BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Replace DRL bulb?
Steve Thomas BMW
      12-15-2012, 11:08 PM   #45
Casualvic
Drives: 328i xdrive
Retrofit set will be sooo expensive.... I have halogen and want to upgrade with hid 6000k kit to include led on every other bulb... But want every color to mach up
Casualvic is offline
      12-31-2012, 10:31 AM   #46
cronek
Drives: '12 F31 320d
http://store.ijdmtoy.com/BMW-F30-328...24w-sku-2f.htm
anyone tried these yet? They're quite cheap but in the pics it looks like the light output is significantly less than the original bulb...
cronek is offline
      01-02-2013, 03:40 PM   #47
Graucho
Drives: 2012 BMW 328i F30
Originally Posted by Graucho View Post
I have them as parking light LED's.... NOT the DRL's.
The DRL's are 24W PW24W bulbs that I still can't find...
I found them... here is a video
Graucho is offline
      01-11-2013, 08:04 AM   #48
nybimmer91
Drives: 320i
does it really matter the light output on DRL? Its more for aesthetics no?...
nybimmer91 is offline
      06-07-2013, 07:52 AM   #49
Roj_cookie
Drives: 320d ED
Bulbs for day running
Can I buy such bulb (blue tint) from Halfords?
Roj_cookie is offline
      06-25-2013, 05:57 PM   #50
v1k1ng01
Likes Cake!
v1k1ng01's Avatar
Drives: 2013 335i m-sport
iJDMtoy has the best mod for LED DRL that I know of. If didn't opt for the xenon's I would do this mod.
v1k1ng01 is offline   United_States
      07-02-2013, 07:22 PM   #51
lt2334
Drives: 128i
This company makes an 18 led version of this bulb now. Does anyone know if it is closer to the stock halogen bulb in terms of brightness?
lt2334 is offline
      07-03-2013, 02:32 AM   #52
Stiunit
Stiunit's Avatar
Drives: 2013 BMW 328i
iJDMtoy are a little to blue for my liking. I would like something more white if possible
Stiunit is offline
      07-04-2013, 10:13 PM   #53
lt2334
Drives: 128i
Is there any company producing a bulb closer to the white spectrum?
lt2334 is offline
      09-05-2013, 12:59 AM   #54
F30 Epal
Drives: F30 320i
Just replaced my stock halogen DRL with ijdmtoy's pw24w:
Happy with the result!
Alpine White '14 BMW 320i 6-Speed MT
F30 Epal is offline   United_States
      09-05-2013, 03:39 PM   #55
Deacon
Drives: 2012 BMW 328i Sportline
I did this same replacement right after getting my car - worked great for 2 weeks then multiple times daily the error codes were displayed that I had a light out. I could turn the light switch to make the DRL's go off and the error message would go away then when switched back the error came back - I did end up returning the bulbs since I was within my 30 day window and they refunded me my $30..
Was hoping another option would surface
Anyone????
2012 Black Sapphire Metallic 328i Sportline | Technology | Premium | Heated Seats
Deacon is offline   United_States
      09-05-2013, 04:20 PM   #56
TheTradingJD
Drives: 2013 F30 328i Xdrive
Mine fell out into the light because of the stupid prongs. Hit a bump and the light fell out of the socket. Getting the thing out of the light housing unit (not sure what it's called but inside the glass) was terrible.
TheTradingJD is offline   United_States
      09-05-2013, 09:14 PM   #57
F30 Epal
Drives: F30 320i
That sounds scary! How were you able to get the thing out?
      09-06-2013, 04:53 PM   #58
v1k1ng01
Likes Cake!
v1k1ng01's Avatar
iJDMTOY.com has an 18 SMD LED option for $34. I don't recommend trying their 8 SMD option though.
      09-20-2013, 10:19 AM   #59
TheTradingJD
it was terrible, had to use one of those metal things that you squeeze on the top and a little claw opens on the bottom to grab things. It's normally used to pick up things you drop in your sink drain. Forgot what it's called, it's a long metal flexible tube with a hidden claw that comes out of the tube when you push/squeeze the top. Scratched some of the plastic on the inside, but what else can you do? I was very upset to say the least.
      09-20-2013, 10:20 AM   #60
TheTradingJD
check out my reply above.
      09-22-2013, 02:15 PM   #61
Syang3
Drives: 2013 F30 328i xDrive
Odd how there isn't a better replacement out yet, it's almost 2014.
Syang3 is offline
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
