a protective under-carriage body panel - actually part of the aerodynamics to smooth under-body airflow - there is much less exposed to corrosion. The engine compartment, for instance, is completely protected.
I don't think anything is exposed to get water-logged, and I've taken my car through car washes that spray under there.
      03-06-2015, 07:25 AM   #10
Prossx
Prossx's Avatar
293
Drives: 21 G82 6MT SPY/YMB
I know nobody reads these but page 11, 2014 BMW Service and Warranty Information manual states: Underbody maintenance: The underbody has to be cleaned at least once a year, in Spring, with plain water in order to remove mud, chemical sediments and other deposits. If those materials are not removed, corrosion will occur on metal components. Your BMW center will do this anti-corrosion service for you.
      03-06-2015, 08:07 AM   #11
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You read your manual?
      03-06-2015, 08:51 AM   #12
Kev314
Drives: 2014 328 xdrive
I do under-wash in a touch less system every couple of weeks or so. No problem. However, I make sure air temp is at least 32degF.
On other cars (not bmw) I've seen tie rods and other bits corrode/rust-out after 10+ years, and hope to keep the 328 that long. So if you're a short-timer then doesn't matter.
      03-06-2015, 09:08 AM   #13
ft1330
Drives: 2014 335i
I wash the underside with a hose, as much as I can reach without lifting the car.
      03-06-2015, 10:51 AM   #14
Don N.
Don't go through an automatic car wash to have it done. If you do it yourself with a hose, it should be fine enough.
-Don
      03-06-2015, 10:57 AM   #15
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
I don't recommend automatic car washes for any nice car, but certainly not the undercarriage squirt: many car washes re-capture and re-use rinse water. So you would be spraying a sheen of salty water underneath your car.
      03-06-2015, 11:53 AM   #16
Billfitz
Billfitz's Avatar
Use a lawn sprinkler. Run the hose under the car from front to rear, turn on the water with moderate pressure, slowly pull the hose.
      03-06-2015, 01:21 PM   #17
JMSpace144
Drives: '13 335i
Never thought of this
      03-06-2015, 01:33 PM   #18
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Washing underneath is always a good idea, all of those suspension components that get caked with road salt would like a good cleaning.
If you have a pressure washer that can be adjusted for lower pressure it will work great to help blast the gunky stuff off.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      03-06-2015, 01:39 PM   #19
Thumper333
Thumper333's Avatar
Drives: 2018 M240i X-Drive
I lift the car and roll under on a dolly with a toothbrush.....................
Seriously, the hose and sprinkler suggestion above is genius, obviously it's a choice that has to be made. Do nothing, or use one of the automatic's. If you can't get to it yourself for whatever reason, better to go auto than do nothing.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded)
2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O
2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O
1983 Porsche 944 All stock
      03-06-2015, 02:56 PM   #20
Straight Six
I love this idea!
      03-06-2015, 03:02 PM   #21
Agamemnon
Drives: 2016 m3 ss2 zcp full leather
Yes the lawn sprinkler idea is the best. I have used this method since owning my first car in 1970. Stay away from car washes - they cause nothing but grief. I don't let the dealer run my car through the car wash when it goes in for service.
      03-08-2015, 07:21 PM   #22
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
Set your hose to the widest spray and thoroughly sweep through the underside of the car on all 4 sides. This will catch a majority of the salt dust since the underbody is decently flat. No more than 5 mins for the whole process. As Prossx mentioned, BMW recommends this in the manual.
I did this every weekend during MN winters and the results showed when I got a loaner. The loaner had rust on exposed bolt threads on the rear suspension while mine were like new.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
