BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > iND F30 painted bumper reflectors replacement DIY
Vorsteiner
      11-29-2013, 01:22 PM   #89
hansolo1019
Drives: 2013 F30 328i
I just installed mine last night, heat gun is a must.
I was able to install both sides within 10 min with heat gun.
      11-29-2013, 01:49 PM   #90
tiburonarce1
tiburonarce1's Avatar
Drives: 2014 328i
Thanks ordered mine from ind and are on their way.
      03-07-2014, 12:37 AM   #91
livewyr25
Drives: 2014 F30 M Sport
Originally Posted by Nate@IND View Post
$75 shipped within the US
I know it's an old thread, but you charge for shipping now?
      12-13-2014, 02:36 AM   #92
F30kma
Anyone have pic of the rear reflectors install before and after? Post if you replaced the red rear reflector to match the color of the vehicle exterior body paint.
Thx!
      04-13-2015, 09:54 AM   #93
ska///235i
***** noob
ska///235i's Avatar
Drives: M235i
2006 325xi  [0.00]
Ok, got it done
No need for pry tools, just a 8mm socket and a heatgun...also a pair of gloves
Do not try to do this in cold temps, my first attempt fail cuz the outside temp was around 40-50 degree. I'll say 60 degree and above will be better.
I use the heatgun on low and you have to heat all around the reflector for a good 3-5 minutes. Also a good idea to use a rope to hold the plastic fender. I tie it against the wheel so that it will remain open for access.
Push on the reflector and it will come off, if not keep heating it
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
