01-21-2015, 04:57 PM | #67 |
Rep 384
08-10-2015, 10:28 PM | #69 |
Rep 443
Edit: Guys, i recently received the m performance carbon fiber shifter and the screw is a T8! You can probably turn the screw with a T6 but it doesnt fill the hole as well and is prone to slipping while in the star peg. I put my T8 in there and it gripped hard and strong without any chance for grinding the hole apart. T8 torx screw is the one to use!
10-12-2015, 06:50 PM | #70 | |
Rep 1,232
12-31-2015, 07:03 PM | #71 | |
Rep 58
Does anyone know how to install the piece highlighted in red? I am awaiting for the piece to arrive but I do not know how to install it. Should I pry it off? Thanks! |
11-22-2016, 10:02 AM | #73 |
Rep 139
I've got a sport automatic transmission. I want to change the original cover with a cover with an M on it, but I don't know how to remove safely the original cover. The included removal tools are totally crap.
Some one knows how to do it safely? Thanks in advance.
F31 320dAs M-Sport Melbourne Red
11-22-2016, 08:03 PM | #74 |
Rep 389
Drives: '13 F30 335i MSport
Use that blue pry tool to gently pry up around the edges. It's just glued down and will come loose easily.
2013 GSM 335i MSport
11-23-2016, 12:56 AM | #75 |
Rep 139
Thanks for the advice, but like I've already said, that doesn't work... . The tools are to soft, to weak,... .
11-23-2016, 03:15 AM | #76 |
Schmollbraten
12512
Rep 1,985
Thats simple, just look at the pictures. Insert a very small slotted screwdriver into the top gap of the old cover and start to move the screwdriver a little around. You would determine that the cover is moving a bit. Now tilt the screwdriver upwards and watch the cover is coming off. The old adhesive strip below should remain, if you want to rechange it any time again.
Now pull off the cover from the adhesive strip of the M-cover and positioning it correct at the shifter knob. Insert and press with slight force after it, your done.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
UKF302524.00 |
11-24-2016, 09:32 AM | #77 |
Rep 139
Thanks for the advices.
I did it with a hairdryer and a modified plastic bicycle tire remover. Van de week in de bus...
11-24-2016, 10:01 AM | #78 |
Rep 356
11-24-2016, 11:11 AM | #79 |
Rep 139
11-24-2016, 11:54 AM | #80 |
Rep 157
11-24-2016, 12:39 PM | #81 | |
Rep 139
One minor complaint. The transparent rectangle for the M/S function LED becomes a fraction lower than OEM (see red oval in the picture below). So you see a little of the alu housing from the gearknob. If you make those two tiny spots black before you glue the cover, you want see anything.
11-25-2016, 02:35 AM | #82 |
Schmollbraten
12512
Rep 1,985
Be warned about imported "OEM M-parts" which are bogus caused by far east fakes. If the customs open up the package and aware the counterfeit product they're be able to charge you for buying known fake products.
Dunno how they would handle that into Belgium but I wont try that in Germany. Btw: Mine is the original including the shifter
11-25-2016, 03:34 AM | #83 | |
Rep 139
https://www.leebmann24.de/blende-gws...312250698.html I know about the fake parts, but little things like this are passing the customs. They got more work with intercepting bigger fake things, I guess.
12-15-2016, 08:27 AM | #84 | |
Rep 11,846
Drives: MY24 G01 AW Msport
i will attempt to do this mod
03-05-2017, 07:21 PM | #85 |
Lovin My Bimmer!
Rep 8
A big thank you to everyone that contributed to this thread. I just finished the installation and it looks awesome!
CURRENT: 2014 BMW 435xi M Sport / RETIRED: 2013 BMW 528i & 2008 BMW 335i Sedan (European Delivery)
05-13-2017, 11:01 AM | #86 |
Rep 4,031
Agree, thanks to the thread! I just did the same.
The screw head that fits is a T8 star head.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
05-13-2017, 12:46 PM | #87 | |
Rep 3,863
Good job sharing this mod Sir |
Dang3r12512.00 |
10-23-2017, 09:22 AM | #88 | |
Rep 199
