02-14-2019, 09:55 AM | #67 |
Rep 12
Yea I love that meat flush look, CONGRATS! Can you send some pics of the set up? Any camber required? I'm on standard brakes so it should work just fine Thanks!
02-14-2019, 10:27 AM | #68 |
Rep 5,140
daniel.d.tran0.00 |
02-14-2019, 10:32 AM | #69 |
Rep 2,655
Hey guys quick question... I'm currently running a staggered set of 400m's on 18X8 up front and 18X8.5 in the rear. They are wrapped in 225/45 DWS06's all arounnd (I was running them on my square set of 397's and didn't want to sell them yet).
My question is, can I run spacers on this setup to get a little bit more of an aggressive look? If so, what do you guys recommend?
02-14-2019, 10:54 AM | #70 |
Rep 37
19x9 ET20 (245/35s)
19x9.5 ET33 (275/30s) |
daniel.d.tran0.00 Alpine-F80200.50 |
02-14-2019, 11:01 AM | #71 |
Rep 12
02-14-2019, 11:03 AM | #72 | |
Rep 12
What you're current offset now? |
02-14-2019, 11:21 AM | #73 |
Rep 2,655
18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 front / 18x8.5" ET47 rear
02-14-2019, 11:31 AM | #74 | |
Rep 2,655
Edit - I'm dumb.
02-14-2019, 11:33 AM | #75 | ||
Rep 12
https://photos.app.goo.gl/NT3VJZ4sRmTUXGMz5 |
02-14-2019, 11:39 AM | #76 | |
Rep 2,655
02-14-2019, 11:56 AM | #77 |
Rep 12
I'm on OEM staggered 225/45 with 255/40. Good luck and let me see some pics once you ordered.
02-14-2019, 11:57 AM | #78 |
Rep 2,655
Awesome. My rear 255's a a tiny bit stretched but not visible if you don't know what you're looking at.
02-16-2019, 12:01 PM | #79 |
Rep 1,127
I think you can do MPSS 255 with 8.5 from reading some threads. I do 245 RE71R's no issue with 18x8.5 ARC-8
02-16-2019, 07:35 PM | #80 |
Rep 797
The 255s bulge on 8.5. I am probably going to sell my summer set. I'd really recommend 245 on 8.5. I will get some pics. 245 18x8.5 et38 with a couple spacers looks ok but isn't exactly dialed. I'm trying to calculate what 245 on 18x9 et30 would look like instead. I may even go 19s but probably not. It sucks not being able to try / test fit.
You won't have any rubbing with 235. |
02-27-2019, 04:05 PM | #81 |
Rep 254
Do you mean 19x8.5 ET20? Or maybe 19x9 ET28? Pretty sure APEX doesn't make a 19x9 +20 ARC-8...
08-08-2019, 12:06 AM | #82 |
Rep 43
Does the wheels poke at all? And do you think running 45s instead of 30/35 will still fit? Really looking to get these wheels but I see a lot of posts saying it won’t fit..
08-09-2019, 08:16 PM | #83 | |
Rep 254
At any rate, are you planning to lower your car? If not, then they will poke a couple mm's but will ride perfectly fine depending on tire choice. I personally like an aggressive look so a couple mm of "poke" can look good if lowered and proper tire choice. Then again I'm the type of person that wouldn't buy wheels until lowering the car first. Regardless, a 45 profile tire is very thick for a 19" wheel, I'd stick with 40 front / 35 rear if you want meaty setup. Here's mine, pretty much identical but with 8.5 +20 225/40 up front (same "poke" because of +20 offset as 9 +28) and I have plenty of room but I have some natural camber from the coilovers. [IMG]https://i.ibb.co/xD7cgBB/2-A25-FAA2-...C228-B7667.jpg[/IMG] |
08-10-2019, 12:31 PM | #84 | |
Rep 43
Yes I’m planning to run coilovers, but damn your car sits sooooo nice! You confirmed for me that I need to get them now haha. Thanks for the info! |
Alpine-F80200.50 |
08-23-2019, 09:20 PM | #85 | |
Rep 43
I’m going to pull the trigger and get some arc8s. Do you think you would have room to run 245/35/19 in front and 265/35/19 in rear or will pull it be a tight fit? |
08-24-2019, 07:14 AM | #86 | |
Rep 254
The front though at that tire width and wheel offset I think you'll rub the bumper tab on big dips/bumps. I shaved part of mine off with a dremel to avoid rubbing on large dips/bumps at my current ride height. You could always do the less aggressive front wheel offset (19x9 +38) and you should be OK with the wider tire up front, just no concave up front but still looks good with rear concave. I almost went that route myself. |
08-25-2019, 02:12 PM | #87 |
Rep 17
Since this has been bumped recently Ill toss my question in here as well.
Looking at these wheels for my '15 F36. How wide can I go without any poke in the rear on stock m sport suspension. 18x9 or 18x9.5? If 18x9.5 would fit what kind of offset would I lookin at? |
08-27-2019, 01:10 PM | #88 | ||
Rep 6,752
If you don't plan on lowering the car, you can use the 18x8.5" ET35 front with 235/45-18 and 18x9" ET30 with 255/40-18 rear for a slightly more conservative fitment. --Dylan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
