09-27-2014, 12:30 PM | #111 |
Rep 40,765
Not needed.
FlorinQCK-2.50 |
10-03-2014, 07:47 AM | #114 | |
Rep 312
Trying Aritaurus method above with E-Sys, but am getting the following error: "Base variant not determinable. Check diagnostic address. [G175]" I'm using the following data for CIC: - Diagnostic Address: 0x63 - Base Variant: HU_CIC - Application number: 27 - Upgrade Index: 0x1 Any ideas what could be causing this? |
FlorinQCK-2.50 |
10-03-2014, 07:49 AM | #115 |
Rep 40,765
Use Application number: 0x1B.
FlorinQCK-2.50 |
10-03-2014, 03:52 PM | #116 |
Rep 10
Would this method mean that you don't need a cable like this?
http://www.ebay.de/itm/171315561475?...84.m1497.l2649 |
FlorinQCK-2.50 |
10-03-2014, 03:53 PM | #117 |
Rep 40,765
That is only for Activation of a Retrofitted Head Unit where Head Unit VIN & FSC Codes do not match car VIN.
FlorinQCK-2.50 |
10-03-2014, 04:27 PM | #119 |
Rep 40,765
There are many different FSC Codes in Head Unit, of which you can only generate one of them, thus for retrofitted Head Unit you still need the activation module.
FlorinQCK-2.50 |
10-04-2014, 03:58 PM | #121 |
Rep 10
help with a e89
Hi all, I've spent the last 5 to 6 hours reading all of the posts on obtaining the FSC but am having problems determining the exact procedure for my 2011 Z4, an E89.
Will someone kindly confirm if I should be buying the Enet cable or the k+dcan usb cable? I have not been able to find anywhere that has any specific reference to my car, so I'm hoping some generous soul will help me out. Thanks in advance! |
FlorinQCK-2.50 |
10-04-2014, 06:49 PM | #122 | |
Rep 40,765
For normal coding and diagnosis of Exx cars, you would use a DCAN Cable. However, you cannot read 1B file from CIC with DCAN Cable. Instead you need an expensive ICOM Interface. And, you cannot use E-Sys to read it either. You would have to use a program called SWID Reader.
FlorinQCK-2.50 |
10-04-2014, 06:53 PM | #123 | |
Rep 10
Thanks Shawnsheridan. I appreciate your reply. I have the swid reader, and have watched videos on how to use it. Will I be able to access my cars FSC code by using the k+dcan wire?
FlorinQCK-2.50 |
10-04-2014, 07:00 PM | #124 |
Rep 40,765
No, I don't think so. All Exx owners I have ever heard from cannot read it with DCAN, and those with ICOM can.
FlorinQCK-2.50 |
10-07-2014, 11:00 PM | #126 |
Rep 40,765
Notepad++
You will some gibberish and then the map name.
FlorinQCK-2.50 |
10-08-2014, 12:27 AM | #128 | |
Rep 1,892
Notepad++ will do it if you enable the Hex Editor plugin. |
FlorinQCK-2.50 |
10-16-2014, 12:15 PM | #130 |
Rep 1
I have BMW F10 530xD (2013 year pre-facelift). Here are the steps I went through updating my map. I have professional navigation (NBT - next big thing). Originally the navigation had Road map Europe Next 2013. I downloaded Europe Next 2014-2, formatted 32 GB stick with FAT32 filesystem, copied the files and plugged into the usb port of the car. The car started transferring the contents to the internal hard drive and after one hour successfully updated the map. On the next restart of the car - it wanted the activation code. I wasn't able to extract it with SWID tool so I used Ariataurus method with the following settings into E-Sys (downloaded E-sys from http://rutracker.org/forum/viewtopic.php?t=4662346 ) - (there are installation instructions within the torrent):
- Diagnostic Address: 0x63 - Base Variant: HU_NBT - Application number: 0xDE - Upgrade Index: 0x1 I successfully extracted the FSC code and saved it to a file - FDZ17056_000DE001.fsc. Then downloaded BMW_CIC_NBT_FSC_Generator from https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q. Extracted it and then went to NBT_fsc subdirectory. Then issued the command fsc FDZ17056_000DE001.fsc 0xA9 0x05 last_seven_digits_of_you_vin_here and got the correct activation code. The correct parameters for map Europe Next 2014-2 are 0xA9 and 0x05. Thanks to everybody in this forum for their great posts. |
FlorinQCK-2.50 |
