BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > HELP ! No high beam F36
      04-23-2024, 04:16 AM   #1
su_786
Drives: bmw f36
Hi I’m having a strange problem with my car. The high beams do not seem to be working at all when i flash the stalk. There are no errors on the idrive. When I have the car in side light mode when i flash the stalk it activates the low main beam so the shutter is working. It’s when it’s on main beam mode and I try to flash the stalk it dosent activate the high beam at all but it gives me the blue flash icon on the Speedo. Any one have any suggestions ? There aren’t any errors on the idrive. Car is bmw f36 gran coupe
      04-23-2024, 04:19 AM   #2
su_786
Drives: bmw f36
Also to add, I’ve plugged in Carly and ista, dosent show any codes for anything headlight or high beam related ? And I tried to activate the high beam via ista still nothing ???
      04-23-2024, 08:01 AM   #3
samspiderman3125
samspiderman3125's Avatar
46
Drives: 2017 440i gran coupe
did you check bulbs?, and are you LED, Halogen, or Xenon
      04-23-2024, 05:52 PM   #4
su_786
Drives: bmw f36
I checked the bulb and they look fine don’t see why it wouldn’t work on high beam on both of the headlights plus it would give me an error if the bulbs were out no ?
      04-24-2024, 02:08 AM   #5
su_786
Drives: bmw f36
They are xenon headlights btw so it’s 2016 pre lci
