05-16-2013, 10:51 AM | #45 |
Rep 110
06-24-2013, 09:47 AM | #46 | |
Rep 99
am thinking of doing the 10mm front and 12mm on the back. is the 10mm spacers from h&r centric spacers? are you still happy with your set up or would you change any thing? when I first measured my car I was thinking 8mm front and 10mm back. but your car looks to be sitting well. |
06-26-2013, 12:18 AM | #47 | |
Rep 265
10mm is perfect in front. 15mm is a bit aggressive in back. H&R now makes a 13mm that works in rear.
MODS: M Perf. Suspension / M Perf. Exhaust
06-26-2013, 09:03 AM | #48 | |
New Lifetime Replacement Policy
818
Rep 11,738
For rear spacers it is suggested to go with a 13mm and up spacer to avoid issues with the hub design. H&R 10mm spacer are hubcentric. |
06-26-2013, 02:18 PM | #50 |
818
Rep 11,738
The lug studs are going to be 14x1.25 threading and pitch.
Awesome GTI (they are more VW oriented but will typically work with our BMW customers as well) in the UK is a distributor of ours, they also carry H&R products. Last edited by ECSTuning; 06-27-2013 at 08:45 AM.. |
06-27-2013, 10:04 PM | #53 |
Rep 215
BMS 15mm rear and 12mm front with h&r sport, style 416,18x225x45. the look is too aggressive for me so thinking about putting 12mm for the rear and 10mm front. ill be putting my 15mm for sale in classified \\cheers RJ
10-09-2013, 07:21 AM | #55 |
Rep 23
13mm spacers for rear
I just installed H&R 13mm rear and 10mm front on a 2013 M-Sport line with 19" 403 OEM wheels and M performance brakes. The suspension is stock. The look is perfect for my taste. Pretty much flush with fenders.
I also installed a 75mm stud conversion kit from Motorsport Hardware (awesome outfit, great service and pricing from Ryan, highly recommend it) to make swapping between summers and winters easier and to get the longer studs needed to accommodate the spacers. Last edited by chlemaire; 10-11-2013 at 10:27 PM.. |
David0ff1059.00 |
10-09-2013, 08:25 PM | #56 | |
Rep 942
10-09-2013, 08:32 PM | #57 |
Rep 1,591
I'm running 10mm front/15mm rear on 19" 403s. I'm lowered on Bilsteins set to somewhere between H&R Sport and Super Sport height. Fitment is on point for the stance I was going for:
-JustinNApproved
10-09-2013, 09:02 PM | #58 |
Law Enforcer
25117
Rep 22,290
Drives: '22 Chalk Gray Porsche C2S
04-23-2014, 08:28 PM | #59 | |
Rep 1,178
2002 E46 M3 Coupe.. SOLD
2011 BMW 1M Coupe SOLD 2013 BMW M3 Coupe SOLD 2014 BMW 335i MPPK SOLD 2015 M3 SOLD |
06-02-2014, 09:42 PM | #60 | |
Rep 78
Awesome, thanks! |
06-04-2014, 01:02 PM | #62 | |
818
Rep 11,738
-James |
06-04-2014, 03:05 PM | #63 | |
Rep 83
For ECS 15mm spacers you are recommending 14x1.25x43mm conical bolts. Since I don't see 39mm, could I use 14x1.25x40mm ? I want to make sure I have right hardware. Initially I was leaning towards 15mm at the back, but don't what to look to aggressive.
06-04-2014, 03:20 PM | #64 | |
818
Rep 11,738
-James |
06-04-2014, 08:49 PM | #65 |
Rep 83
I have H&R 10mm spacers up front and 13mm rear. I used 40mm wheel bolts up front and 43mm bolts in the rear. This is what was recommended to me by H&R and I've had no issues. I got 8 full turns on the fronts and 9 turns on the rears. BTW, ECS has (at least had) the best pricing on the H&R spacers and wheel bolts.
2014 335i M-Sport 6MT MPPK
Alpine White/Coral Red |
06-04-2014, 10:03 PM | #66 |
Rep 78
