10-14-2018, 09:02 PM | #45 |
Rep 91
Drives: White 14' F32
02-14-2019, 01:33 AM | #46 |
Rep 3
02-14-2019, 05:56 PM | #47 |
Rep 252
Drives: 2017 Model S P100D
02-26-2019, 01:53 PM | #50 |
Rep 16
This is the setup I'm thinking about doing on my F31. With M437's. Any rubbing problems with this? Also, any pics of your setup?
svartorn | '14 F31 // '18 i3 |
04-04-2019, 04:24 AM | #51 |
Rep 4
My F31 is running on OEM Style253 wheels.
8.5" front & ET25 10" rear & ET41 Tires are 245/35R20 (26.8" diameter on tires, which is absolute maximum that fits on front) on all 4 wheels. Little bit of stretch on rear wheels to avoid rubbing. Last edited by agentzer0; 04-04-2019 at 07:05 AM.. |
J555568.50 |
04-23-2020, 08:31 PM | #53 |
Rep 19
I've found no one else in these forums running 255/35/19 front, but I've found a great deal on that exact size if I can make it work on my 2013 320i xdrive. Just curious if you've had any issues with rubbing or other since you posted this?
Thanks |
04-23-2020, 11:00 PM | #54 | |
Rep 4,330
https://f30.bimmerpost.com/forums/sh...&postcount=265 Bimmerguy91 has 255/35/19 square on 19x8.5 ET35 https://f30.bimmerpost.com/forums/sh...8&postcount=13 there are many guys with 255/35/19 in front. [search] 255/35/19 and look through threads that appear to have information you are searching for. |
04-24-2020, 04:57 AM | #55 |
Rep 611
There are guys running even 255/40/19 front on stock suspension without extra 10 mm of x-drive height, as dst86 here: https://f30.bimmerpost.com/forums/sh...020367&page=10
04-24-2020, 08:04 AM | #56 |
Rep 40
I'm currently running MPS4S 255/40/18 (same outer dimensions as 255/35/19) on 18x8.5 et35 all around on VMR v810 on Stock/Base 340i
I'm considering going wider in the rear. Leaning towards 18x9.5 ET45 VMR810 with 285/35/18. Anyone gone wider than 285 in the rear? If I went up to 19" in the rear there's 295/30/19 or 305/30/19 MPS4S available that I could mount on 19x10.5 ET45, but I've not heard of anybody going this wide on a stock f30. |
04-24-2020, 12:10 PM | #58 | |
Rep 4,330
https://f30.bimmerpost.com/forums/sh...2&postcount=85 EDIT rays340i has 1.9 camber also. https://f30.bimmerpost.com/forums/sh...03&postcount=8 285 +45 to +40(slight poke unless lowered) is realistically the widest on F3/4 series. here is aps with 285/30/19 +40 lowered... https://f30.bimmerpost.com/forums/sh...&postcount=291 i'm curious, why so wide? traction issues or just looks? rolling resistance and weight will affects your acceleration, braking and handling albeit slightly. if you don't care, post some pics after it's on. fwiw, your car would look better mildly lowered on some eibach. Last edited by alohasurftoad; 04-24-2020 at 01:20 PM.. |
04-24-2020, 12:50 PM | #59 | |
Rep 3,748
alohasurftoad3079.50 |
04-24-2020, 01:47 PM | #60 | |
Rep 40
As for why, yes to both. RWD running MHD Stg2 now and I'll be going Stg2+ e30 once its released and I find a HPFP. The bump in low end torque looks pretty substantial so a larger tire at a lower pressure should help hooking up. Weight wise my stock 225 runflat w/cast 397 wheel setup came in at 52lbs and this 285 on an 18x9.5 should be about 49lbs so still a win win there IMO. |
04-24-2020, 03:37 PM | #61 | |
Rep 252
7+ lb per wheel lighter than my 442M's that came with my car. No rubbing problems but as per alohasurftoad I'm technically out of xdrive spec |
04-24-2020, 04:19 PM | #62 | |
Rep 4,330
https://f30.bimmerpost.com/forums/sh....php?t=1142647 i'll continue to use 1% even if your x-drive is doing fine with 2.3%. i'll advise people they can choose whatever tire sizes they want at their own risk. |
04-24-2020, 06:25 PM | #63 | ||
Rep 252
Also it tramlines a bit now, I think it's due to way wider tires though Maybe look at the %dif of the x3m/x4m/m5? They are all staggered and xdrive |
04-24-2020, 07:51 PM | #64 | |
Rep 4,330
as i stated earlier, if i give x-drive advice, i'm going to say "same diameters are best", "try to stay below 1% if possible", "codestar has 2.3% so you can exceed 1% at your own risk. |
07-24-2020, 05:40 PM | #65 | ||
Rep 2
275/35 zr19 rear ET35 255/35 zr19 front ET29 Would they have any rubbing issues on 2014 328ixdrive sport line which is on stock suspension and running 225 18inch all around Looking for some help 🙏🏽 Thank you |
08-04-2020, 03:21 PM | #66 |
Rep 12
Could these X3 wheels fit the F30/31
I am looking into changing the wheels on my 2015 xDrive and come across several styles for the X3 which appear to be a bit wider but close to F30/31 OEM offsets. 622M, 309M,608M and 369M.
They are all Front 8.5 x 19 ET38 Rear 9.5 x 19 ET48 Anyone tried any of these or is there some reason they won't fit. |
