BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 - Rear Spacers on 19's
      12-23-2012, 09:52 PM   #1
335i-SG
335i-SG's Avatar
Drives: 2013 335i M-Sport
I want to add spaces to the rear wheels and lower with springs.
How thick of a spacer to make the rim almost flush with rear fender. I have the M sport package 19's.
Which size would you recommend 5mm, 10mm, 13mm, 15mm,etc...?
Who do recommend that makes the spacers for the F30? RE, H&R?
Thanks for the help!
      12-23-2012, 11:21 PM   #2
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Sadly, a 10mm spacer will not work on the F30 rear. The new hub lip prevents this. A 5mm spacer will work, but is simply not agressive enough to flush the wheel. A 15mm will work as well, but it "might" be too agressive.
I also have OEM 19" wheels (401 style). I actually tried a 10mm "tester" spacer (not hub-centric) for the rear and it looked perfect. I should've have taken a photo. It doesn't matter anyways because no one makes a 10mm that fits an F30 rear hub. The front will take any size just fine.
H&R does make a 13mm for the F30. I'm 95% sure that it will fit on the rear and still clear with no rubbing. But I don't want to be the first one to try it. If you decide to do it, PLEASE post up the result here.
      12-24-2012, 07:03 AM   #3
335i-SG
335i-SG's Avatar
Thank you for the response!
Number, are you saying they wont work or they just don't make 10mm spacer that fit the F30 yet?
I'm going to call Rogue Engineering next week to see if they are working on something. I had their spacers in my 2007 335i and were a quality product.
      12-24-2012, 01:00 PM   #4
ƒ°
ƒ°'s Avatar
101
Drives: ✚
They won't work. I don't know if anyone can design a 10mm hub-centric spacer for the rear that'll work out of the box. I believe it's because the hub lip protrudes just enough that a 10mm spacer doesn't have enough girth to have a lip of it's own. But since the lip on the spacer is necessary for hub-centric spacers, the 10mm spacer won't actually sit flush to the hub. There will be a 1mm gap or so. Sorry if that doesn't make sense. It's a bit hard to explain.
HOWEVER, there is a work around if you must go with the 10mm though. You can shave down the hub lip with a grinding tool. Just a mm or so will do. Then the existing 10mm spacers will fit fine (or so I've been told).
Let us know what Rogue says. I'm interested in the H&R 13mm, but it's damn expensive for spacers with no bolts included.
      12-24-2012, 04:56 PM   #5
335i-SG
335i-SG's Avatar
Ill call Rogue and see if they have something in development. If not I might go for the 13mm H&R. I'll keep you guys posted.
I'm also thinking about H&R sport springs. Super sport looks a bit to low.
How much lower will the sport springs be over my M sport springs?
Thanks
      12-27-2012, 02:37 PM   #6
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
815
Drives: Independent Tuning Specialists
Your best bet is always to measure properly for spacers. Everyone car is a little different, and everyone s idea of what's "right" or "fits" can be different. We put together a video explaining how to measure for spacers, I've embedded it below for you to view.
kern4174449.50
ImBlue30.00
      12-27-2012, 02:44 PM   #7
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Thanks
On the M-Sport USA Spec, it comes with OEM springs that are 10mm lower. The H&R Sport Springs will be almost exactly 1 inch lower than that all the way around. This is for the 335i only. 328s won't go as low in the front.
Here's my car with H&R Sport Springs.
http://www.f30post.com/forums/showpo...7&postcount=54
      12-27-2012, 04:31 PM   #8
fastduo
Drives: 2012 335 Melbourne Red Sport/T
Interested in this myself. Please update. Thank you. How much will the Sports lower w/o the M pkg? I have a sport line.
      12-27-2012, 05:34 PM   #9
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
I have BMS 15 mm on the rear and turner motorsport 10mm on the fronts. I have the oem 19" 401's. When I first dropped the car they stuck out a bit too much but after driving for a few miles and it settled it was actually perfectly flush. I highly recommend it. I am on a sportline with Madaptive suspension. never comes close to rubbing.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      12-27-2012, 05:43 PM   #10
ƒ°
ƒ°'s Avatar
101
Drives: ✚
From what I understand, the Sport Line and M-Sport suspension (USA SPEC) has the same 10mm drop. The M-Performance springs should have 10mm more. So 20mm more than Luxury Line. Please correct me if I'm wrong.
Hey fotios, I didn't know you dropped it. Can you post pics of the 15mm spacers on 401s with the drop? I only have the pics when it was still stock high.
      12-27-2012, 06:28 PM   #11
FotiosF90M5
I think thats correct.
No, lol, i meant when I dropped it down from the jack. I am getting the Mperformance springs though so it will be lowered. I have a full msport body kit being freighted now via ups. Im so glad I bought it. Msport with fogs, just what I wanted.
      12-27-2012, 07:58 PM   #12
dboucher30
Drives: E46 328i / F30 335i Sport
Nice, I have the same config. 19" 401 style with m adaptive suspension. I'm gonna give it a try. Thanks
      01-29-2013, 09:51 PM   #13
335i-SG
335i-SG's Avatar
Tomorrow i'm ordering H&R 10mm front & 15mm rear spacers for my M-Sport 335i with 401's. I originally wanted 10mm rear or 13mm but they only fit the front.
My concern is the factory summer tires stick out a lot past the rim. Do you think 10mm front/ 15mm rear will rub?
I also plan to order H&R Sport springs which I believe drops the car .80 more than my m-sport springs.
Any thoughts regarding the spacers? Will they rub when lowered?
Thanks.
      02-07-2013, 01:35 PM   #14
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I have 18's with a 20mm drop (M Perf Suspension).
I'm at the burgermotorsport page and they recommend:
12mm up front
15mm out rear.
Has anyone tried this, seems pretty aggressive...will be running these with 18" 400's.
SOLD: 2012 335i Mineral Gray
      02-07-2013, 01:55 PM   #15
ƒ°
ƒ°'s Avatar
101
Drives: ✚
12mm up front
15mm out rear.
From what I know, nobody's tried it yet. There are some folks with 15mm spacers in the rear, but their cars aren't lowered. I contacted Burger a while back about the 15mm for the 401s in the rear; they said it would rub if you lowered it. The tires do stick out way past the rim.
      02-07-2013, 02:01 PM   #16
dcg71
Australia
72
Drives: F15 X5
I've done 15mm spacers on the rear with H&R sport springs. This is on sport line style 397 wheels - 8" ET34 with a 225 tire. Its pretty flush, rears rub when you corner aggressively.
The 400s obviously are 1/2" wider with 255s, but you have more offset to play with - ET47.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      02-07-2013, 02:53 PM   #17
shivaswrath
Drives: 2012 335i
the 401s are 19's right? They do seem to stick out a bit...in the rear especially, the 255's are nice and chunky.
Yeah, I have the 397's on right now with snow tires, and those tires are tall, it seemed like they'd rub a little...
You mention the ET47 on the 400's helping, does it bring the rim closer to the hub?
I'm not sure I want to spend $200 experimenting..ironically, my concern was actually with the 12mm's up front. Any thoughts on that?
      02-07-2013, 03:13 PM   #18
ƒ°
ƒ°'s Avatar
101
Drives: ✚
12mm up front should be fine. As a matter of fact, you probably have more room to play with on the front than the rear.
      02-07-2013, 06:03 PM   #19
dcg71
Australia
72
Drives: F15 X5
Yeah, they will be closer to the hub, 13mm closer compared to the 397, but the rear wheel will be 12mm wider. The numbers cancel each other out so an 8.5" wheel at ET47 will sit out exactly the same as an 8" wheel at ET34. On M perf suspension you will be 1/2" higher compared to H&R sport, plus you should have less body roll, so I can't see that rubbing.
I've not used spacers on the front, but would be reasonably confident 12mm will work.
Of course we're talking mm's here, so obviously the tire and its sidewall play a big role.
      02-07-2013, 06:06 PM   #20
shivaswrath
Drives: 2012 335i
Done, you've made a good argument, I'll order tonight...
      02-07-2013, 06:55 PM   #21
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Awesome. Thank you for taking the time to do the math.
Be sure to post when you get them!
      02-07-2013, 08:12 PM   #22
dcg71
Australia
72
Drives: F15 X5
No worries, you made a good argument for getting the M perf suspension. My kit is on the way.
