02-10-2015, 03:30 AM | #1 |
Rep 360
'Sticking' sat nav
This morning, for the 2nd time (first was back in November), my sat nav seemed very slow to react and often had me up to a mile behind where I was or even just off the road I was on. And even when it found me, the directions on the instrument cluster would freeze for a while.
I know sometimes rtti and other connected services stop but they are phone signal dependent and presumably sometimes need rebooting centrally. However, the nav itself is independent of connected services. Used the nav perfectly fine yesterday. Was just wondering, has anyone else experienced this? |
02-10-2015, 03:32 AM | #2 |
Rep 643
I've had this same thing happen twice, both time I was leaving the center of Birmingham.
Current mods: Mperformance rear spoiler, diffuser, side vinyls and front grille, non OEM carbon mirror caps, Remus cat back exhaust, Eibach springs, TPI spacers 15mm rear and 12mm front, Maxton side blades and v2 front splitter, Pipercross direct replacement air filter, Remus Powerizer.
Current: F36 440i M Sport GC STORMTROOPER Previous: F30 320d M Sport Xdrive STORMTROOPER |
02-10-2015, 07:02 AM | #4 | |
Rep 360
As per m car Chris's suggestion, I will keep an eye on it and book into dealer if it reoccurs. Ps on a vaguely related note, has anyone confirmed if the ota update re. Security has definitely happened. I.e. without using usb? |
02-10-2015, 09:45 AM | #5 |
Rep 729
Mine consistently "sticks" and doesn't wake up for a good 3 or 4 minutes every time I come out of a particular underground car park in Bath. Not only that but the position it shows while stuck is always around 1/2 mile away from where I am (but not always in the same place). I assume it's because it's had no signal for a while while parked and has to re-aquire the GPS satellites.
