11-22-2013, 09:55 AM | #1 |
F30Drive
Rep 82
Required Torque value for 328i wheel bolt?
Does anyone know the required torque value for wheel bolts on a 2013 328i? I'm putting on my winter wheels this weekend for the first time.
2013 Melbourne Red 328i Sportline 6MT- Black Dakota Leather - Aluminum - Coral Red - Premium Package - High Speed Max.
11-22-2013, 10:18 AM | #3 |
Rep 4,721
103lbs for F3x
88lbs for E9X http://www.bmwforums.info/bmw-wheels...e-setting.html I am sure you're going to get different answers, even from BMW dealers. You can always do 90-92 as a compromise. I do mine with such. I can say when the dealer did 103 at one time, my tire shop guy did find it a bit harder to turn the lug bolt because it was secured tightly. Last edited by bobblehead; 11-22-2013 at 10:35 AM.. |
tmdals0213210.50 |
11-22-2013, 06:06 PM | #4 |
Rep 18
A lot of misinformation out there on this. M14x1.25 lugs require 140 Nm, or about 103 ft/lbs.
90 ft/lbs is not a compromise, its wrong. No offense, bobblehead. Don't want those suckers coming loose. |
tmdals0213210.50 |
11-22-2013, 10:05 PM | #5 |
Rep 4,323
Wow, I torque mine to 88lbs!!
But I have a 335...I better go tighten them up tonight...
11-22-2013, 11:49 PM | #6 | |
///M Specialist South Shore BMW
770
Rep 7,108
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
11-23-2013, 09:14 AM | #7 |
F30Drive
Rep 82
Thanks guys. Does anyone know the socket size for the wheel bolts?
11-23-2013, 11:39 AM | #9 |
Rep 376
wow, I understand the importance, but I have been working on cars since I was 15 (15 years maybe more) and I have never used a torque wrench on a wheel nut and/or bolt. I just use a repeatable amount of force (pretty much my pulling strength upward) and have never had a problem with one coming loose or being over torqued.
This is more out of convenience and probably a bad habit. Just thought I would share my experience. |
11-23-2013, 12:59 PM | #10 | |
Rep 1,730
OP - the torque spec should be written in your manual under tire replacement. For my car, it is 90 ft-lb +/- 10 ft-lb. Make sure you re-torque after driving 50-100 miles. If you use spacers or aftermarket wheels with cone seat lugs, make sure you get *at least* 6 turns of thread engagement. Also with different lugs, make sure to spin the wheel to make sure the bolts aren't sticking out the back. Carry factory lugs if you have a spare tire. I like the ratcheting torque wrenches that click when you reach spec http://www.ecstuning.com/Search/Torq...nch/ES2221244/ Last edited by drob23; 11-23-2013 at 01:22 PM.. |
11-23-2013, 01:29 PM | #11 | |
Rep 376
11-23-2013, 01:42 PM | #12 | |
Rep 1,730
I've had a wheel come loose and start vibrating while driving on the HWY and it was some scary sh*t. Didn't know anything about cars at the time and the car was just worked on by a shop. They claimed that someone must have tried to steal the wheels while I was stopped...car was a POS 92 honda prelude with steel wheels and hub caps |
11-23-2013, 07:12 PM | #13 |
F30Drive
Rep 82
lol thanks. I'm an Engineer so I'm very particular about torque values!
11-08-2019, 01:11 PM | #14 |
Rep 1
11-08-2019, 09:07 PM | #16 |
Rep 5,392
11-08-2019, 10:58 PM | #17 | |
Rep 3,748
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered |
11-09-2019, 09:59 AM | #18 | ||
Rep 5,392
05-14-2020, 08:31 PM | #19 |
Rep 11
Drives: BMW F30 328i
