01-11-2015, 01:48 AM | #1 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
F30 M Sport shadow trim
My 2014 335i driver side window is squeak & rattle when you rough surface, took it back to dealer and they installed the Teflon tape around the rubber seal and problem hasn't go away. The shop foreman mentioned the rattle noise is very common among the shadow trim model, not sure if anyone had this occurred on your F30 ? TIA
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
01-11-2015, 08:31 AM | #2 | |
Rep 335
01-11-2015, 05:35 PM | #4 |
1131
Rep 5,557
I will keep you posted when the car is done with the repair, dropped it off yesterday and hopefully they can get it fix this time around ( second trip to dealer ).
01-11-2015, 05:38 PM | #5 | |
1131
Rep 5,557
01-11-2015, 07:29 PM | #6 |
Rep 335
01-12-2015, 12:43 AM | #7 |
1131
Rep 5,557
What brand did you go with? Thanks
01-12-2015, 03:40 AM | #8 |
Rep 16
I thought that the best solution for all these squeaks/creaks was the teflon tape according to threads I read.
If teflon tape doesn't work then that is a problem because I have my appointment for this Thursday for dealer to install teflon tape in my 2015 335i msport. |
01-12-2015, 12:53 PM | #9 |
Rep 335
FWIW, I used this: http://www.detailedimage.com/Blackfi...P205/16-oz-S1/
I doubt that it matters much what product you use as long as it creates a semi-permanent slick surface that allows the surfaces to easily slide past each other. Although I haven't tried it, a coating from a company like Optimum, 2pple or cQuartz would probably last longer than a sealant. |
01-13-2015, 01:10 AM | #10 | |
1131
Rep 5,557
Design flaw ?
01-13-2015, 11:14 AM | #13 |
1131
Rep 5,557
I only had the problem with driver side and dealer went ahead and installed the Teflon tape on all four windows.The noise came in & out randomly and that is why I have them recheck the repair.
01-14-2015, 01:27 AM | #14 |
1131
Rep 5,557
Picked up my car today and all dealer did was lubing the seal and window guard no other part were replace, disappointed let's see what happened next if problem remains I will have them check it out again.
So far the Teflon tape did help to bring down the rattle but it's not completely gone.
01-14-2015, 09:43 AM | #16 |
Rep 204
I hear the creaking/squeaking noise (no doubt from chassis flex) on my F30 which is especially noticable on speed bumps. I have been using gummi-pflege (sp?) about once per month around the rubber seal on the upper part of the doors which make contact with the M-Sport Window trim. It lasts about 2-3 weeks and the noise starts to come back in again. My first service should be in the next month or two and will be bringing it up. Until then, the home-remedy above works good enough as I just apply it every other car wash or so. I shouldn't have to do it but I don't mind if it means I don't have to be annoyed by this on a daily basis.
2014 328d MSport ED: 5/2/2014 2013 F30 Activehybrid3 MSport (Gone) 2012 F30 328i Sportline (Gone) |
01-14-2015, 11:53 PM | #17 |
1131
Rep 5,557
So far so good Teflon tape plus lube that really help will see how long it would last.
01-16-2015, 03:46 PM | #18 |
Rep 16
My car is at the dealership and was just told that the teflon tape is helping reduce the noise but not eliminating it completely. I was also told that the tape does not look good on the car by the SA.
I thought that the teflon tape used by the dealer would be the clear tape kind? I guess I will have to head down to the dealership to see what type of teflon and where they applied the tape. |
01-16-2015, 04:28 PM | #19 |
Rep 2,266
My SA said they won't do the tape and to just wipe down the surface. I clean the car weekly so it's not a big deal and keeps the noise down.
F30 Sapphire Black M-Sport 335i 6MT
01-16-2015, 04:55 PM | #20 | |
Rep 398
Please look for the thread i made. Even pictures are there. |
01-17-2015, 11:32 PM | #21 | |
1131
Rep 5,557
01-18-2015, 12:30 AM | #22 |
Rep 16
Picked up my car today from the dealer. With the teflon tape on so far so good with no squeaky/creaky noises to report even over speed bumps
I do notice small air bubbles and imperfections on the installed tape but not sure dealer could have done a better job. Brand new 50K+ car and have to put a tape on so the car doesn't squeak I like BMW and this is my 4th but |
