12-06-2017, 01:52 PM | #1 |
Rep 268
Touch Controller Retro Fit - Req plug
Alright all. I'm planning on retrofitting a touch controller into my 13' 335i. My car currently has NBT pro nav with the controller on the K-can 1 bus. I have brought some 22awg cable to splice into the K-Can 2 bus at the rear of the NBT. I want to terminate at a new plug that fits into the Y splitter cable for the NBE and TBX modules. Does anyone know what the plug number is (or where I can get one with pins) that is on the end of the current harness in the car? Its a four pin male plug. All I can find is the female CiC plugs online. I plan to pinout the live and earth and then make a new plug for K-can 2.
Thanks in advance. |
12-08-2017, 07:03 AM | #2 |
Rep 268
Think I might have found them. These are the plug and pin numbers.
61132359994 61138380696 |
IndotagSwizz524.50 |
01-07-2018, 08:27 PM | #3 |
Rep 808
01-15-2018, 02:00 PM | #4 |
Rep 268
I havnt got around to it yet with Christmas etc. I want to do it at the same time as my screen upgrade and I have been fettling that. Maybe this weekend.
01-15-2018, 09:16 PM | #5 |
Okurrr
Rep 54
Can someone tell me what the advantages and/or appeal of the touch controller are?? My car came with it and I didn't realize there was a non touch version until I started browsing this sub-forum. The touch controller is larger which is very nice, but I've also only really found 2 places the touch pad has a use, and drawing numbers for a phone call is jank at best.
01-16-2018, 03:46 AM | #6 | ||
Okurrr
Rep 54
01-16-2018, 01:52 PM | #7 | |
Rep 48
It's handy for entering nav destinations too. Mine doesn't have too much trouble with numbers in addresses. |
02-10-2018, 01:55 AM | #8 |
Rep 12
Hi there, I want to upgrade my idrive controller
My car came with no navigation and I bought a retrofit OEM from BMW part numbers: 65902450301 65902410425 65902414644 I want to change my idrive (65902410425) for one with the touch screen...my wiring retrofit is ready with the connectios for the touch controller and 2 pins and 1 connector... but I really have no idea if all I need to do is simply buy a new idrive touch drive and controller and replace or do I have to change/add pins to K_CAN2? My car is year 2016 production date 7/2015 f30 320i VINK356623 Can any one advise? |
02-12-2018, 07:23 AM | #9 |
Rep 268
If your car is a 2016 then your current I drive controller will be on Kcan2 anyway. If you retro fit a touch controller it should work straight away. You will probably have to do a couple of lines of coding so the car knows you have touch controller installed. It will obviously only work as a normal controller (minus touch function) if you do not install the TBX handwriting module in conjunction with the new controller.
